Pana 45-175mm troubles
Started Mar 18, 2021 | Discussions
BG28
BG28 Contributing Member • Posts: 612
Anyone had this happen to them?
I wanted to take some telephoto shots, so I removed the 12-40 and put on the 45-175 (on an EM5-mk3). The screen was black. Nothing I did changed it. I could still see all the camera conditions around the outer portion of the screen, but no image. No aperture was detected by the camera.
And NO, I didn't have my lenscap on lol (1st thing I checked). The 12-40 and 8mm pro worked fine on the camera.
When I got home, I put the 45-175 on to my E-P5. It was completely usable on that body, so I took it off and put it back on the EM5. The image sputtered for a microsecond, but it worked and was usable and visible on the lcd. Weird. I switched the lens between bodies a few more times and everything worked.
The next day, I went to use the 45-175 on my EM5mk-3 while out and about, and guess what happened?! Blank screen, no aperture detected.
I just bought an Oly 40-150 for $99 cuz "why not", but I think I might miss the extra 25mm of reach. 8''(
I wish the Pana 45-200 was a better optical performer (at least on par with the 45-175), because that's really the basic all-around telephoto FL we need imo, especially for those of us who don't do a lot of telephoto work.
 BG28's gear list:BG28's gear list
Olympus PEN E-P5 Olympus E-M5 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro Panasonic Leica DG Summilux 15mm F1.7 ASPH +2 more
Tony Rogers Senior Member • Posts: 2,201
Re: Pana 45-175mm troubles
I suggest you try cleaning the contacts on the lens and the body because it sounds like an intermittant contact.
 Tony Rogers's gear list:Tony Rogers's gear list
Sony a1 Sony 1.4x Teleconverter (2016) Sony FE 50mm F1.8 Sony FE 85mm F1.8 Sony FE 200-600 F5.6-6.3 +1 more
pannumon Veteran Member • Posts: 4,130
If cleaning does not help, I suggest cleaning the second and the third time.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
secretworld Senior Member • Posts: 1,734
Best method is a pencil eraser gum.
 secretworld's gear list:secretworld's gear list
Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +7 more
BG28
OP BG28 Contributing Member • Posts: 612
Thanks guys! I just cleaned the contacts, thoroughly, with isopropyl. The lens works on the camera, now.
Both sets of contacts looked fine. Not dirty or in poor shape or anything, and yet a couple swipes of alcohol was enough to get them working again. I’m ashamedly amazed!
Cheers!
Ronald Contributing Member • Posts: 641
Cheers!
The 45-175mm is a great lens.
The fact that it is an internal zoom that was originally made for video is a plus
Ronald Nikon cp4500, tc-e2, canon tc-dc58n, Fuji S9000, Fuji HS20EXR, Panasonic G3
