camera for photojournalist? upgrade from d3400
OP rob91 Junior Member • Posts: 32
Re: D750 is a good camera
Blufftonian wrote:
The Nikon 18-140 DX VR zoom would be fine for you.
that's not the big magnification, as a photojournalist i need to stay in a distance when situation becomes dangerous, and be able to shoot photos and  videos of objects i don't want to come close to . that's why i am looking for something like 18-300 , ( i already have 50-200 but they are slow).
does nikkor , tamron or sigma has a good lense for this, i am aware they will not be perfect. but i hope there is one which is not bad quality. in dynamic situations
i can't change my lense in dynamic situation so i need a wide range.
i would also use my nikon d3400 with fifty nifty as a backup
 rob91's gear list:rob91's gear list
Nikon D7200 Nikon D3400 Nikon AF-S Nikkor 50mm F1.8G Nikon AF-P 18-55mm F3.5-5.6G VR Nikon AF-P 70-300mm F4.5-6.3G VR
Blufftonian
Blufftonian Contributing Member • Posts: 992
Well, you've never told us exactly what kind of photojournalism you do, but if range is more important then get the Nikon 18-300 DX VR.  Of course it's heavier, larger and more expensive but that's the trade-off.
On a DX body, the 50 really isn't that useful as it's more of a short telephoto than a normal lens...well unless you need a faster lens in a low-light situation.  I assume it's an f/1.8 or f/1.4.
 Blufftonian's gear list:Blufftonian's gear list
Nikon D500 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Nikkor 10-24mm f/3-5-4.5G ED Nikon AF Nikkor 50mm f/1.4D Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR +5 more
do you recommend nikkor over sigma ?
i think sigma has also the macro option
Blufftonian
I own neither of these two 18-300mm lenses so I can't tell you which I think is better.
There is lots of info out on the web though...
https://www.dpreview.com/forums/thread/4267156
https://kenrockwell.com/nikon/18-300mm-vr.htm
https://www.pcmag.com/reviews/nikon-af-s-dx-nikkor-18-300mm-f35-63g-ed-vr
https://www.pcmag.com/reviews/sigma-18-300mm-f35-63-dc-macro-os-hsm-contemporary
Keep in mind that with non-Nikon lenses to update their firmware you'll probably need some sort of dock, not that you'll typically need to do this very often.  Also they may not be fully compatible with some Nikon features like lens distortion control and focus fine tuning.
anycolourfloyd Regular Member • Posts: 295
Sell the 55-200 And buy an AF-P DX 70-300. It's a very fast focusing and sharp lens.
Then since you are concerned with macro, buy a Raynox DCR 150 and mount it on the end of the 70-300 And boom, you have more macro than you need in a small and light package.
Having said that, nobody knows why you need macro because nobody knows what your subjects are.
 anycolourfloyd's gear list:anycolourfloyd's gear list
Nikon D500 Nikon D7500 Nikon AF-S DX Nikkor 35mm F1.8G Sigma 17-70mm F2.8-4 DC Macro OS HSM | C Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +3 more
there will not be many situatiosn in which i will need macro haha
NIKON NIKKOR AF-P DX 70-300MM F4.5-6.3 G ED
is it the one you mean? these are not expensive
Yes but you want the VR one! It's inexpensive but I don't think you find a more universally appreciated lens on this forum for performance vs cost
yeah i foudn one with vr
so i will have:
NIKON NIKKOR AF-P DX 70-300 mm f/4.5-6.3 G ED VR
Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR
Nikon AF-P DX Nikkor 18-55mm F3.5-5.6G VR (d3400 kit lense)
what about kit lense , would you recommend upgrade?
nikon has so many 70-300 that's its confusing as they have difference performance
i found this
but in this article they descrieb as more superior
Nikon 70-300mm f/4.5-6.3G DX VR AF-P
Nikon 70-300mm f/4.5-6.3G DX VR AF-P Review - Reader Comments (Page 5 of 5) (photographylife.com)
Gesture Veteran Member • Posts: 8,479
Check which cameras the AF-P lenses fit.
https://www.dslrbodies.com/lenses/lens-articles/general-nikon-lens-info/understanding-the-af-p.html
You seem to be doing fine with your talent.  I wouldn't sweat the lenses so much or add a gaggle of lenses all at once.
