"The best" X-Trans sensor
Started Apr 15, 2021 | Discussions
Novim
Novim Regular Member • Posts: 146
Omar Gonzalez made a video "Which Fujifilm X-Trans Sensor is really the BEST?", to which Ritchie Roesch responded with a text "Comparing X-Trans Sensors".
"The best" for whoom, for what, when, where etc. - the question is improperly formulated as is always the case with "the best" questions, but anyway the question of differences between the X-Trans sensor generations (I, II, III, IV) is interesting. IMHO the generation I (X-Pro1, X-E1) is my favourite for its (analogue) film and grain like look, the generation IV (X-T3 & 4, X-S10) gives punchier images, the generations II & III maybe offer nicer colours. Of course, it all depends on many other variables, uses and habits.
What is your take, and why-when-where?
 Novim's gear list:Novim's gear list
Ricoh GR Digital IV Leica Q Ricoh GR IIIx Ricoh GXR Mount A12 Fujifilm X-E1 +5 more
FTOG Senior Member • Posts: 1,359
Re: "The best" X-Trans sensor
I've watched the video and found it interesting, although I find the discussion as such rather tiring. So long as image quality is sufficient, the video also illustrates that you can reasonably replicate any one sensor's character in post, should it be necessary.
I'd always choose the camera with the capabilities and features I like, and tweak (where necessary) the images to look the way I want them to look.
To that end, I would neither stick with an old camera that no longer meets my needs for its sensor's character, nor would I move to a newer generation if my IQ and functional needs are still met by a less than current generation.
 FTOG's gear list:FTOG's gear list
Fujifilm X-E3 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR +2 more
JNR
JNR Veteran Member • Posts: 4,652
Omar is entertaining and usually very accurate. His conclusions in this instance pretty well reflect what the consensus of opinion among members here has indicated over time and in piecemeal fashion.
Essentially, the 16mp, 24mp and 26mp sensors (X-trans II, III and IV) are all pretty close to each other in IQ, but the color temps and processing differ in arriving at default raw settings and JPEG output. Essentially, the older sensors are warmer and the new more color accurate. The 16mp sensor tends to show a lot of red channel saturation (and I would add that this can easily result in red channel blow out - it certainly was a problem with the Pentax implementation of the same Sony sensor design).
Perhaps the most important take away from Omar (and mentioned in some postings here) is that the JPEG processing on the 24mp sensors seem to be cleaner than the new sensors. Possibly, the greater emphasis on video performance is related to the relatively minor compromise on the JPEG stills side.
I think Omar might have missed one important factor - and that is the 160 ISO setting on the new sensor is yielding a cleaner base result. If I recall correctly, he simply standardized to 200 ISO for comparison purposes... and that isn't quite fair.
Another point not made by Omar relates to the more crop-able aspect of the denser sensors. Omar noted that for real-world viewing, 16 mp looks pretty much as sharp as the denser sensors. True, but you wouldn't want to crop much at all before you run into trouble - especially so with the newer higher-resolution computer monitors. Not to mention that some of us still like to make large prints on occasion.
JNR
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
Pocket Lint Senior Member • Posts: 2,540
The key takeaway here is that the older sensors have less dynamic range.
In Omar’s video, the older sensors produce more saturated colors SOOC. I think what has happened is in each successive sensor generation, the DR and noise performance increased, meaning truer Color reproduction. Someone correct me if I’m wrong but that’s my take on it.
 Pocket Lint's gear list:Pocket Lint's gear list
Canon EOS 5D Mark IV Fujifilm X-Pro3 Canon EF 50mm f/1.2L USM Canon EF 100-400mm F4.5-5.6L IS II Fujifilm XF 23mm F2 R WR +5 more
Artur Darulewski Senior Member • Posts: 1,209
When it comes to AF performance, the newer the better. Moreover old sensors work worse or not at all with AF adapters (Fringer/Viltrox)
I have XT20 and XT3 and, to be honest, can't see any advantage of X-Trans III over IV (I always shoot RAW).
Artur.
 Artur Darulewski's gear list:Artur Darulewski's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +16 more
Emile15 Senior Member • Posts: 1,769
Are you sure that for AF the newer the better really holds? Evidence?
 Emile15's gear list:Emile15's gear list
Fujifilm X100T Fujifilm X-T4 Canon EOS R5 Canon EOS R7 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +12 more
I can't provide any evidence regarding 1st and 2nd X-Trans but here are few facts from my experience:
  • When I had Viltrox EF-FX1, AF worked significantly better on X-T3 than on X-T20.
  • Viltrox EF-FX1 didn't work on X-Pro I (1st X-Trans) and Fringer doesn't support PDAF on 1st X-Trans.
  • When I switched from X-T20 to X-T3 (for BIF) I noticed significant AF-C improvement
  • According my experience (didn't do any tests) low light AF performace was better on X-T3 even with FW 3.21.
  • The 4-th X-trans on X-T3/X-T4  supported by the latest FW 4+ has really good AF especially  AF-C and eye tracking (compared to X-T20)
Well, I bought X-T3 instead X-H1 due to one reason - AF (based only on what I read -also on this forum). I believe that despite X-T20 and X-H1 are sharing the same sensor, overall AF performance is better on X-H1 due to better software.
There are a lot of opinions here on the forum, saying that even old sluggish lenses (56/1.2, 60/2.4) work much better in terms of AF on newer bodies/sensors.
It seems natural, that newer sensors shouldn't be worse (at least in terms of AF) than previous (let's see what we get with new high density 36-40 Mpix sensor in X-H2). There are more AF points, better software etc - I can confirm this on my two bodies.
