Need help on Minolta RD-175
Started Mar 22, 2021 | Discussions
billyf Regular Member • Posts: 301
Hi,
I finally got one RD-175. Get all the three batteries (2CR5, CR2032 and NP-500H) and able to turn it on.
Then, work hard to format the memory card (PCMCIA adapter + 512M CF card). The shutter is able to shoot and record an image on the CF card.
I just got an .PBD image and restore it on the 512M CF card.
RD-175 needs specific way to format it otherwise it won't recognise it.
I need help on the following:
1) The .PBD image I got is for 256M CF. It means even my CF is 512M and it can only use 256M. I tried to restore the image to 256M CF card and the EaseUS todo Backup Home said my 256M CF card is not larger enough.
I want to get the Minolta software on PC and format it via the RD-175 (with SCSI connected).
Where can i download it?
2) How to convert the RD-175 RAW file (.MDC) to jpeg etc.?
Thanks a lot!
Billy F
Hong Kong
 billyf's gear list:billyf's gear list
Sony RX100 Sony RX100 IV Nikon D3 Nikon D500
Rudi Senior Member • Posts: 2,040
Re: Need help on Minolta RD-175
as far as I know the RD 175 software was availlable only for Macintosha, but
maybe you can find some help here :
http://www.epi-centre.com/reports/9605cs.html
https://www.pbase.com/cameras/minolta/dimage_rd175
https://www.dpreview.com/forums/post/62745444
Also you might try to contact Mr. Circala.
Rudi.
neilt3
neilt3 Veteran Member • Posts: 3,008
To download the drivers go to Minolta's website .
See here ; https://www.konicaminoltasupport.com/index.php?id=1083&L=2BedienungsanleitungA2%3A
Windows or mac .
Windows 2000 was the last version , but I think it runs fine on Windows XP .
You might need to set up a virtual PC if you don't have an old PC .
I keep an old one running off line to run old hardware on , scanners and cameras , that don't work on things later than XP .
You can download the manual too , should you need it .
Any problems and I'll have a go at copying an earlier version I have on the floppy disk they came with , but I'll have to find the stand alone drive I have for them .
Once you taken some pictures most software won't entertain them .
I've found that the free version of Picajet converts them just fine .
Once converted to a modern format they can be opened in any image editing programme you use .
http://www.picajet.com/en/index.php?page=features
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
OP billyf Regular Member • Posts: 301
Thanks a lot.
I ordered a used SCSI card with the SCSI connecter that matches the RD-175. it is one the way!
Once I have the SCSI card, I will try to format the memory card (PCMCIA to CF card).
Billy F
Hong Kong
Check equipment in profile
neilt3
There is a way of formatting a CF card in a standard card reader .
I've tried finding the post , but not had any luck yet .
It was on a thread on Dyxum , so it might be worth having a search on their .
