Do you gel your strobes/flashes even indoors?
sirhawkeye64 Veteran Member • Posts: 6,575
So I was reviewing some images that some of the people I shoot with, have posted on social media.  In particular, ones shot with flash and noticed that a lot of them, it's pretty obvious they were shot with flash because of the color balance of flash to the skin tones.
This had me wondering, as I don't do a lot of studio photography, but mostly on location where I do gel flashes in some situations, depending on the ambient lighting.
I know people will gel flashes on location (outdoors for example) to try to match ambient light (such as sunlight, especially around the golden hour) but I'm curious how many people gel flashes indoors as well, to try to match skin color, for example, and thus eliminate that "flash" look.
(I guess to me, it's a little distracting.)
Thoughts on this?
 sirhawkeye64's gear list:sirhawkeye64's gear list
Nikon Z7 Nikon Z5 Nikon Z6 II Nikon Z7 II GoPro Hero8 Black +12 more
Colin Creevey Regular Member • Posts: 389
Re: Do you gel your strobes/flashes even indoors?
Well if you are shooting studio you normally are not mixing ambient with your flash so no gel needed (unless it is for artistic effect).  That being said, say you are doing a shoot where there is ambient then you would want to balance them.  Probably a lot easier gelling your strobe than all ambient sources.
Alternatively, use something like an LED source with adjustable temp
OP sirhawkeye64 Veteran Member • Posts: 6,575
OK I guess maybe that was a bad way of wording it.
What I really meant was geling to sort of match the skin color, so not to be racist or anything, but photographing a person perhaps with darker skin (either someone who is tan or African American for example, would you tend to use a yellow/orange gel so the flash doesn't appear so much like a flash shot (white light)?
Krav Maga
Krav Maga Veteran Member • Posts: 3,642
Thoughts on this?
Assuming we're strictly talking about studio portraiture and you've set your camera up to completely kill the ambient, gelling is not the way I would go about it.
This is a situation in which a white balance card is typically used.
It doesn't matter what color the skin is. You would simply have the subject hold up a white balance card, take a photo of it (raw is best), and then use it to set the white balance for the photos using that particular lighting set up.
Personally, for the kind of shooting I do, I don't care to get accurate skin tones. I'm just after a consistent baseline from which to begin my post production.
There are so many ways to color grade a photo of a person that I'm not sure there is a way to determine an obvious use of flash in many instances.
For example.
Is this using flash or is it purely natural light?
Flash or natural?
Flash or natural?
Regards.
Take photos that you love, and don't listen to anyone else --Peter Coulson.
https://www.danielmedley.com
Instagram: https://www.instagram.com/danlmedley/
 Krav Maga's gear list:Krav Maga's gear list
Nikon D750 Sony a7R IV Tamron SP 70-300mm F4-5.6 Di VC USD Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 50mm F1.8G +3 more
CptAmerica
CptAmerica Senior Member • Posts: 1,799
FYI, pointing out or acknowledging somebody's race or skin tone isn't racist.
 CptAmerica's gear list:CptAmerica's gear list
Nikon D850 Sigma 105mm F1.4 DG HSM Art Nikon D4 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm F1.4G +7 more
CptAmerica
I lol'd
KE_DP
KE_DP Veteran Member • Posts: 5,897
Then they did a poor job - or were deliberately looking for that effect.
Or maybe trying to create a golden hour look when it's not a match? Or just going for some other artistic angle?
For me - just no. "To match skin color" sounds really strange to me. Accurate skin tones (regardless of what color or tone) are achieved by neutral (~5600k daylight balanced) light - not adding an odd color. The point of using a reference like color checker or WhiBal card is to reproduce accurate color. Otherwise - why bother? Just stick a matching color filter on everything in post. ha ha If you were taking a photo of a blue house would you add an extra blue filter on your camera? It's redundant.
That "flash look" is often the "deer in the headlights" over usage of flash - less likely to do with the temperature than the excessive power many people use. It becomes more apparent using HSS, but at the same time that look is a genre unto itself. It really depends on the goals of the photographer and/or subject.
Maybe you meant to say - gel indoor flash to match indoor ambient (same as outdoor ambient)? That makes sense.
 KE_DP's gear list:KE_DP's gear list
Sony a7R III Sony a7R IV
(unknown member) Forum Pro • Posts: 19,317
I should but im to lazy, shooting on a white backdrop in my well lit studio does create a blue tint to the images in some areas, all i do it take the image into acr and push the blue colour slider to the negative to remove any cast.
Don
Sony A7r2 , A6300
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1 em5mk1, em5mk2, em1mk2.
rumple
rumple Senior Member • Posts: 1,725
No, never.  "warm sells" so I will generally run slightly warm in post compared to the accurate white balance, but I've never seen a need or any advantage to warming / cooling for specific skin tones.
I gel at events to partly match tungsten ambient; I want the background / ambient lights to look like an event (warm), so I don't put on a full CTO / CTS on flash, maybe half.  But never for skin tone.
"THINK" - Watson
Klaus dk
Klaus dk Veteran Member • Posts: 7,985
Here's an update on how flash can be used creatively without looking like flash.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS 7D Canon EOS R Canon EF 135mm F2.8 SF Canon EF 100mm f/2.8 Macro USM +15 more
KE_DP
Exactly - it's a good approach to start with an accurate natural looking baseline skin tone, then use post to taste.  If you start out with something way off to begin with, the old adage - garbage in, garbage out - applies IMO.
This wasn't even mentioned but also important - Hopefully one will be using a set white balance - not Auto.  I pretty much leave mine on "daylight" full time - and batch adjust in post as needed using my color/WB reference.
Suntan Veteran Member • Posts: 6,011
Like others have said, when I shoot indoors with studio lights, it is setup such that any ambient light in the room is not registering in the image. All lighting is being produced by strobes. That makes it easy to set WB and have it be uniform across the image.
That said, I do sometimes gel a light, but only to specifically add an intentional color-cast. Not because I am trying to deal with unintentional mixed lighting.
 Suntan's gear list:Suntan's gear list
Panasonic LX100 Nikon D300 Nikon D750
