Using Nikkor 35mm F/1.8 on Panasonic Lumix S5
An Hong Tran
An Hong Tran New Member • Posts: 3
I would like to seek your advice on using my Nikon 35mm lens on my new S5. Have you been using G mount on L mount? How is the quality and handling on S5 with 35mm lens? Thanks for your insights.
KCook
KCook Forum Pro • Posts: 19,562
Re: Using Nikkor 35mm F/1.8 on Panasonic Lumix S5
Also check over on the L-mount forum on this site.
Kelly
 KCook's gear list:KCook's gear list
Canon EOS 50D Olympus PEN E-P5 Panasonic G85
Martin_99 Senior Member • Posts: 1,763
Personally I would rather use native lens - you can buy very good Sigma 35f2 DG DN.
 Martin_99's gear list:Martin_99's gear list
Sony a6400 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony E 50mm F1.8 OSS Sony E 18-135mm F3.5-5.6 OSS Sony E 70-350mm F4.5-6.3 G OSS +1 more
An Hong Tran
OP An Hong Tran New Member • Posts: 3
I have my Nikkor 35mm. So, I would like to use it if it is possible. Thanks for your suggestion.
rdavy Regular Member • Posts: 355
Presumably you are talking about Nikon F mount, type G lens.
If such an adapter existed, it would need an aperture lever actuator for full functionality. Just like the FTZ adapter. I expect it would not be cheap.
Perhaps there are "dumb" adapters, but then you would have to focus manually and shoot f1.8.
 rdavy's gear list:rdavy's gear list
Nikon Coolpix P340 Nikon D600 Nikon D3300 Nikon AF-S DX Nikkor 35mm F1.8G Samyang 85mm F1.4 Aspherical IF +4 more
An Hong Tran
Thank you. I will try them.
