Samsung nx lens on fuji x mount
Started Mar 26, 2021 | Discussions
MustafaYasir New Member • Posts: 4
Hi,
Is it possible to mount samsung nx lens on fuji body?
 MustafaYasir's gear list:MustafaYasir's gear list
Olympus E-M5 II Panasonic GH5 Fujifilm X-T20 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 7-14mm F4 ASPH +14 more
kypfer Contributing Member • Posts: 985
Re: Samsung nx lens on fuji x mount
You might be able to lash something up, but, unless it's a fully manual lens, you may well have no control of the focussing or aperture … all in all, probably not worth the effort!
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Lawrence Norman
Lawrence Norman Regular Member • Posts: 437
MustafaYasir wrote:
Hi,
Sorry, not possible due to Flange Focal Distance (FFD):
Samsung NX Mount FFD: 25.50 mm
Fujifilm X-mount FFD: 17.70 mm
(25.50 - 17.70 = 7.8)
Samsung lens would need to be 7.8mm inside of the Fuji-x mount.
Best Regards,
Tu Vu
“What gets us into trouble is not what we don't know. It's what we know for sure that just ain't so." -Mark Twain
 Lawrence Norman's gear list:Lawrence Norman's gear list
Samsung NX1 Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samyang 85mm F1.4 Aspherical IF +18 more
Heritage Cameras
Heritage Cameras Senior Member • Posts: 2,301
Nothing commercial, but someone has made such an adapter for manual lenses:
https://www.dpreview.com/forums/thread/4119927
Dave, HCL
 Heritage Cameras's gear list:Heritage Cameras's gear list
Canon EOS 5D Sony a7 Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100-300mm f/4.5-5.6 USM +2 more
HenrykC
HenrykC Junior Member • Posts: 42
It`s the opposite. The adapter would need to be spaced 7.8mm which is quite thin.
Lawrence Norman
Thank you, I "Thumbed Up" your correction
What got me into trouble is not what I didn't know. It's what I knew for sure that just wasn't so
Best Regards,
Tu Vu
OP MustafaYasir New Member • Posts: 4
Thanks, the problem I have many samsung nx lenses.
TuVuVu wrote:
MustafaYasir wrote:
Hi,
Best Regards,
Tu Vu
Thanks, it is clear now.
A problem many photographers have had to deal with over the years. There are only really two practical options :
1. Buy a second (and third?) Samsung camera body and hope you can still find batteries for them in the future … bear in mind that the internal "clock/calendar" battery is also likely to fail in this time frame and there's no really practical cure for that, unless you're very good at repairing compact electronics.
2. Sell all your NX lenses whilst there's still a market for them and use the cash for Fuji-fit lenses (and hope Fuji don't redesign their mount any time soon!)
Heritage Cameras
Yes, and I'm sure many Samsung NX users are in the same position and would like to be able to use their lenses on other cameras. Unfortunately there's no simple solution.
It should be possible for an enterprising manufacturer to make smart adapters for NX lenses. A project was under way to create one that worked the other way around, for Canon EF lenses on NX cameras:
https://www.dpreview.com/forums/thread/3973075
There is precedent for such unlikely-sounding adapters making it to production, such as the Monster Vectis-Sony model:
https://www.dyxum.com/dforum/lave1-monster-adapter-for-vectis-lenses-reissue_topic138733.html
It might be possible to modify NX lenses to offer mechanical focusing (and maybe diaphragm) operation. Here's an AF-to-manual modification for a Fujinon lens, which like most NX ones is usually fully electronically controlled:
https://yukosteel.wordpress.com/2019/01/12/fujinon-xf-27mm-f2-8-lens-true-manual-focus-mod/
Another option would be to re-mount the lenses (primes easier than zooms) into manual barrels, like this:
https://yukosteel.wordpress.com/2020/06/07/custom-lens-new-look-of-fujinon-xf-27mm-f2-8-manual-focus-mod/
It might even (just) be possible to cobvert NX lenses to Leica M-mount, in which case they could be used with auto focus using adapters like the Techart PRO and Megadap.
Perhaps there's a business opportunity here for someone...
Dave, HCL
