Re: Lens weather sealing for zooms
Chris 222 wrote:
Contrary to internet forums lore, the displaced volume of air on most zoom lenses is actually very small.
1) It depends on the lens in question.
- For Zooms like the 12-40pro I agree with you, this lens expands very little and the volume of displaced air is very small, Therefore the amount of fine dust (dust finer than what the hydrophobic filter mesh can retain) is very small, and it will take a very long time before you can see a dust coat on the inner glass surfaces. It does happen after some time though, and on that particular lens it is the lens surfaces right before and after the aperture that are first affected.
- For a Zoom like the PL 100-400, the displaced volume is quite large. This lens expands by 7.9cm. The external diameter of the expanding tube is 6.3cm. Lets assume an inner void diameter of only 5.0cm. The area is 2.5cm*2.5cm * 3.14 = 31,40cm2, over 7.9cm expansion that is 31.4cm2 * 7.9cm = 272mL. That is almost the volume of a CocaCola can. For each time the lens is zoomed the whole range from 100mm to 400mm. And that is quite often, because you transport this lens collapsed to 100mm. Assume in one day of use, you fully zoom this lens 30 times, you are pumping 8L of air through it. After 100 days of use that would be nearly one cubic meter. If that air was laden with fine dust, that will show up as fine deposit on the internal lens surfaces.
Also, this lens is open at the back. Better avoid zooming it without a WS camera attached, as you suck in unfiltered air from the rear.
2) For a tele lens like the PL 100-400, it only takes two zooming strokes to completely exchange all the air inside. If that happens to be moisture saturated warm air, like in the tropics, and you then bring the lens inside an airconditioned cool hotel room, the humidity in the air will condense onto the inner surfaces. And that can become messy, if those surfaces are already coated with some fine dust. Cause when the droplets dry, they will leave visible drying marks behind. Also, ideal conditions for fungi (spores introduced with the dust), they will thrive finding both water and food (dust)! So when coming into a cool room from a moist outdoor, better cycle the zoom action a few times to replace the moisture laden air inside. And when coming from a cold airconditioned room out into tropical conditions, let the lens warm itself up before using it.
The above means that the useful life of some external zooming lenses can be shorter, than what you can expect with internal zooms. It depends on the environment, and on how careful you use the lens. And note, some lenses like the PL 100-400 simply cannot be sent to the service center for internal cleaning, because they cannot be opened without losing alignment. If you do not like that, better choose an internal zooming lens - it will be larger and heavier though. Like the 40-150pro, this lens is sealed and does not breathe air, making it ideal for things like dusty action sports.
