Weird sharpness issues with Panasonic 100-300
Mar 23, 2021
Hi,
I have a Panasonic Lumix G Vario 100-300 lens (the original one, not the newer mark II) that I use with a couple of Olympus bodies (E-M5 II and E-M1 III). My typical shooting scenario is:
- RAW only
- Limit the focal length to 275-280 mm to avoid the IQ degradation at 300 mm
- Holding the lens under by the hood to reduce the shaking
- Lens OIS turned on and both my cameras set to lens OIS preference if available (i.e. the body's own sensor stabilization is off)
- Using the low-speed sequential mode + electronic shutter (L-heart) or first-curtain antishock (L-diamond).
When I view the resulting sequential shots of the same scene shot at focal lengths above 200mm I always see strange artefacts that look like waves of visual distortion and floating areas of poor sharpness.
I can see how a wave of optical distortion can be caused by a microscopic movement of the OIS element inside the lens as it tries to compensate for the lens shake while the camera is in the process of reading out pixels from the sensor. But I struggle to come up with an explanation for the floating areas of poor sharpness.
I can best illustrate the latter problem with the following three crops from larger images, all taken at 275mm, 1/2000s and f/7.1. If you look at the grassy area in the center of the frames and compare it from one shot to the next you can see how different parts of it are blurry in one shot but sharper in another. (Best viewed in full screen mode at 100% resolution.)
I know this problem has nothing to do with the shimmying air currents as it appears in all shots regardless of the ambient temperature or the proximity of the subject to the ground.
Any idea what could possibly cause this strange effect?
