G9 vs G90
Started Mar 30, 2021 | Discussions
OP judyb Regular Member • Posts: 149
Re: G9 vs G90
hi
The 12-60 lens I have is a Lumix
Is there there significant different between that & the Leica 12-60?
ty judy
Pete_W
Pete_W Senior Member • Posts: 2,841
Re: G9 vs G90
judyb wrote:
hi
I would say no. The Leica is a bit faster, i.e. f/2.8-4.0 compared to f/3.6-5.6 but otherwise the Lumix version is sharp and a good performer, lighter and shorter too.
A few other things not mentioned above (that I could see) re the difference between G9 vs G90:
Of course, none of these things may matter to you depending on how you use the camera.
I was trying out burst mode for a while as I was taking action shots so felt a bit annoyed that the RAW files were a bit lower in quality, but found that dealing with so many images in post processing was even more annoying. A better approach for me was to turn off the image review so I could just fire off a number of shots without needing burst.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
Re: G9 vs G90
judyb wrote:
hi
ty judy
The Lumix 12-60mm is a decent lens, generally thought to be one of the best kit lenses.
In the USA, if you are buying the G95 new, you can only buy it with the Lumix 12-60mm f/3.5-5.6 as part of the kit.  While the G9 you can either buy it body only or with the Panasonic-Leica 12-60mm f/2.8-4 lens bundled.
To me, that makes no sense at all.  In general, I view the G95 as the successor to the G85.  It uses the same battery, grip, etc. as the G85, so a natural market would be people upgrading.  However unless you bought the G85 really early in its release cycle, you had to buy the Panasonic 12-60mm f/3.5-5.6 lens as part of the kit.  If they had offered the G95 body only, it would make more separation between the G95 and G9 cameras.
For example, when I bought my G85 3 years ago, I could have bought it body only for something like $800, and with the 12-60mm lens as a kit for $900 (which I went for).  A few months later, Panasonic removed the body only version, and you had to buy the lens.  At $100 difference, it is more of a no-brainer than if I had to buy the lens separately ($500).
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Re: G9 vs G90
5
Hello all
I appreciate all of your responses, wide range of experience & kind manner in how it's been shared..
This has been a real eye opener. I like to take photos & use software to create different effects. I came from the Canon world (mid range) & it's been real interesting.
I've received more information just posting the question than I could have imagined.
To my surprise, I think I've been able to understand a lot of what's been posted, yet there's so much more to be learned.
As you folks have shared the more in depth technical aspects of the 4/3rd world, I've come to better understand your comments that do include the phrase "depends upon what my use would be".
The amount of knowledge/experience plus your gear (albeit GAS) has been fascinating to learn about to say the least.
A long time ago, I had photos accepted in local shows, then I stopped learning. Time to start again.
Switching to 4/3rd has led me to see there's been a whole world yet to be learned regarding what to use-when or how to use & sell & update equipment.
I have to admit, I keep vacillating between the 9 & 95. Your interesting & informative replies has helped my learning process.
& I've learned, you folks have a lot of camera gear indeed. What to use & when to use it is the question.
"To each his own" is so appropriate here. I'm glad I found DPReview & this forum.
Feel free to continue your replies.
To be continued & thank you, Judy
jonno35 Contributing Member • Posts: 884
Re: G9 vs G90
One thing I find useful on the G9 that the  G90 doesnt have is AF Peaking . G90 only has M Focus Peaking it gives you a good idea of D o F..The top info plate is more useful than I thought it would be because it allows a quick settings check without having to use VF or Monitor, mind you I would swap it for a pop up flash.Another useful setting I dont know whether the G90 has is One touch AE, very useful if you use M mode a lot.
I used to be indecisive but now I'm not so sure.
 jonno35's gear list:jonno35's gear list
Panasonic FZ1000 Panasonic Lumix DC-G9 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 14-140mm F3.5-5.6 II +3 more
Re: Easy decision for me, but maybe not for you
brentbrent wrote:
jalywol wrote:
judyb wrote:
I was hoping to find something that went into the flash mount
That way when I was out in the sun, I'd have a larger field of view rather than the smaller viewfinder.'
The lcd screen in sunlight is almost impossible to see
The G9's EVF is huge and works great, IMO. With that EVF andthe joystick for moving AF, I often shoot with the LCD closed, works fine for me.
Just get the larger accessory eyecup. They make ones for the G9, and the GX9, but I am not sure if they make one for the G90.
I have ones for all of my Panasonic bodies and they make a huge difference in EVF functionality, esp in bright sunlight.
I have the accessory eyecups for my GX7 and GX8 and like them a lot. The G9's eyecup is a different matter, though. Too wide, too curved. Photos and details here: https://www.dpreview.com/forums/thread/4261593
Thanks for the post, I'm a left eye shooter so you've saved me from buying the ex eye cup.
Marty4650
Marty4650 Forum Pro • Posts: 16,289
Roughly, $400
judyb wrote:
hi
ty judy
The Panasonic Leica version is a better lens. And it is faster and probably has a better build quality and weather sealing. And it has a nine blade aperture rather than seven. But it costs more, weighs more, and requires larger filters.
But both lenses cover the exact same focal length, and both are very good. Both have OIS and both are weather sealed. I would be happy with either one.
If you go for the G9 you might be able to find a deal on one bundled with the Leica version. This lens has a $900 list price, so you will see how much you save with the bundle. It is also bundled with the Lumix version from some vendors.
