Re: Olympus 100-400 VS 40-150 Pro with 2X telconverter
offtheback wrote:
I recently got the Oly 100-400 and wasn't satisfied with the sharpness.I compared it to the 40-150 2.8 with 2x telecon and was happier with the 40-150 result even when I cropped the 600mm effective to 800mm effective.Anyone have the combo and what do you see?Did I get a poor copy?I have the Panny 100-400 and like it except for the stiff zoom which is my second copy(better than the first but still unacceptable for action zooming).Your thoughts please.
After purchasing and playing with the Olympus 300mm f4 PRO, I had this question recently as well. Mainly I wanted to see if I could rationalize just having the 40-150 PRO with 2x TC at a constant f5.6, and pair that with the 300 f4 PRO w/ TC’s...rather than the 100-400 @ f6.3 when fully extended. I didn’t do anything too scientific with my personal tests, but felt I had good enough results to determine for myself the pros/cons. Here were my findings/thoughts if it can be any help:
1). The Oly 100-400 drops down to f5.4’ish (if I remember correctly) around 138mm. When extended to 300mm the Oly 100-400 lens is at f6.3 and can’t open up any wider.
2). In both indoor ambient light and outdoor natural lighting, the Oly 100-400 was noticeably sharper than the 40-150mm PRO w/ 2x TC WHEN the Oly 40-150 was at f5.6 (all other exposure settings similar).
3). I found that I had to stop down the 40-150 with the 2x TC one stop (to f6.3) to get similar sharpness I was seeing with the Oly 100-400 in both outdoors and indoors. (This seems to hold true to what others have said regarding the TC’s, in that, it is helpful to stop down one or two stops to get sharper results).
4). Therefore, in order to have similar sharpness between the two lenses, you are not really gaining any light advantage, (Again, IF you want the sharpest possibilities...which is what I was wanting).
5). With that said, from what I was seeing with my personal tests, it did look like the 40-150 PRO w/ 2x TC did have slightly better color rendition and contrast. (Honestly, if you weren’t looking at the two different images side by side, I doubt one would notice. The Oly 100-400 was still pretty good. Also, if you wanted to edit in post, it didn’t seem like it would be hard to get the Oly 100-400 image to match the 40-150 PRO w/ 2x TC out of camera image...I didn’t try).
6). For fun, I wanted to see how much better the 300 f4 PRO was than the Oly 100-400 at 300mm. The 300mm f4 PRO @ f6.3 had noticeably better sharpness, color rendition, and contrast out of camera. The Oly 100-400 was good...but the 300 PRO was better. (This didn’t surprise me really).
Here was my general personal takeaway: I was hoping to sacrifice 100mm for slightly better low-light capabilities in staying with the 40-150mm PRO w/ TC’s over the Oly 100-400. I was also hoping the sharpness, colors, and contrast straight out of camera would out-perform the Oly 100-400mm. However, with my personal tests, in order to get the sharpest results with the 40-150 PRO w/ 2x TC, I had to stop down to f6.3. This defeated the whole purpose of what I wanted from the 40-150 PRO w/ 2x TC, and the possibility of slightly lower light abilities, as I want as sharp of images I can get with said exposure.
I personally decided the Oly 100-400 was a better choice for me and my use of it over the 40-150 PRO w/ 2x TC. If I wasn’t able to get any light advantage with the 40-150 PRO w/ 2x TC, I didn’t want to sacrifice the 100mm extra reach (I mainly bought this lens for wildlife). I decided that I have to just be very mindful when using the Oly 100-400 lens and will probably be spending slightly more time in post getting the image closer to where I want it (e.g. noise reduction due to high ISO’s needed in low-light, increasing contrast, slight color edits, etc.).
I will probably be selling the 40-150 PRO in the near future. It’s a great lens, but with what I have and my photography, it is redundant. I am finding that I’m not using it as much. I am now pondering on whether I should return the 300mm as well (probably will). Maybe I can put the funds of both the 300mm and the sale of the 40-150 towards the Oly 150-400 PRO. (if that ever becomes available in my lifetime). If I ever do have the ability to get the Oly 150-400, I will sell the 100-400 as well (and put those funds towards that purchase).
Until then, I think I will practice with the Oly 100-400 at longer focal lengths and have fun!
Hope that helps.
