Minolta x700 P Program doesn't work
Started Mar 15, 2021 | Questions
andreww123 New Member • Posts: 1
I've noticed that when I set my MC lens to minimum aperture (f22), lock it and set program mode, each time I shot the aperture stays at f22 usually with long exposures, it doesn't automatically change even tho viewfinder says shutter speed should be a lot faster. I don't know where's the problem but it basically makes P mode unusable.
Anyone knows how to fix this ? thanks
paul_kew Senior Member • Posts: 1,857
Re: Minolta x700 P Program doesn't work
I thought you needed tu use an MD lens, not MC .
http://www.rokkorfiles.com/Lens%20History.html
 paul_kew's gear list:paul_kew's gear list
Olympus OM-D E-M10
FrancoD Forum Pro • Posts: 19,261
It is doing what it is supposed to be doing. With the MC you get manual and Aperture priority not P.
See the silver lug outside the mount at 10 o'clock ?
That is the one the MD mount will engage to get the P mode . It isn't there in the MC version. (the MC uses the one at 11 o'clock)
neilt3
neilt3 Veteran Member • Posts: 3,008
The above two answers are correct .
That's why the MD lenses were released .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
