R5: Please help me get closer to 20 fps
Started Mar 25, 2021 | Questions
explummer New Member • Posts: 12
Hello, I have rented an EOS R5 with the RF 800 F/11 lens, and I'm trying to get as close to 20 fps as I can. The best I can do is around 16 fps. Based on my research, here are my current settings. If you can think of anything else I can try, please let me know.  Thanks so much!    (p.s. first time shooting Canon).
Canon RF 800 F/11 lens
  • Manual focus (physical lens switch)
  • Stabilizer off (physical lens switch)
Canon EOS R5 body
  • High Speed Continuous+ shooting mode
  • Manual shooting mode: 1/2000, F/11, 6400 ISO
  • Electronic shutter
  • Airplane mode on
  • Anti-flicker shooting Disabled
  • Recording RAW to CFexpress card (Sony tough card), and  L jpegs to SD card (ProGrade Digital UHS-II) .   I tried with SD card removed and it didn't help.
 explummer's gear list:explummer's gear list
Sony RX100 Sony RX100 II Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS +7 more
Canon EOS R5 Canon RF 800mm F11 IS STM
BirdShooter7 Veteran Member • Posts: 9,127
Re: R5: Please help me get closer to 20 fps
Try a lower ISO?  Maybe turn off any in camera NR?  How are you measuring the frame rate?
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
SSO Photography Regular Member • Posts: 173
How do you know you got 16 fps? In Mechanical, that's not possible; in Elec., you always get 20 fps unless you let go of your finger quicker than a sec.
Occams Razor Senior Member • Posts: 1,252
Are you using a fully charged battery?
Randy
 Occams Razor's gear list:Occams Razor's gear list
Canon EOS Rebel SL2 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM +4 more
srinivas_av Junior Member • Posts: 48
Have you disabled WiFi?
Tazz93
Tazz93 Veteran Member • Posts: 3,473
Potential Reasons
In my testing the battery power doesn't matter for electronic shutter. I've shot it at close to 20 fps down to 5%. Look for other items that may be slowing the process down like Dual Pixel RAW.
Also, I remember a FM thread where someone reached out to Canon and Canon suggested the San Disk CFe card was too slow and buffered the shots too soon. So the camera was really capturing at 20 fps, but the buffering and slow writing didn't timestamp it until after the one second mark. His was a San Disk 256GB CFe. They mentioned something about it should be showing 99 in the shot buffer prior to starting the burst, but his was only showing 66. Check to see if you have a 66 buffer limit too.
They suggested shooting a phone's stopwacth app to confirm the shooting speed and not the file write speed.
Mike Jackson - Wildlife Photography Enthusiast
https://www.flickr.com/photos/mj_flickr/
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
PMUK
PMUK Senior Member • Posts: 2,999
Canon EOS R5 body
  • Airplane mode on
Hi explummer,
The conditions for shooting at the maximum burst during high-speed continuous shooting can be found here - pan down for Electronic Shutter.  This was last updated in July, 2020, so there’s no mention of the RF 800 f/11.
I’m not sure where this takes you, but there you go...
Phil
OP explummer New Member • Posts: 12
Thanks all, for the replies!
To determine fps, I'm shooting my smartphone which is running an atomic clock app. The app shows an anaolog clock with a second hand that ticks the seconds rather than sweeps continuously.
Good news, I repeated my test with a few changes per your suggestions:
  • Fully charged battery
  • Lowered ISO (reduced from 6400 to 800. Which required me to change shutter speed from 1/2000 to 1/500).
  • Changed "High ISO Speed Noise Reduction" from Standard to Low (there is no "Off")
This time, I did get 20 fps. I'm not sure which of the changes were decisive. Maybe I'll play around some more to try to find out.
For those interested, here's the data from my most recent test. The columns are: clock second hand, first frame number, last frame number, and number of frames.
S.H.   F.Fr    L.Fr    #Fr
59   2417   2419      3 (ignore, partial second)
0     2420   2439     20
1     2440   2459     20
2     2460   2480     21
3    2481    2500     20
4     2501    2520    20
5     2521    2541    21
6     2542    2556    15
7     2557   2575     19
8     2576   2584      9
9    2585    2594    10
10   2595   2603      9
11    2604   2612     9
12    2613  2621      9
13    2622  2630      9
14    2631  2639      9
expro Senior Member • Posts: 2,273
It will be the combination of battery and lower iso (thus less mb)
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
