Got myself a 700si: anyone knows of a adjustable diopter viewfinder?
Started Apr 15, 2021 | Discussions
Joseph Balson
Joseph Balson Regular Member • Posts: 299
It was cheap, the rubber was literally decomposing on touch.
I did a dirty quick fix with Sugru: looks good enough.
Now, this SLR doesn't have diopter adjust. Anyone know if there is some adjustable diopter viewfinder that I could adapt?
It's just some glass, some silicon and magnesium. It isn't a religion.
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Got myself a 700si: anyone knows of a adjustable diopter viewfinder?
The only eyepiece fittings that have an adjustable dioptre is the 90° angle finder and the straight magnifier .
For normal use these camera's use a clip in dioptre corrector .
The same item is compatible with the Sony DSLRs and visa versa .
Check with your optician what power you need and either order a new one off Sony or an old Minolta one .
I use a -3 in mine so I can use it without my glasses .
Here's a link to one at random ;
https://www.ebay.co.uk/itm/223548341168
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
Joseph Balson
OP Joseph Balson Regular Member • Posts: 299
thanks
MikeInOr
MikeInOr Senior Member • Posts: 1,630
If you ever do another grip with Sugru I would love to see the process.  I have a few old Maxxum bodies that could use a new grip.
 MikeInOr's gear list:MikeInOr's gear list
Sony SLT-A55 Sony a7R IV Sony 20mm F2.8 Sony 100mm F2.8 Macro Sony FE 12-24mm F4 +11 more
neilt3
Hi Mike , it was Joseph that's repaired his camera with Sugru , but I've used it for other things .
The stuffs a bit like plasticine or playdo . Once you've removed your old crumbling grip , wipe the camera body down with a bit of IPA to remove any residues .
Then apply the Sugru to the body and build it up to the desired thickness and contours .
When I used it I wetted my finger with water to smooth it out .
It's available in several colours , so you can use it in black as per original , or pick another colour to personalise your camera , or even a psychedelic mixture !
Once done , just leave it to cure .
Joseph Balson
sorry couldn't answer, I had super great eye surgery.
neilt3 answered.
I should just add that the 3 little packs of sugru were barely enough to make the grip. I should have ordered more to make it a little more bulky.
That stuf is really great.
