Help needed on lens project!
Started Apr 4, 2021 | Questions
Will T
Will T Regular Member • Posts: 354
The idea is to upgrade a binocular film camera to digital.
The idea is to replace the camera with a lens mount thus making the binocular into a lens for an interchangeable lens camera.
I am looking for suggestions of what camera to use.
I have a Canon EOS M100 that I was thinking of using, am I wrong?
Do to the 1/2 frame format & film plane spacing a near APSC mirrorless system would work best.
I have a machine shop in mind to make the mount for the lens plate/ bayonet.
Please give me suggestions as to what camera/mount/brand excettera with why you think it would be best.
Here are some photos so you can visualize the application.
Thanks for your help.
Will T.
"Galleries don't hang DxO charts" David Hull
Canon EOS M100
Lemming51
Lemming51 Forum Pro • Posts: 15,261
Re: Help needed on lens project!
Fun project, though your proposed hack would hammer its collector value. I see one on ebay going for about $1000 USD.
per pics and notes on the innerwebs, the binocular lens is 165mm f/3.5. I think it'd be better on a smaller format than the M100 (1.6x "crop factor"), like a m4/3 (2x "crop factor") or even smaller like an old Nikon 1 (2.7x "crop factor").
IMHO, YMMV.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Will T
OP Will T Regular Member • Posts: 354
With testing a 1.6 crop is just the right size.
I have acquired a rear EF-M lens flange to use.
Now to do the machining required.
Will T.
Kjeld Olesen
Kjeld Olesen Veteran Member • Posts: 4,470
As said above, a very interesting project, but I suspect you will be disappointed by the optical quality of the lens, having to operate with no stop-down mechanism, and probably not designed for projecting an image to a flat surface
Good luck all the same, we will look forward to seeing the results.
 Kjeld Olesen's gear list:Kjeld Olesen's gear list
Canon EOS M Canon EOS 6D Canon EOS M5 Canon EOS R6