Enjoy the D7200.  I do think 2 card slots is valuable for a working photographer.
if i understand correctly its mostly compatible for nikkon d7200
so which one to choose:
NIKON NIKKOR AF-P DX 70-300MM F4.5-6.3 G VR
or
also it's admittedly cheap lense, so anything better for higher price in this focal lenght?
any other lesne you recommend instead of
nikon afp nikkor 18-55 vr?
or
I think they're both the same. Most important is AF-P, DX, VR.
There are more expensive lenses but they're bigger and heavier, no point going down that path unless you find the 70-300 lacking in some specific thing that you need.
The AF-P 18-55 is great. Only reason to upgrade it is if you want longer reach or wider apertures. Both of these come with a size and weight penalty.
Honestly, 18-55, 70-300 and a fast prime is a well rounded kit. Though I prefer 35mm f1.8, I'm not a fan of 50mm focal length on DX but this is just personal preference.
Blufftonian
or
As good as the 70-300 AF-P lens is, because it's a medium-to-long telephoto, I don't think you'll use it as much as you would a wide angle to medium tele.  At its widest, 70mm is the equivalent of 150mm on film or FF.  You won't be able to take shots of crowds with this.
So, put the 70-300 on your D3400 and put the (also excellent) 18-55 on the D7200.
Or consider a wide to medium with a larger range - 8-105, 18-140 - for the D7200.
do you really consider kit lens good?
and why should i put them on d7200 instead of d3400?
Blufftonian
Of course I do. Have you read any reviews of the Nikon 18-55 AF-P?  It's an excellent lens even with its plastic mount and low price.
https://kenrockwell.com/nikon/18-55mm-af-p.htm
https://photographylife.com/reviews/nikon-18-55mm-dx-vr-af-p
https://www.imaging-resource.com/lenses/nikon/18-55mm-f3.5-5.6g-dx-vr-af-p-nikkor/review/
...and more.
One of my "kit" lenses is the 16-80 that I bought along with my D500.  It is probably the finest DX lens Nikon has ever made.
Why put the 18-55 on the D7200?  Because it will have the most useful range of any lens you own and you'll want to use it on the best camera you own.  Load the camera up with the two largest SD cards you can afford, and also consider getting the MB-D15, or equivalent, grip with an extra battery.
Also remember, as a photojournalist you won't be doing fine art photography.  Just about any lens from any major manufacturer will have good enough quality for your uses.
Sactojim Veteran Member • Posts: 8,521
or
Good advice, Fact is that the preferred setup for photojournalists is a 17-55 or similar as shooting is done close at hand and not over 200mm max. Pro's use full frame too as that gets one into much lower light than a APS size sensor.
Rick Vansloneker
Rick Vansloneker Junior Member • Posts: 44
If I could make money with my pictures I definitely would want that 16-80!
okay
honestly i haven't been the fan of 18-55 , also in photojournalism i do less of portraits but more action in distance as sometimes not possible to approach a subject for security reasons
anyway your pieces of advice very helpful.
16-80 will change my life? it's a bit expensive
rob91 wrote:
okay
what's your problem with the 18-55? Not sharp enough, not long enough, not wide enough aperture?
If the problem is distance then that's fixed with the 70-300?
Blufftonian
rob91 wrote:
okay
Yes, it's actually a bit TOO expensive but when bought with a new D500 as a kit Nikon was offering $600 off. That's how I bought mine.
Many here will know that when Nikon brought out the 24-120 AF-D zoom in 1996 it instantly became a favourite of journalist who dubbed it "The Streetsweeper" because it could do anything an urban photographer might need. I still have mine but on a DX body it translates to 36-180 which is far less useful. So, in steps the 16-80, the exact same range on DX as 24-120 on FX.
On a limited budget, and wanting an all-around DX lens I'd pick an 18-140. I think you'd be using it 95% or more of the time. Yes, it's a "kit" lens but it's pretty solid with a metal mount. On an ever tighter budget I'd even consider an 18-105. Nikon made a ton of them and they were offered as a kit way back with the D90. I'm sure there's lots of used copies available quite cheaply, the quality is more than adequate for your needs, and while the plastic mount can break - mine did! - it's an easy fix.
As a journalist I'd be setting my D7200's shooting menu Image quality to JPEG normal (or even basic) and my Image size to Medium or Small as you don't need 24MP images and I'd just keep firing away!
