Panasonic 14-140 II OIS problems?
Started Apr 14, 2021 | Discussions
BrodenMax New Member • Posts: 8
Hey!
I bought the 14-140mm mark II used and besides some dots on the glass inside the lens (not dust), I don't see a difference with the power O.I.S "on" and "off". Besides the symbol on the screen when its off. I read some complains about a few lenses where the OIS is barely noticable, the 14-140 being one of them.
I like to hear your thoughts about this. If you own this lens and can tell the difference between on and off.
I also bought a 100-300mm II and used gh4 with this lens, so I really need the lens ois. With the 100-300mm, the stabe is very nice.
The 14-140 lens has quite a few dots inside of the glass, maybe from water damage? I haven't seen any on the pictures I've taken. If water has somehow entered the lens, I imagine the power ois also might take damage from this. I've searched the interweb for broken lens-ois, but there's no information about this, which make me believe that it's quite rare.
So what du you guys think, is the ois broken? I'm thinking maybe a firmware update would fix it, but I have the most recent update installed. I haven't found a way to reset the lens firmware and re-install the latest one, is this possible somehow?
You can probably tell that english is not my native language(?).
Thanks!
Panasonic Lumix DMC-GH4
alcelc
alcelc Forum Pro • Posts: 19,003
Re: Panasonic 14-140 II OIS problems?
BrodenMax wrote:
Hey!
Hard to comment anything on used gear since we never know what its pervious owner might have done to it. I owned the non WR version 14-140 f/3.5-5.6 mk-I 7 years, a major lens always on GX85. Despite it had been used under all sort of weather condition from rain (sometime can be heavy), to freezing cold covered with snow, hot and humid to dusty desert... 0 problem so far. Clean as new except some used mark on the lens mount after so many years of usage...
FYI, a WR gear would be harder to deal with moisture or dust etc if it could find its way inside the lens than non WR gear. It is an external zoom designed lens. When we zoom in and out the pumping action would eventually let fine particle goes through the sealing...
On best WR, internal zoom could be more safe.
Before all, I have to declare that my experience is on 14-140 f/3.5-5.6 mk-I only. As per members' info, optically and on performance-wise both mk-I and mk-II are identical.
Why not try it by yourselves? Take few shots on using IS=ON and OFF. To see what is the slowest shutter speed you can use.
I did this on every new lens I purchased. I would take 10 shots on AFS, shoot continuously in very short interval between every shot (half breath) on a reasonably close object having fine detail on it under good lighting condition. Examine the output on 1:1 and take 7 or more sharp image (single pixel formation of edges) out of 10 as the slowest shutter speed you can used.
As per my home testing on GX85, the DUAL IS should be able to provide upto 5 stops of stabilization, which means close to 1/10"~1/15" shutter speed zone on the long end vs the traditional rule of thumb around 1/300".  It means a lot to me.
On GH4, which is a Lens OIS only model, I suppose you could expect around 1/30"~1/40" for the long end @140 (280 eq of FF), i.e., 3~3.5 stops effective stabilization IIRC (my memory is faded since shooting 14-140 on non IBIS body had to traced back to 8/9 years ago: the G1, GF3 and GX1 era).
Of course the above is highly depending on the hand holding stability and style of shooting of individual that could vary a lot.
Not to me. So far all of the lens OIS lenses are very effective to me.
Please bear in mind on Panny bodies we can only enjoy lens OIS or no IS. Unlike 5-axis IBIS Olympus bodies which allow shooter to choose IBIS and lens OIS whichever is more effective, hence for them they might choose to disable lens OIS and use IBIS only, or use an IBIS priority setting. This is not applicable to Panny user!
I also had read some reports that the Lens OIS might indeed soften the image. Mostly were results of the very sensitive OIS mechanism of 14-140 plus its light weight construction. It is well known that 14-140 is one of the shutter shock magnets among Panny lenses on older Pannys which had a noisy/hard m-shutter.
Switching IS off, nor put on a tripod couldn't help. E-shutter is the best solution and recently Panny has used a more quite m-shutter (since GX85) and Auto Shutter to address this problem.
Night and day different, more obvious on DUAL IS or DUAL IS 2 setup for the extra 2~2.5 stops effectiveness stabilization. Of course, I shoot with e-shutter all the time for the best result of this lens.
