histogram
Started Mar 9, 2021 | Questions
ericka287 Regular Member • Posts: 102
histogram
I can't display histogram in shooting mode on M6ii. Reset all menu items and reselected desired items. Still no display of shooting histogram on camera screen. Histogram is displayed in menus but not on camera screen. Someone please help how to fix this. No problem on M3; M6ii ???  Thank you for your help.
 ericka287's gear list:ericka287's gear list
Canon PowerShot G12 Canon PowerShot G1 X Canon EOS M3 Canon EOS M6 II Canon EF-S 60mm f/2.8 Macro USM +8 more
Canon EOS M3
noisebeam Senior Member • Posts: 2,963
Re: histogram
Turn Exposure Simulation (back) on.
 noisebeam's gear list:noisebeam's gear list
Sony RX100 II Canon EOS 30D Canon EF 100mm f/2.8 Macro USM Sigma 15mm F2.8 EX DG Diagonal Fisheye Sigma 30mm F1.4 EX DC HSM +8 more
OP ericka287 Regular Member • Posts: 102
Re: histogram
Thank you I would have never discovered this. All is good.
geru Senior Member • Posts: 1,409
Re: histogram
Blue tab #4 top item play back mode I have items 1&4 checked. Press image review and you will see Histogram, press info and you get full screen view . Depending on how long you’ve set to review your photo the screen will default to a live histogram that can be used to establish exposure. This is the method I use to set exposure.
 geru's gear list:geru's gear list
Canon EF 85mm F1.8 USM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS M50 Canon EOS M6 II Canon EF 40mm f/2.8 STM +5 more
verino55 New Member • Posts: 2
Re: histogram
If you're still looking for a solution to this issue, I think I found it.  I was having the same issue with my M6 MkII.  I had the camera in servo mode.  Once I switched to one shot, the histogram became available.  Interestingly, the histogram remains available when the camera is in face detect with tracking mode, which behaves much the same as servo.
 verino55's gear list:verino55's gear list
Canon EOS M6 II
