Samsung NX mount to M4/3 mount possible?
Started Mar 15, 2021 | Questions
samuser Regular Member • Posts: 161
I have never seen or able to find a Samsung NX mount to M4/3 mount.
Anyone know if it ever get manufactured?
kypfer Contributing Member • Posts: 985
Re: Samsung NX mount to M4/3 mount possible?
Probably not!
Primarily because the Samsung lenses, like so many modern lenses, are "fly-by-wire", with an electronically-controlled aperture and indeed focusing arrangement, making them unadjustable when not on a Samsung camera.
If the lens(es) you're hoping to adapt is one of the fully manual aftermarket lenses, you might be able to make something up using a Samsung rear lens cap or lens-mount from a defunct body glued onto an M4/3 body cap, with appropriate spacers in between to get the focussing correct, else you may be able to mount your Samsung lens within something like an M42-M4/3, again with appropriate packing and/or spacing, but you'd need to check your clearances before you start.
In the case of an after-market manual lens, it may be worth contacting the manufacturer to see if they could change the mount for you, assuming the lens is/was also produced in M4/3 mount.
All in all it just may be easier and cheaper to buy a Samsung camera, if the lens is really worth using!
Good luck
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
skinwalker2009 Regular Member • Posts: 156
The image circle from a mFT lens does not match the (larger) sensorsize of APS-C - that is also why the other way around, NX-lens with a larger image circle on a mFT body, does work.
'nuf said.
Gerrit Snoek
 skinwalker2009's gear list:skinwalker2009's gear list
Fujifilm FinePix S100fs Sony Cyber-shot DSC-R1 Nikon Coolpix P7800 Samsung NX500 Panasonic Lumix DMC-GX8 +5 more
Heritage Cameras
Heritage Cameras Senior Member • Posts: 2,301
Probably not!
That's good advice, though some Samsung NX lenses can be focused manually (the 20-50mm is one, and there may be others). There's a workaround for the aperture, but you need patience and a Samsung NX body.
There's no commercial NX-MFT adapter I'm aware of, but it might be possible to make one using 3D printing, parts from extension tubes and/or other DIY techniques. There's only 6.25mm to play with, and for most lenses (such as the NX 30mm f/2 tagged in the OP's question) you'd also need to incorporate a helicoid for manual focusing.
https://www.dpreview.com/forums/thread/3063687
https://www.dpreview.com/forums/thread/4119927
https://www.dpreview.com/forums/thread/4157183
Dave, HCL
 Heritage Cameras's gear list:Heritage Cameras's gear list
Canon EOS 5D Sony a7 Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100-300mm f/4.5-5.6 USM +2 more
foot Veteran Member • Posts: 4,805
Heritage Cameras wrote:
Probably not!
You can check the flange distance of different camera mounts here:
https://en.wikipedia.org/wiki/Flange_focal_distance
 foot's gear list:foot's gear list
Sigma dp2 Quattro