This should mean a lens OIS only combo. If you switch IS to OFF, you are using a non stabilized gear. I guess you are on a tripod or monopod, or you have excellent handholding skill, or you won't need crazy slow shutter speed?
Could be watermark. Try to shoot at the blue sky using f/22. If dust inside, it will show up on the output. Generally dust won't be noticed on f/8 or faster aperture value.
If there would be watermark, specially if on the inner surface of the glasses, I might pay extra care of it since the watermark might signal water/moisture might have once got inside the lens, that might start to corrode the electronics/motors etc inside. Sort of cancer to electronic gear.
Might be but not must.
Yes it is very rare. Usually the AF might fail easier than the Lens OIS...
Without more info it is hard to guess what has actually happened to you.
No, it won't.
No. We can't.
Thanks!
Please give more info on what led you thinking the OIS of your lens has been broken?
Any in-gear IS is just allowing us to shoot with slower shutter speed than without in-gear IS. The effectiveness of IS will be varied from person to person. While generally 1/focal length of FF was adapted as a guide line, some might require 2x to that!. Even for the same person, the difficulty of shooting, the physical condition of the shooter at the time of shooting etc would also affect the effectiveness a lot. 1 or 2 stops could be off set by many factors easily in real life. Under this shot an effectiveness 5 stops IS might be reduced to 1~2 stops only on another shot...
BTE, if you have doubt on the lens, return it if possible. My 2 cents.
Albert
** Please forgive my typo error.
** Please feel free to download the original image I posted here and edit it as you like **
jonno35 Contributing Member • Posts: 884
I've had the Mk2  14-140  for a year now and the OIS is very good, especially if I use 4x or 2x magnification. Even with th zoom right out it is noticeable when I switch it on ,I am in my 80s so probably bit more shakey anyway. The lens behaves the same as my Leica 12-60, best OIS I've ever had, I have  had a 3 second hand held shot really sharp.
I used to be indecisive but now I'm not so sure.
 jonno35's gear list:jonno35's gear list
Panasonic FZ1000 Panasonic Lumix DC-G9 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 14-140mm F3.5-5.6 II +3 more
Samuel Dilworth
Samuel Dilworth Senior Member • Posts: 1,391
Too much work. Just zoom the lens to 140 mm, point it at a distant subject (e.g. over 5 metres away), and half-press the shutter button to stabilise the viewfinder image. (Keep holding the shutter button half down to keep stabilising.)
Then do the same with OIS switched off. There should be an obvious difference. If there isn’t, magnify the live view image (as if for critical focus) and repeat the on-off test, still at the long end of the zoom where differences are most visible in the viewfinder.
Trolleyman Senior Member • Posts: 1,048
Take two photos with ois on and off at a shutter speed under accepted values for a good result.
The difference should be discernible, always is when I try it that way to see what effect stabilisation is having
 Trolleyman's gear list:Trolleyman's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH Olympus 12-100mm F4.0 +3 more
OP BrodenMax New Member • Posts: 8
Thank you very much for the info.
I have only tested the lens with video, switching the ois on and off on the long 140mm end. I really don't see a difference between the two clips, this is what made me believe that it's broken. When I shot some video with the 100-300 at 140mm, I noticed a huge difference between on and off.
I thank you for the visible lens dust info, did not know this. So I shouldn't worry too much if there's dust, rarely shooting higher than f8. I understand what you mean with the watermarks. Feels like the existing moisture can develope into more damage.
With my video stabe test in mind, I'm 99% sure that it's broken. Maybe it's just the switch, I'm gonna search for a dissemble video of the lens, get a look of it. Or maybe just use the lens on my IBIS Olympus and everything gets smooth anyways.
I will try the things you suggest. Just to make sure it's broken before i open it up, or maybe sell it very cheap.
Thanks again!
Thanks, I will try this. Did not know that the half-press is nessecary. Did not see a difference in video testing tho, so probably broken anyway. But yeah I will try this out!
Thank you for the info!
If as you say the stabe in this lens is very good, I'm certain that mine is broken. I will try taking some photos switching on and off the stabe, I have only tried video. Surely it would stabilize my video too if it was working, but anyway.
alcelc
Forget this since nowadays I have DUAL IS, which is activated automatically once it is powered on... Half hit of shutter (to engage AF) or not gives me no difference 😀.
