Dell Laptop Screen vs Monitor
Started 2 months ago | Questions
RinaldiB New Member • Posts: 1
Hi guys. I have a dell Inspiron 15 laptop. The screen colours are completely off, even after calibration. Apparently its just the colour display that it has to offer. I bought an external Samsung monitor. The monitor is calibrated. Now my problem is, I printed a test photo for colour testing through a professional lab. Now I see that the colour printed on the photo is leaning more towards the laptop's display (dull and just ugly), but on monitor, the photo is bright and tones are different. Monitor brightness is set at 70% and laptop at 100% as laptop's display is dark at most angles. Which display is the true display now for photo printing? Even though I got the external monitor, will the end print results always reflect the laptop's screen display?? Even though I'm using an external monitor, does it copy the laptop's settings for printing? I'm confused as I never had these problems before with any other laptops.
bmoag Senior Member • Posts: 2,856
Re: Dell Laptop Screen vs Monitor
The best solution to your problem requires a trip through the Twilight Zone of color management and monitor calibration. Also understanding that all monitors experience a degree of color drift over time. And perhaps better understanding the differences between what a print can display compared to a monitor.
Factory calibration is usually market speak for LUTs built into the monitor. The short of it is that LUTs, when used with an appropriate calibration device and software, allow "hardware" calibration of the monitor rather than the "software" calibration used with monitors that do not have LUTs. I have never seen a difference in terms of print results, but I digress.
Out of camera jpegs that have not had anything more than cropping applied should print reasonably accurately at kiosks and on-line printers, think of cell phones. If you start changing brightness/hue/saturation etc  you are likely to push RGB values out of the sRGB range regardless of the type of monitor you are using, calibrated or not.  Havoc ensues.
Raw files have a limiting color space and bit depth based on your camera settings but are not tagged with a color space until you do that in a program like PS. If you do it wrong havoc ensues.
The purpose of calibration is to translate to a color managed program the RGB values the monitor actually displays to what ideally it should display so those RGB values can be translated to what the printer can reproduce--that's how it ideally works, anyway. As a byproduct monitor colors can be corrected to a degree with calibration but monitors are rarely wildly off color. Your description suggests the laptop is a TN panel (issues with viewing angles) and so should be ignored for image processing. At a minimum when using the Samsung be sure Windows is set for the canned Samsung monitor profile (you can look up how to do that).
In any event if you want to pursue these subjects, which once understood stabilizes and improves all image processing results, I always recommend digitaldog.net. I believe the videos are now available on youtube through a link on the website.
 bmoag's gear list:bmoag's gear list
Nikon D70 Nikon D3300 Panasonic Lumix DMC-GX8 Nikon Z6
