The Red-bellied Woodpecker with the 18-135
Joachim Wulfers
Joachim Wulfers Veteran Member • Posts: 4,987
6
Although this is nearly a 100% crop (83%), the E 18-350 did quite well with sharpness, colour and contrast
 Joachim Wulfers's gear list:Joachim Wulfers's gear list
Fujifilm X100T Sony a6000 Sony a6600 Sony E 18-200mm F3.5-6.3 OSS Voigtlander 21mm F4 Color Skopar Pancake II +12 more
philzucker
philzucker Veteran Member • Posts: 9,380
Re: The Red-bellied Woodpecker with the 18-135
It sure did. A very capable small lens IMO. And very good pose of the bird. Like its colorful plumage.
Thanks for sharing!
Phil
Joachim Wulfers
OP Joachim Wulfers Veteran Member • Posts: 4,987
Thanks for sharing!
Phil
Thanks Phil, I appreciate your comment.
paul wassermann Senior Member • Posts: 1,923
Outstanding!  Only the chromatic aberration hints at an economy lens.
 paul wassermann's gear list:paul wassermann's gear list
Sony a7R II Sony a9 Sony a6600 Sony Carl Zeiss Planar T* 50mm F1.4 ZA SSM Sony FE 90mm F2.8 macro +7 more
Joachim Wulfers
Thank you Paul. Indeed the E 18-135 is susceptible to CA whereas I see that seldom with the FE 70-300
I meant to mention how nice it is to see a bird image that isn't sharpened to the point of making the plumage look like plastic!
Joachim Wulfers
I understand your point. I sharpen +20% in my editing SW, however, when I reduce the photos for posting here, I run them through 0.80 quality reduction and the photos look much more natural. At 1.00 they always came out over-sharpened. It's particularly difficult with the white feathers like with an egret. Glad you liked the result. I should have worked on the CA, however, there was no significant green fringing so the CA did not bother me too much