If you go for the G95, it is rarely sold "body only" and is normally bundled with the Lumix version of the 12-60mm lens. I have never seen it bundled with the Leica version since the G9 is considered a flagship and the G95 a midrange camera.
Here's what I found on Amazon:
  • G9 body $1,098 , $998
  • G9 with Lumix 12-60mm bundled $1,198
  • G9 with Lumix 12-60mm purchased separately $1,498
  • G9 with Leica 12-60mm bundled $1,598
  • G9 with Leica 12-60mm purchased separately $1,898
With the G9, it looks like the Lumix would only cost $200 more with the body, but the Leica would cost $500 or $600 more. Either option represents a big savings off the $500 and $900 list prices for those lenses. Naturally, you would be nuts to buy the body and lens separately if you wanted both.
  • G95 with Lumix 12-60mm lens $998
  • 12-60mm Lumix alone $498
  • 12-60mm Leica alone $898
Good luck with your final decision.
 Marty4650's gear list:Marty4650's gear list
Panasonic LX100 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 +16 more
Felice62 Veteran Member • Posts: 5,079
Re: G9 vs G90
judyb wrote:
hi
ty judy
I have both lenses and since you already have the lumiix i wouldn't recommend to 'upgrade' to the panaleica unless you really need the faster lens.
That said, the PL12-60 has better micro contrast and color rendition in respect to the lumix sibling.
Latter is certainly one little gem of the mft system, providing great coverage in an extremely portable form factor, that's very likeable, especially when paired with smaller camera bodies (gx80/gx9/pen series..).
It also fits well the larger bodies like the g9.
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
KenTel
KenTel Senior Member • Posts: 2,567
Re: G9 vs G90
Hi Judy, I went through this same experience myself, and the advice found put me in favour of the G9 (body only), I had at that time and still do have the ever obliging G85. So after 6 months with the G9 the G85 was being used more as I found the G9 overkill and over weight for my usage. So G9 replaced by G90 body only and now after over a year I have no regrets.
This is just my personal actions, many disagree with my reasoning, but we are all individuals and have varying levels of equipment satisfaction.
So my recommendation is if price is no problem, and you get to try both G9 and G90 and find that either would suit you. Then contrary to what some may think I would say go with the G9.
Best of Luck with your final decision. They are both good cameras.
Cheers. Ken.
 KenTel's gear list:KenTel's gear list
Fujifilm FinePix Real 3D W1 Panasonic LX100 Panasonic FZ2500 Panasonic G85 Panasonic Lumix DC-S5 +8 more
Re: G9 vs G90
So here's the latest update:
I ended up getting the G95-is super condition @ good price.
I appreciate all your replies-great learning for me.
I look forward to learning the camera-will use with 14-140
Now to get back to reducing equipment logjam-still available:
*** Edited by moderator ***
ty all-judy
KenTel
Re: G9 vs G90
OK Judy they are both good cameras, and hopefully you will find the G95 equal to your requirements, as did I. Much better for my style, my first tip which applies to most similar cameras, if on tripod you will get best results by turning stabilizing off. I have tested this myself and find it correct, especially when using video as it jitters somewhat. This is not just the G95 but most cameras using built in stabilizing. But for hand holding the stabilizing should be on.
Now enjoy your fresh tool and keep it fun.
Cheers. Ken.
Re: G9 vs G90
I appreciate your comments Ken
Now all I have to do is sell my other Lumix stuff to have space,
Stuff listed in For Sale section here
I was doing some preliminary camera looking & saw how nice n bright the eye finder is.
just might be able to take photos & leave my glasses on
ty
judy
KenTel
Re: G9 vs G90
I have trouble with my glasses, being varifocal if I happen to use view finder and glasses slide into a changed position, well you can guess the rest. It does get tiresome so mostly I either remove glasses or have to refocus the evf. Not the fault of any camera.
Just have to grin and bear it. 😎
Cheers. Ken.
Sranang Boi Senior Member • Posts: 2,860
Re: G9 vs G90
I can wear glasses when using the G90 and the FZ10002 without any issue. Just remember to adjust the diopter adjustment at the side if the EVF for image sharpness with your glasses on.
 Sranang Boi's gear list:Sranang Boi's gear list
Panasonic Lumix DC-FZ1000 II Panasonic Lumix DMC-GX8 Panasonic G90 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +1 more
Re: G9 vs G90
I have vatifocal spectacles and even with large viewfinders like the g9 or the x-t3 I need to take them off else i just can't 🙈
KenTel
Re: G9 vs G90
I have varifocal spectacles and even with large viewfinders like the g9 or the x-t3 I need to take them off else i just can't 🙈
Exactly, it is the Varifocal Glasses that cause the problem, as when I use my reading glasses and adjust the camera for them I have no problem. But can't wear them for out side use, mainly for when using PC as I am long sighted. I need an upgraded me! 😎
Cheers. Ken.
KenTel
Re: G9 vs G90
I imagine you don't use varifocal specs.
Cheers. Ken.
Re: G9 vs G90
It is a really bothersome I know...
Qadri New Member • Posts: 14
Re: G9 vs G90
Hi. Can you tell me where it can be bought for £799 including with it the things you mentioned?
kalisti
kalisti Senior Member • Posts: 1,181
Re: G9 vs G90
It was deal, over a year ago as far as I remember.
The price has since gone up a bit.
 kalisti's gear list:kalisti's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +3 more
