My DIY Sony X-Pan or A7riiP
Started Apr 26, 2021 | Discussions
SaschaSelli
SaschaSelli New Member • Posts: 6
A few digital alternatives to the Xpan have been around for some time. Hasselblad, Fuji or Panasonic natively display the 65:24 format in the viewfinder.
Cropping afterwards is not an option for me, as I would like to determine the image in the viewfinder.
But since I didn't want to invest in another system, I only had one option: masking.
My old a7rii served as a test device, which, cropped to 3: 1, still delivers around 20mpix.
Without further ado, two strips of tape on the sensor protective glass, using the lines on the display as a guide and the Sony viewfinder only showed the desired 3: 1 format.
Sensor tape
The principle does not really differ from the function of old point and shoots, which covered the top and bottom of the film with a slide.
It is important not to stick the tape flush on the guide lines, as the distance between the sensor and the surface of the protective glass is still too great and there is shadowing along the edge of the tape strip.
Guidelines
Any 24 lens to get the field of view of the 45 Xpan lens and off you go.
The workflow in post is simple: first of all, crop to 3: 1 and then apply all corrections as usual.
Here are a few first test images.
Sony X-Pan
Sony X-Pan
Sony X-Pan
 SaschaSelli's gear list:SaschaSelli's gear list
Fujifilm X100V Sony a7R II Sony a7R III
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: My DIY Sony X-Pan or A7riiP
... Without further ado, two strips of tape on the sensor protective glass, using the lines on the display as a guide and the Sony viewfinder only showed the desired 3: 1 format.
It hurts even to think about tape on the cover glass....  Aren't the grid lines close enough?
Anyway, on the older Sonys, that still support playmemories, it would be possible to use OpenMemories to make an app to do arbitrary aspect crops... but possible!=easy.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
(unknown member) Forum Pro • Posts: 19,317
thats cool,
Don
Sony A7r2 , A6300
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1, em5mk2, em1mk2.
AudiiDudii
AudiiDudii Contributing Member • Posts: 816
Out of curiosity, what does applying the tape to the sensor accomplish that applying the tape to the LCD would not?
In both cases, you'll be able to compose the photo using a 65:24 format mask.  And in both cases, you'll still need to crop a 65:24 image from the captured file to remove the black areas, the same as you would if you crop a 65:24 image from a file containing a full image without black areas.
Lastly, I have to believe it'll be easier to accurately apply the tape to the surface of the LCD than directly to the cover glass ahead of the sensor (as well as being a lot easier to remove the tape later and do so without leaving a traces of evidence behind.)
I'm not trying to be negative here, as I'm clearly missing something ... please educate me!
SaschaSelli
OP SaschaSelli New Member • Posts: 6
The difference lies in the fact that the image is also shown cropped in the viewfinder. Very important for me personally because I prefer the viewfinder.
Of course, masking the display is easier, but the display can hardly be seen in strong light.
There is adhesive tape that leaves hardly any traces, of course you have to pay attention to this before applying, or you can test it on a mirror or another glass surface before sticking it to the cover glas.
SaschaSelli
For me personally, the lines are unfortunately not enough. Since I sometimes go on longer hikes over several days and do not take a computer with me, a lot of pictures accumulate over the course of days, which I would have to crop at home according to my memory.
Of course, the images could be crop by using a batch function in Photoshop, but then I still miss the crop in the viewfinder.
The simplest solution would be if Sony made it possible for us to choose from a large number of formats or even to be able to enter own formats in camera...
ProfHankD
Again, that's do-able using OpenMemories on the A7RII, but I don't think anybody has done it... much rather that than tape on the sensor. For that matter, tape on the sensor doesn't crop -- it seriously darkens a large area, potentially confusing a lot of processing steps (including exposure). I have a hard time getting past being horrified by this idea....
D Cox Forum Pro • Posts: 32,980
The results are very nice, but I wouldn't stick tape on any of my cameras' sensors.
Is there any camera that has a 3:1 crop option ? The Sigma fp that I have will do 3:2 but hot 3:1.
In Adobe Camera Raw, you can set 3:1 as a custom crop ratio, so you could load in a couple of hundred images, "Select All", crop them all to that ratio, and then go through them raising and lowering the frames to suit.
Don Cox
Sigma fp
SaschaSelli
Everyone ticks differently. I have no hesitation in modifying something and the devices are often more robust than you might think.
The multi-field exposure metering was also, to my surprise, not affected. For critical exposures, however, I always use the spot measurement coupled to the focus point.
wouldnt that be great, Ive just bought a 24 mm lens for landscapes on my a7r2 and that would be perfect as i to love shooting out of camera. mind you it wouldnt be hard to make an insert to slip into the camera body or even an insert for a uv filter actually you have motivated my inventive brain
Don
Sony A7r2 , A6300
arbeterfroyen Contributing Member • Posts: 602
Not the same but now I'm thinking about doing an anamorfake filter on a ultrawide...
