What's the easiest and most affordable way for obtaining UV reflectance images?
Started Apr 24, 2021 | Questions
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: Shifting the focus plane
Johannes Zander wrote:
I think to correct for removing the filter stack in front of the sensor, you need to bring the sensor nearer to the lens.
From the formula given on the above mentioned website you would bring the sensor round about 1,3mm forward to the lens. No shimming of the lens needed.
I have a Laowa 10-18mm that takes a flat rear filter. So, I just tested.
With the filter in, focus set to 3 feet is the same as focus to infinity with no glass.
Thus, the rear of the lens does need to be farther away with the filter in. So, I guess I did have it backward? Ooops. That means removing the cover glass can cost you infinity focus... which is very bad. How come I haven't heard everybody complaining about that?
Well, at least the rest of my post above is not wrong... right?
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Enginel Contributing Member • Posts: 946
Re: Multispectral band extraction
ProfHankD wrote:
Yup, quartz lenses are the "right answer." That's why old EPROM chips used to be so expensive: to get enough UV to erase 'em, they needed a little quartz window and a ceramic package to mount it in.
Has someone crazy enough used them as an image sensor?
Johannes Zander Regular Member • Posts: 467
MOS DRAM would be a better choice I think. But you have to etch the top away.
https://en.wikipedia.org/wiki/Cromemco_Cyclops
 Johannes Zander's gear list:Johannes Zander's gear list
Nikon 1 V1 Nikon D4S Nikon Z6 II Nikon AF-S Nikkor 17-35mm f/2.8D ED-IF Nikon AF-S Nikkor 24mm f/1.4G ED +21 more
ProfHankD
Old EPROM as UV imager
Not that I'm aware of... which I wish you hadn't said.
It takes A LOT of UV to erase a bit, so exposure time would probably be days if not weeks of sunlight, and without a quartz lens to focus the light, I'd probably try a pinhole, extending exposure time into months. However, I will admit that I kind of want to try it now. You should be able to get a huge DR by sampling over time to watch when each bit changes... except I don't think lighting really comes with a huge DR when averaging over a month....
BTW, an early digital camera, the Connectix QuickCam , actually used a RAM chip that had be specially packaged with a glass window. I still have my parallel-port-interfaced Color QuickCam somewhere.... In fact, in 1996, that was just about the only live view camera ("webcam" wasn't yet a thing then) I could hook-up to my 6400x4800-pixel cluster supercomputer-driven video wall, which was a little sad, because it delivered 320x240 images with somewhat wonky color.  Then again, it was the gross inadequacy of that which got me started doing computational photography... so I guess it was a very good thing in the long run?
ProfHankD
DRAM as an imager
That's interesting. I did a lot with NorthStar Horizons back in the day, when they were Chevys and Cromemcos were Cadillacs, but I don't recall ever seeing a Cyclops. However, my first home machine was a HeathKit H8, so it's possible that I was just a tad too late to see those.
My first digital imager was actually a CDS cell strapped to a HIPL0T DMP-4to make a scanner. I actually got fairly decent resolution out of my little kludge, monochrome only. I think I still have it somewhere too.
So, are there any easily-windowed DRAM parts still in production?
I did find a straightforward (if unpleasant) way to remove a plastic case , but I'm not sure it leaves the die functional, and I'd need to bond wires to it and repackage it. Here 's a more official way.
