Olympus TG4 overpressurisation
Started Mar 22, 2021 | Discussions
Alan P K New Member • Posts: 1
I had my TG4 in an underwater housing that leaked and the camera stated overpressurisation on the screen prior to me turning it off. It now does not register the underwater setting at all plus turns itself on sometimes. Any ideas of how to solve this issue.
Olympus Tough TG-4
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Re: Olympus TG4 overpressurisation
Are you saying that water touched the camera? If so, there's your problem, especially if it was salt water.
Have a look at what happens:
https://www.lensrentals.com/blog/2017/10/about-getting-your-camera-wet-teardown-of-a-salty-sony-a7sii/
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Barmaglot_07 Contributing Member • Posts: 633
Not really relevant, he's using a TG-4 which is waterproof to 15 meters without a housing.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
PHXAZCRAIG
Except this camera may have seen a lot more pressure than 15 meters if it warned about over pressurization.   What happens to a TG-4 when you take it to 20 meters without a housing?
www.cjcphoto.net
A former user reports here (sorry, it's in Russian, and a kind of slang that I don't think Google Translate will handle well) that he used his TG-4 down to 25m - below that it reported 'no SD card' but recovered around 15m. Taking it to 45m resulted in a cracked display and destroyed camera.
kelpdiver Veteran Member • Posts: 5,564
this is in the realm of your mileage can vary.   Manufacturing tolerances aside, how abruptly you exceed the pressure matters as well.   If the housing was leaking from the get go, the pressure buildup would be less dynamic than if it gave at depth.   And of course a dive bomb to the lower deck is different from a gradual descent along a slope.
I took the cheapie Ikelite A35 housing slightly past its 30m (?) rating and Ike's note was the buttons may not work until you ascend.   But that was just mechanical concerns.
If the on button is self actuating at times, that points to salt water intrusion in the button.   Not good.    The inability to select water mode - don't quite understand, not knowing how that it done.   But unfortunately, the window to recover from these salt water exposures is very narrow.   At this point, unlikely anything can be done about it.
Right as it occurs, there is the rice bag routine, or where suitable, rinsing/scrubbing in 90% alcohol.   I did that when I had a bad nikonos cord connection to a strobe, and a different time when a strobe's battery compartment took on water (the batteries may have offgassed or been too hot - pushed the oring out).   If you can arrest the corrosive effects and then let it dry out, you can sometimes save it.   Potentially this could work vs the on button, though I'd suggest contacting Backscatter.
Given the price of a replacement TG-6, paying someone to repair a 4 probably doesn't make sense.
PHXAZCRAIG
I've heard one way to try to save a camera immediately after a salt water exposure is to submerge it in fresh water and let it soak.  (Preferably distilled water, but that's never available when you need it.)  The idea being that the fresh water will essentially do the same thing as a dunk tank and wick away the salt before it starts corrosion.
Then you of course have to dry it out, but at least that's conceivable.
I wonder if there are any signs of salt exposure inside the areas of the camera you can easily view, like a battery compartment?
www.cjcphoto.net
So this is the quandary you face, and the answer probably depends on the observed information.   Salt is the devil and washing it out is essential, but do you risk doing more damage with water?   As you note, you're not going to get pure water.   Rubbing alcohol will evaporate and is preferable if you can get sufficient amount.   Easy when shore diving near a drugstore, not so when off shore, and not the kind of item you can pack in your luggage for flight.
It was 13 years ago I had the YS-110 compartment flood, but that does seem to be independent of the rest of it.   I can't recall if they had alcohol or vinegar, or if I made due with water.  But I did rinse that, to get the battery corrosion out, and then toothbrush the metal contacts.   It looks ugly, but it works.   I'm going to try to sell the pair, but that one goes for a big discount.
PHXAZCRAIG
I'm not sure that's possible.
I've had that happen to the battery compartment of my AF-35 flash and a YS-D1.  Same solution.  Even saved batteries from one of them, though they were always rusted after.
www.cjcphoto.net