Albert
alcelc
For video, IBIS would give better differences. Lens OIS is great for still style of frame to frame shooting. IBIS or Dual IS (combination of IBIS + Lens OIS) should be more effective for the video style of continous shooting.
Albert
Cafe Racer Senior Member • Posts: 2,136
So if I get a Panasonic lens for my G80 with an OIS switch on the lens barrel and switch it to the off position, am I also switching off IBIS?
 Cafe Racer's gear list:Cafe Racer's gear list
Olympus PEN E-P1 Olympus PEN E-P5 Panasonic G85 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II Olympus M.Zuiko Digital 45mm F1.8 +4 more
FunGuy66
FunGuy66 Regular Member • Posts: 304
Could you clarify which 14-140 you have?
There was the original f4.0-5.6
There was the first f.3.5-5.6, a new design often inaccurately called Mark 2.
Lastly there's the f3.5-5.6 II, which has the same optical design as the previous but with added splash/dust resistance and possibly other minor improvements.
Could be relevant if your issue is related to water infiltration...
FunGuy66
Yes. On a G80, switching off OIS via the lens switch also switches off IBIS.
On Panasonic bodies with IBIS, the options are:
Lens with Power OIS: Dual IS, or nothing.
Lens with Mega OIS: OIS only (e.g. 45-200 mk1 and a few others), or Dual IS 1 (e.g. the 30mm macro), or nothing.
alcelc
Yes, no IS at all.
For Panny, only non OIS lens can use IBIS.
IBIS will never be used  (except its role in DUAL IS) if the camera can communicate with the lens and know it is an OIS lens. Shooter cannot choose to use IBIS or Lens OIS or DUAL IS... Only the best IS or nothing.
Albert
That's unfortunate. I'm not keen on Dual IS during video recording on the G80 as I find it a bit jittery, I prefer IBIS only. My Lumix 12-60mm doesn't have a switch on the lens and I thought if I had a Panasonic lens with an OIS switch on the barrel I would be able to choose. How difficult is it to implement such an option?
alcelc
Straightly speaking, Power OIS or Mega OIS wouldn't actually play any part on this. If so, just co-incident. e.g. the 14-42 PZ is power OIS was promised to have a firmware update making it DUAL IS compatible like 45-175PZ, but never happen so far...
The best is to check the DUAL IS compatibility list of Panny:
https://av.jpn.support.panasonic.com/support/global/cs/dsc/connect/dual_is.html
The IS policy of Panny is:
  • DUAL IS 2 compatible lens (e.g. 14-140 f/3.5-5.6 mk-I/II) on DUAL IS 2 compatible body (e.g. G85), DUAL IS 2 or nothing.
  • DUAL IS 2 compatible lens (e.g. the 14-140 f/3.5-5.6 mk-I/II) on DUAL IS compatible body (e.g. GX85), DUAL IS or nothing.
  • DUAL IS compatible lens (e.g. 12-35 f/2.8 mk-I) on DUAL IS 2 compatible body (e.g. G85), DUAL IS only or nothing.
  • Non DUAL IS compatible OIS lens (e.g. 14-45 f/3.5-5.6) on DUAL IS 2/DUAL IS compatible body (e.g. G85/GX85), Lens OIS only or nothing.
  • Non OIS Lens (e.g. 7-14 f/4) on IBIS body (e.g. G85 which is DUAL IS 2 compatible, GX85 which is DUAL IS compatible or GX7 which is non DUAL IS compatible but has IBIS), IBIS or nothing.
Albert
FunGuy66
You're quite right. I just simplified on the basis that all Power OIS lenses are compatible with one or the other version of Dual IS, while several (but not all) Mega OIS lenses are not. There's certainly a case to be made that it's an over-simplification.
alcelc
If you feel the IS was the problem, might switch IS OFF and shoot on tripod (basically no more stabilization issue) to see would your output been improved. If so, your finding might be related to the IS. If not, likely not IS related.
Albert
alcelc wrote:
Yes, no IS at all.
Oh well, thankfully Olympus have quite a few options if I want a zoom lens without OIS, which will allow me to use IBIS only.
IBIS only with my non-stabilized prime lenses appear to give smoother results.
