EOS R Error
Lenshead1 New Member • Posts: 1
EOS R Error
"Card cannot be accessed, Reinsert card or format card with camera."
This error began to appear with certain cards and now ALL cards. Try to format card with camera and it can't. Formatting card on computer doesn't help.
Any advice, other than the obvious: send it to Canon?
TIA
rmexpress22 Senior Member • Posts: 1,770
Re: EOS R Error
Look inside the slot to see if anything is stuck in there. Or if there's obvious dirt that you may be able to scoop out. The contacts don't typically wear out. I have had dirty contacts on SD cards where cleaning the SD card contacts help.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +19 more
johncal Contributing Member • Posts: 529
Re: EOS R Error
TIA
Do you still have the same problem with the lens removed?
Can you still get the camera to read any cards at all? If so, try reloading the firmware. It might have gotten trashed. Otherwise, send it back.
 johncal's gear list:johncal's gear list
Canon EOS 70D Canon EOS R Canon EF 50mm F1.4 USM Canon EF 28-135mm F3.5-5.6 IS USM Tamron 28-300mm F3.5-6.3 Di VC PZD +8 more
