New 27mm f2.8 results
Started Apr 6, 2021 | User reviews
pharles
pharles Forum Member • Posts: 88
5
I bought this as a kit with the X-E4 and I'm generally happy with the lens as it is functionally improved over the old version. However, I would not use this lens for video as it appears to still retain the old AF mechanism. As a consequence it's still prone to hunting in AFC /Face Detect mode. It breathes as well, so imagine a tripod mounted X-E4 with the 27mm, a mostly static subject and the image is going: big, small, big, small, big, small . . . . . Ended up slapping an old Pentax SMC-M 28mm f3.5 on the camera and going 100% manual.
Still photography is fine if AF speed, Face Detect and AFC is not a requirement. I like the focal length and especially like the aperture ring, but the AF should have had an update as well.
Peter Charles
 pharles's gear list:pharles's gear list
Fujifilm X100V Fujifilm X-Pro3 Fujifilm X-S10 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 18-120mm F4 LM PZ WR +15 more
Fujifilm XF 27mm F2.8 R WR
Prime lens • Fujifilm X
Announced: Jan 27, 2021
pharles's score
4.0
Average community score
4.0
Schleiermacher Senior Member • Posts: 2,637
Re: New 27mm f2.8 results
If your experience is like mine, you’re probably pretty happy with the images from the Pentax M28/3.5.
Schleiermacher
www.mmathews.zenfolio.com
'At our best and most fortunate we make pictures because of what stands in front of the camera, to honor what is greater and more interesting than we are. We never accomplish this perfectly, though in return we are given something perfect -- a sense of inclusion. Our subject thus redefines us, and is part of the biography by which we want to be known.' --Robert Adams, Why People Photograph
 Schleiermacher's gear list:Schleiermacher's gear list
Pentax K-1 Fujifilm X-T20 Fujifilm X-T3 Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +12 more
Pan50 Contributing Member • Posts: 673
Can’t speak for video but I find my 27mm Fuji lens to be a lot sharper than my Super-Tak28f3.5. The 28mm is great for painterly color jpegs but for B&W and street shooting the 27mm eats it for lunch.
 Pan50's gear list:Pan50's gear list
Fujifilm X100S Fujifilm X-E1 Fujifilm X-T1 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +9 more
DarnGoodPhotos Forum Pro • Posts: 11,882
6
pharles wrote:
...Ended up slapping an old Pentax SMC-M 28mm f3.5 on the camera and going 100% manual.
Why didn't you just set your camera to MF and use the Fuji?
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
pharles
OP pharles Forum Member • Posts: 88
For the simple reason that the 27mm on MF doesn't have a distance scale. I am both the camera operator and the subject. Pretty hard to focus on oneself without a distance scale on the lens.
Peter Charles
sam2428 Forum Member • Posts: 98
Hello, do you think the mark II version of the 27mm is worth getting over the original? Is there any notable difference in autofocus speed? I like the pancake design to toss when when you want ultimate portability....and can live without the aperture ring.
The new version is also weather sealed, but if you don't care about that the original is the same.
is the autofocus performance the same between the two lenses?
My understanding is that they are identical except for the sealing and aperture ring.
forest dream Senior Member • Posts: 2,796
WR on retractable lens?
Are new 27mm F2.8 sealing rubber will break at retractable parts after many collapse/expand activity?
Why X100V did not apply WR on retractable lens like XF 27mm Mark II?
Current X100V only weather-sealed, when filter adapter and filter are used.
jhorse Veteran Member • Posts: 5,913
Hi, thanks for your review. For those who ask if the 27 Mk II is worth getting over the Mk I, here is my experience. I have just got the XE4 kit, with the 27 Mk II, and I'll write up my impressions of the XE4 in another post.
Regarding the upgraded 27, the build quality seems marginally better, but this could be because it is a new rather than an older lens. In my limited testing walking around the village, the IQ is excellent, but I can see no discernible difference between the Mk II and the Mk I in this respect. The AF seems to be the same, very accurate (the Mk I is very accurate too) , but compared to my f2 Crons, slower and noisier. The aperture ring is very nice to have and it has a good feel too. WR is nice to have, but the XE4, disappointingly, is not WR so of little added value for me.
So, if IQ and AF remain the same why did I upgrade? Simply because the XE4 kit with the lens was good value. When taking into account the trade-in values offered to me by the retailer for the the XE3 with and without the 27 Mk I versus the XE4 body or the kit with the 27 Mk II, the difference with the lens trade versus just a body trade was just £40 due to the better than expected trade-in value of the Mk I (the difference between my 27 Mk I purchase price in 2018 and trade-in was just £30!). So, I went with it.  Glad I did.
I'd suggest that unless the aperture ring is a must, the 27 Mk I is the better buy if buying solely the lens, particularly second hand.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
Re: WR on retractable lens?
Thats unknown, but external focusing WR lenses have been around for a while. Fuji's 16-55 f2.8 is a WR externally zooming lens and it seems to be fine. Heres the thing, rubber seals do dry out and break down over time so you really should get them serviced eventually.
To keep it as small as possible. Same reason hy the 27 is externally focusing instead of internally focusing.
For WR I prefer internally focusing lenses and that's what the X100V with a filter is.
IMO if X100V built-in internal focus may has same size as X100V + filter adapter + filter.
Wish future X100VI come with OIS.
It probably is.
I think OIS is more likely than IBIS.
mfoto
mfoto Contributing Member • Posts: 587
I also bought the XF 27mm f/2.8 R WR as part of the kit with the X-E4. Here is my review if anyone is interested:
Fujifilm XF 27mm f/2.8 R WR - Review
Morten Byskov
5050 Travelog
https://www.5050travelog.com/
 mfoto's gear list:mfoto's gear list
Fujifilm X-Pro1 Fujifilm X-Pro2 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +1 more
(unknown member) Senior Member • Posts: 2,057
Nice review. Have you ever moved the aperture ring by mistake? Is it quite stiff? I was delighted when I saw the lock button but dismayed when I realized it was only for auto mode. With the aperture ring being so close to the camera I am just a bit skeptical about switching in case I move the ring by mistake, which happens with some non Fuji lenses. If so I will stick with the first version, which has a terrible value now, but I would buy the awesome new hood.
JoshuaR Contributing Member • Posts: 587
The aperture ring on the new 27 is awesome, at least for me. It’s extremely clicky: moving between apertures, it’s like clickity clickity clickity. The action is stiff and decisive. I really like it!
 JoshuaR's gear list:JoshuaR's gear list
Ricoh GR IIIx Leica M10 +2 more
Thank you. Sounds perfect. Time to start shopping again 🤠
