Gitzo 1549 too old?
foskram Forum Member • Posts: 71
Gitzo 1549 too old?
I know this is very subjective. I am thinking of buying the Gitzo but am also considering a used Benro 3770tn at about 60% of the price of the Gitzo. Will be used with 100-400ii and 500mm v1. Any thoughts? Or other suggestions? Many thanks
1Dx4me
1Dx4me Forum Pro • Posts: 11,526
Re: Gitzo 1549 too old?
if it is the light CF small travel tripod, i have it and used it quite a bit. it would be fine for the 100400 II but i am not sure about 500mm v1, i'd be careful using the 500mm lens on it. however, it is a pricey tripod. i paid for it around $400-$500 for it a few years ago.
good luck.
Absence of evidence is not evidence of absence!
Rexgig0
Rexgig0 Veteran Member • Posts: 7,060
Unless a tripod uses obsolete attachment hardware, how can it be “too old?”
“500mm v1” indicates a quite heavy lens. An ultra-light travel tripod might be rated to support a specified weight, but the actual experience of using a camera/lens combination that is anywhere near that specified maximum, might be a less than satisfactory experience, as movement will take more time to settle to zero.
I lost my light-weight/travel Manfrotto 190CX carbon fiber tripod before I owned any lenses as heavy as a 500mm, but I doubt that I would be happy with that long-lost 190CX, if shooting with our current 500mm lenses, which are in the range of 3000 to 3100 grams, if I recall correctly. I would much rather use a tripod like the Manfrotto 055CX, to support this much weight.
I realize that this does not directly answer your question, but it is a frame of reference, if you can find a comparative review of lightweight carbon fiber tripods.
This being a tripod-oriented question, you might be more likely to get a range of informed replies in the Accessories Talk area of the forum.
By accident of availability, I learned to use Canon and Nikon DSLRs at the same time. I love specific lenses made by both Canon and Nikon, too much to quit either system. Since 2018, Leica-M has been my “mirror-less” system. I am, certainly, not an expert.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +56 more
OP foskram Forum Member • Posts: 71
Many thanks for your response. The last time I owned a 500mm lens I did also use a Gitzo tripod with it. My inclination is to go with Gitzo again, but I suppose I was wondering if technology had moved on and lighter tripods might be a realistic option. I have actually posted the same question in Accessories. Thank you for your thoughtful responses
