Minolta 200mm with 2x TC vs 500mm Reflex - Size and AF
Started 7 months ago | Discussions
Inunacho New Member • Posts: 22
Hello all, would anyone happen to have any real world comparisons between the 500 Reflex and a 2x TC 200mm?
If I'm correct the 2x would only be a F5.6 vs the 500's F8 and the AF would be better too?  How is the size between the two on an A99?
Surprisingly image quality is not the most important aspect of my project, just faster speed and size.
I'm very accustomed the the Reflex's drawbacks but would like some better AF performance.
Sony Alpha a99
Lensmate
Lensmate Veteran Member • Posts: 6,165
Re: Minolta 200mm with 2x TC vs 500mm Reflex - Size and AF
I would go with the 500mm f8.
-Martin P
 Lensmate's gear list:Lensmate's gear list
Sony Cyber-shot DSC-F717 Sony RX100 Sony RX100 VII Sony Alpha DSLR-A100 Sony SLT-A55 +11 more
James Pellenbarg Regular Member • Posts: 252
The 500 is fairly light and can be hand held. Try that with the 200 plus tc!
jim
Twah Regular Member • Posts: 108
I have a Sony 70-200 and a Sony 2.0x and the 500mm.
both good and sharp.  Learn how to shoot the 500 and it’s really a fun lens.
and like everyone said, the 500 is super light and super travelable
 Twah's gear list:Twah's gear list
Sony RX100 II Sony RX10 IV Sony a99 II Sony 500mm F8 Reflex Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +5 more
toughluck Veteran Member • Posts: 3,730
jim
The 500 reflex is 655 g while the 200/2.8 is just 790 g. With the 2xTC it weighs just 990 g. Not that much heavier.
 toughluck's gear list:toughluck's gear list
Sony a99 II Sigma 50mm F1.4 EX DG HSM Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 85mm F1.4 ZA Carl Zeiss Planar T* Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +7 more
Maxxuman Senior Member • Posts: 1,892
jim
I have - it's easy. Still weighs less with the 2xTC than a lot of lenses do.
Barry
TomV1 Regular Member • Posts: 373
I had the 500mm and liked it. The AF was fast if you were in the range, otherwise it can hunt. The DOF control is limited since it is fixed at f/8. You can only focus with Center Spot. The lighting can only be adjusted via shutter speed or ISO.
I have not used the X2, only the 1.4X (Minolta, Sony & Kenko). I thought the performance of the 1.4X was very good in terms of IQ, not much impact on AF speed with my 400mm and 600mm Minoltas. I have read some reviews of the X2 and it was determined that you are better off using a 1.4X and cropping.
 TomV1's gear list:TomV1's gear list
Sony a99 II Sony 70-400mm F4-5.6 G SSM Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) Rokinon T-S 24mm F3.5 ED AS UMC Sony 70-300mm F4.5-5.6 SSM II +11 more
sybersitizen Forum Pro • Posts: 20,998
I do. The 200 is the HS version and the 2x is an old Kenko TELEPLUS MC7.
That's right. With my A77, the 200+TC focuses faster. It also allows use of all the AF patterns while the 500 only works with the center point.
The 200+TC is noticeably larger and heavier.
There's also a significant difference in the angle of view, for both near and distant subjects, though that could vary with the specific TC.
The 500 has no visible CA. Can't say that about the 200+TC.
Those are all in-camera JPEGs, but I could process the ARWs later if that's important.
OP Inunacho New Member • Posts: 22
Thanks for that detailed comparison.  I wonder how much a difference the CA is on the Minolta branded TCs and realistically that isn't too bad given the harsh light.
Do you think you could take a picture of the two lens standing next to each other?  Just trying to get a visual on the size, thanks!
The 500 is 4 5/8 long, the 200 5 1/4 inches long. The 1.4X adds 3/4 inch.
Can't say for sure, but I assume they'd be better.
Here ya go:
The 200 is shown with its sliding hood collapsed, and the 500 is shown with its removable 'hood' removed.
If you’re gonna travel, the 500 hands down. It’s light and pretty small.   Just locked in at 500.  So just weigh how you’re gonna shoot.  Can’t go wrong either way
Yea I just stuck with my 500 Reflex after figuring out that my A7S' high ISO and LA-EA4 was more beneficial than the 200 + 2x.
Yeah I love my 70-200 g2 but man it’s heavy.  But the 500 is awesome for what it is, a compact 500 prime.
