Protective pouch for underwater housing
Started Apr 25, 2021 | Questions
starbase218 Senior Member • Posts: 1,229
Hello. I'm looking for something like a packing cube or pouch for my Fantasea FRX100 VA housing. This would go in my regular backpack and would contain the housing, the vacuum pump, the o-ring grease and any other things that I might need. Its purpose would be to protect the housing and keep things organised. Does anyone use something like this and if so, what do you use? Thanks.
 starbase218's gear list:starbase218's gear list
Sony RX100 V Nikon D750 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF-S Nikkor 24-120mm F4G ED VR +7 more
OP starbase218 Senior Member • Posts: 1,229
Re: Protective pouch for underwater housing
Hmm, actually I just tried to see if it would fit in the LowePro Off Trail 1 bag I had from back when my DSLR was a normal size, and surprisingly it does! I guess I would like a lighter pouch than this. But if all else fails this is may be a good enough solution.
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Consider tupperware containers...
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Architeuthis Regular Member • Posts: 491
Hi starbase,
I transport my Nauticam housing in this padded bag (similar bags are available for domeports). Housing and ports can be transported this way in the check-in lugagge and do not need to be in the cabin lugagge (plenty of stuff, like flashes, camera, lenses, laptop etc... remain): https://www.nauticam.com/collections/mirrorless-housing-accessories/products/padded-travel-bag-for-mil-housings-w-handles
Using Google I found these, maybe a good solution for Fantasea housings (But I am not shure this is intended for check-in lugagge)? :
http://www.fantasea.com/s.nl/it.A/id.399/.f
http://www.fantasea.com/s.nl/it.A/id.150/.f
Wolfgang
 Architeuthis's gear list:Architeuthis's gear list
Olympus E-M1 II Olympus E-M5 II Sony a7R V Canon EF 100mm F2.8L Macro IS USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
Dann-Oh Contributing Member • Posts: 894
I use a soft sided ice chest to keep my housing safe both around the house and on a boat.
I take photos, not particularly good photos, mostly abstract photos. Yeah abstract is what I would call them, you might call them blurry.
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 +20 more
Reefdiver Forum Member • Posts: 56
Most of us use a roller bag designed for camera gear. Many styles, with adjustable velco pads to customize interior. You can also pack tee shirts, socks, etc around the gear.