BTW I also read about better low light performance (less noise) on 3rd vs 4th generation, but even if so - I didn't noticed significant difference.
No offence, but I wonder if you have any evidence/use-case when older sensor is better in terms of AF. If so - please enlighten me
I can understad that the old 1st gen has different nice rendering (according personal preferences) - but it's hard to believe that AF performace was better.
Artur
JNR
The review indicated the newer the sensor the less contrast produced. This referenced the processing and was not intended as an indication of dynamic range. I do believe there have been very minor DR improvements in each version related to added detail due to increased pixels... and the lower ISO floor on the newest sensor. I don't think Omar measured DR, though.
Saturation and color precision are a function of processing parameters whereas DR and noise performance are measured without regard to the color characteristics applied. When processing, the red channel can blow out (due to over-saturation) and lower detail... but the native DR of the sensor should be measured before processing.
JNR
The Davinator
The Davinator Forum Pro • Posts: 24,707
For me
One of the reasons I have never so.d my X-Pro 1 is the color.  In the X-Pro 3, greens are greyish and not pleasing to me.
Threaded Veteran Member • Posts: 4,180
YouTube seems to be full of these videos at the moment.  I like Omar but I’m not sure how helpful comparisons like this are; at the end of the day all these “filmic” labels are hugely subjective and personal and there is more to all of these sensors than simply the look of the JPEG’s; each one comes packaged in a different camera with different abilities and failings, all of which also need to be factored in.
Having used every X-Trans generation and been well down the rabbit hole of which look I prefer, the conclusion I’ve always come to is it’s a fools errand to look back.  The current cameras and sensors do a better job in more situations.  X-Trans I cameras were a pig to use, X-Trans II bodies did terrible things to skin tones at higher ISOs, X-Trans III was great but had some issues with AWB, and X-Trans IV - honestly - is the best of the lot IMO, especially when you take classic neg into consideration.
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
Threaded wrote:
[...] each one comes packaged in a different camera with different abilities and failings, all of which also need to be factored in.
Exactly, as sensor is an integral element of the each camera model, it shouldn't be perceived/discussed as interchangeable part like CPUs in PC systems.
I believe Omar's idea was to focus on some common sensor's output attributes  specific for all implementations of each X-Trans generation. I don't want to justify whether is was helpful, useful or just casual informative material.
I agree with your overall conclusion
Artur
Erik Baumgartner Senior Member • Posts: 6,893
Re: For me
I can see preferring an older camera if you are strictly a jpeg SOOC shooter and really like the particular look you’re getting out of it. When it comes to which has the best sensor though, the color you’re seeing is almost entirely determined by the processing - you may or may not be able to reproduce the color and contrast from the older camera with the the limited jpeg setting options, but you can absolutely do it with the RAW file. This difference in greens could easily be corrected and a custom profile produced in a couple of minutes that will always deliver the greens you prefer. For RAW shooters, I just don’t get the preference for older sensors based on color alone. For jpeg shooters, maybe, but I think you can probably get the results you want (and then some) with some careful adjustment of the jpeg/WB settings.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
EMs1950 Regular Member • Posts: 325
I shoot in RAW format and for me there is no good or even best X-Trans sensor.
I have worked with the X-E1, the X-E2S, the X-T1, X-T2 and X-T3.
And besides that with the X-A1 and currently with the X-T100.
My experience is that nature and landscape photos with an X-A1 and Bayer sensor beat the cameras with X-Trans sensor with the same megapixels showing much better structures in the details.
Also, the photos with my X-T100 (and certainly those of the newer X-T200) show more detail and better rendering compared to X-T2 or T-T3.
There are different methods developing the RAWs. The worst result for X-Trans comes from Lightroom, as it has for years. Even with the current LR CC Classic.
CaptureOne develops X-Trans much better. I still see a slight advantage for the Bayer sensors on my X-A1 and X-T100.
Best Regard
EMs1950
Jason Elander Regular Member • Posts: 164
Omar is The Best
/nt
 Jason Elander's gear list:Jason Elander's gear list
Panasonic Lumix DMC-LX7
blink667 Contributing Member • Posts: 944
The best x trans sensor is the one you own.
 blink667's gear list:blink667's gear list
Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
JNR
An almost artful effort to work Bayer preference into a conversation entirely devoted to the X-trans sensor comparisons. Whether we like it or not, all of the Bayer-sensors are placed on Fuji bodies that are otherwise essentially entry level in terms of performance (and in some instances build).
Yeah, I wish the higher level Fuji bodies would give us the option to decide between the two arrays. But it really doesn't make much difference - as long as the (now majority) of us here have finally left behind slavish devotion to Adobe incompetence and greed.
In any event, please let's not highjack the thread...
JNR
The Davinator
Re: For me
That is the issue.  With the first gen, I don’t need to correct...it is just right out of camera.  That is the point.
Martin Silenus
Martin Silenus Junior Member • Posts: 46
Prediction: At some point Fuji will release an X-Pro1 "film" simulation
Re: For me
Well, you were comparing RAWs which aren't right out of the camera. If you compare the right out of the camera jpegs, Despite the obvious exposure (and significant sharpness) discrepancy, they're actually very close - nothing a slight EC tweak wouldn't fix. I consider any necessary changes of settings to reach a desired result "adjustments". Any tool with so many variables will require a certain amount of fine tuning and calibration for optimal results. Should we also accept our monitor's settings right out of the box?
