Fuji X100T meets the moon...!
Started Apr 1, 2021 | Discussions
crowley213
crowley213 Senior Member • Posts: 1,177
5
A fascinating little camera, maybe my all time favorite, paired with some enthusiasm and the interest to try something different ...!
Herbert
Fuji X100T, f/5.6, 1/40, ISO 800, no crop!
 crowley213's gear list:crowley213's gear list
Fujifilm X100T Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +1 more
Fujifilm X100T
Samuraidog Senior Member • Posts: 1,672
Re: Fuji X100T meets the moon...!
I'm a bit confused. How were you able to get this closeup shot of the moon with a 23mm lens and no crop?
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
jhorse Veteran Member • Posts: 5,913
Same question...
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
No crop no prob on April 1st :)
Guess this is only possible on April 1st
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
crowley213
OP crowley213 Senior Member • Posts: 1,177
Re: No crop no prob on April 1st :)
Martin
Nope, wrong answer!
Beside the fact that the image was taken 3/31 here the link to the original raf file so you can check!
https://www.dropbox.com/sh/kmz7ch96av2rh5d/AAAf-9vjppbQPPYM8TTjpQaSa?dl=0
Herbert
skimble
skimble Veteran Member • Posts: 6,193
Martin
Nope, wrong answer!
Herbert
It does do a very good job for a 35mm I took shots of star skies I would never have thought is possible with such a camera.
 skimble's gear list:skimble's gear list
Panasonic Lumix DMC-LX3 Fujifilm FinePix X100 Canon EOS 70D
crowley213
jhorse wrote:
Same question...
The answer to this question... afocal photography!
As mentioned in my image comment, it needs only some enthusiasm and the interest to try something different.
In this case, as I don’t have my X-T3 available at this moment (repair of the front command wheel) and I will not get the necessary flattener for my telescope (for the use with a full frame camera) before the end of May, I just mounted my little X100T to the eyepiece of my telescope... and there we go.
As soon as our actual windy weather (gusts up to 40 mph) gets better I also want to try this combo with a star tracker... let’s see what it can deliver.
Herbert
texasfz8
texasfz8 Regular Member • Posts: 270
I'll guess taken through the eyepiece of a telescope?   Anyway, great shot!
 texasfz8's gear list:texasfz8's gear list
Fujifilm X-S1 Fujifilm X30 Fujifilm X-E3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm 50-230mm II +2 more
Foxjet Contributing Member • Posts: 987
crowley213 wrote:
jhorse wrote:
Same question...
Herbert
Ha! Reminds me of days gone by when shooting birds through my spotting scope with a Nikon CoolPix, we called it digiscoping. Probably some are still doing it.
What kind of adapter did you use?
 Foxjet's gear list:Foxjet's gear list
Fujifilm X-T3 Sony a7R V
crowley213
Foxjet wrote:
crowley213 wrote:
jhorse wrote:
Same question...
Herbert
Richard,
Using a Baader Hyperion eyepiece I got me also the necessary Baader adapters to mount my X100T.
It’s just a basic adapter ring for the eyepiece and then a ring with the correct filter thread diameter for the X100T. Another possibility would have been to go for the so called T-2 system, a really nice and flexible system, but there the basic adapter ring for the eyepiece is not available at this moment.
I am not sure I would like to use this type of photography for birding, but for astrophotography it is definitely still an interesting and fun option.
Herbert
Herbert
crowley213 wrote:
Foxjet wrote:
crowley213 wrote:
jhorse wrote:
Same question...
Herbert
Richard,
Herbert
Herbert
Thanks Herbert, that's very interesting information. And I agree about not using for birding, I switched to DSLR in 2005 and never looked back. I would love to see your results using a star tracker, please keep us posted.
Jazz1
Jazz1 Contributing Member • Posts: 757
I thought the OP was on the International Space station if he was only using the camera's lens
 Jazz1's gear list:Jazz1's gear list
Ricoh GR III Fujifilm X-H1 Fujifilm X-Pro3 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 50-140mm F2.8 +9 more
