Hood for Olympus 75mm 1.8
Started Mar 11, 2021 | Discussions
Interceptor121 Veteran Member • Posts: 8,691
In addition to the Olympus OEM hood are there any other compatible hoods that are recommended?
I never use UV filter but all my lenses have hood and none comes in the box
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Danielvr Veteran Member • Posts: 6,863
Re: Hood for Olympus 75mm 1.8
You may well find your answer in one of the previous discussions on this subject:
https://www.dpreview.com/search/forums?query=75mm%20hood&forum=1041&sort=from-oldest&only-threads=yes&only-titles=yes
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
Coldpaw Contributing Member • Posts: 772
5
I bought the much cheaper copy of the original hood made by JJC and can't complain, full metal construction, it holds on tight on the lens. The inner area is covered with cloth, which is a slight bummer because it attracts quite a bit of dust and is annoying to keep clean. Other than that however, I am satisfied with the cheaper copy.
OP Interceptor121 Veteran Member • Posts: 8,691
Thank you. This looks a great suggestion and it is available in UK. Most of the threads are US based and I can't find any of the options!
WileEC_ID
WileEC_ID Senior Member • Posts: 1,749
I was looking for something, too - and found three options for 58mm threaded hood - two metal, one shorter, one longer, and one rubber - the rubber hoods can be nice as they protect - and take bumps while transferring none of the jarring from the bump to the lens. All three options I found on Amazon US. The two metal hoods would accept lens caps - but not the same size, nor the stock lens cap.
This shows the three options mentioned above.
The two metal hoods have no cloth inside - just matte grooved metal.
Please harshly criticize my images - it helps me better at this photography thingy.
 WileEC_ID's gear list:WileEC_ID's gear list
Olympus OM-D E-M1X Olympus E-M1 III Nikon Z6 II OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +13 more
mikero
mikero Veteran Member • Posts: 3,057
I too bought a JJC hood.  I've not actually handled the genuine Olympus version, but I don't see how it could be any better than the JJC copy.
Mike
 mikero's gear list:mikero's gear list
Olympus E-M1 II OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
dave rogers Contributing Member • Posts: 774
I have the Vello LHO-LH61F. It has the fuzzy lining as well, but seems well made and approximates the finish of the silver lens. It can get marred/scratched, but it's a hood and I don't care. Reverses on the lens, so it can afford some protection while the lens is stored.
The finish is more of a champagne color than the lens; but again, I don't care. Some people do.
Here's a link to B&H for a description .
 dave rogers's gear list:dave rogers's gear list
OM-1
I would prefer one that does not screw on the lens if that makes sense and has a bayonet type or screw type. Am not actually sure you can fit a bayonet on the lens to be honest
WileEC_ID
I can appreciate that - it looks like the $60 stock hood uses a screw into the side of the lens. The options I considered use the front filter threads. Might be other options - be interesting to see what others suggest.
I observe this option. which seems to slide on, held by friction - on Amazon US:
KUVRD - Universal Lens Hood - Fits 99% of Lenses, Holds 99% of Circular Filters, Fits 54mm-76mm, Single - (Small)
mikero
There is no bayonet fitting on the lens.  You either have one that clamps on the lens barrel, or one that uses the filter thread.
Mike
So the screw on the side is really the only option
Skeeterbytes Forum Pro • Posts: 23,186
Mike
Another JJC satisfied user - it's nicely made, metal, and mimics the OEM's odd friction screw attachment versus the more typical bayonet. Very deep and does a fine job keeping sun off the front element.
Rick
Jon Schick Veteran Member • Posts: 5,163
Another satisfied customer; the JJC hood  is excellent.
 Jon Schick's gear list:Jon Schick's gear list
Olympus E-M5 III Panasonic Lumix DC-S5 OM-1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +13 more
Prairie Pal Senior Member • Posts: 2,912
I played around with a few flexable rubber hoods until i found one fairly deep. I removed the threads from it and it stretches snugly over the barrel and stays put. It even doubles back on itself to make a cushioned shock absorber when not needed as a shade. Previous to that i was using an aftermarket hood from the oly  40- 150mm F4.0-5.6 R Zoom, shimmed with black duct tape to create a friction fit..  Yes I'm a miser.
Ivan
 Prairie Pal's gear list:Prairie Pal's gear list
Nikon D600 Nikon D7200 Olympus OM-D E-M10 II Olympus E-M1 III Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
Yes, at least if you don't want to use the filter thread. As I said I have the JJC copy of the hood since a few years now and can't complain, there are no scratches on the barrel and the hood attaches as tight as possible. When I change lenses, I always grab the 75mm by the hood and rotate it to either remove or attach the lens to the camera, the hood stays on and doesn't even move the slightest bit.
As for the lenst cap, I replaced the default Olympus one with a cheap, generic center-pinch cap you can find  pretty much everywhere.
RedDog Steve
RedDog Steve Senior Member • Posts: 1,972
JJC Hood for Olympus 75mm 1.8
I bought my 75mm used and it came with the JJC hood. I normally avoid third party accessories when possible, but in this case the hood is decent quality and nicely matches the lens.
I like that the hood is reversable but rarely use that mode for storage, I prefer to just leave it in place. The lens itself isn't all that large to begin with and not much bigger with the hood.
I quite often store the lens face down with the hood in place without a lenscap in a divided Domke or Tamrac case. I've not noticed any objectionable dust accumulation on the front element, even though there might be a bit on the inner surface of the hood. Maybe that's as intended ?
I'm not a perfectionist, I'm a precisionist.
rd
 RedDog Steve's gear list:RedDog Steve's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Panasonic Lumix G Leica DG Summilux 12mm F1.4 ASPH Panasonic 8-18mm F2.8-4 +17 more
Re: JJC Hood for Olympus 75mm 1.8
I was actually talking about the soft, inner fabric of the hood itself rather than the actual front element el the lens.
It's not hat bad though and maybe I brought up a con which isn't really problem, to my knowledge, the genuine Olympus version also has some fabric material on the inside. I'd buy the JJC again without second thoughts if I'd ever lost it, simply a good quality product at a reasonable price.
