Sony e-mount lenses to Samsung Nx bodies... Kamlan 50mm F1.1 APS-C
Started Mar 8, 2021 | Discussions
freedom21
freedom21 Forum Member • Posts: 81
Hi guys
Is there any way to adapt this lens to the NX mount? MAybe through two adapters? like a sony e-mount  adapter to a-mount, and then to a-mount to nx.. does it exists?
kamlan-50mm-f1-1
https://www.ultraonlinept.com/kamlan-50mm-f1-1-olympus-panasonic-m43-mount-4.html?gclid=CjwKCAiAkJKCBhAyEiwAKQBCkn1S7WHb0cVbgh5bE-3a-BSbplTT_dyU2lxlQdyH7Q8QlbS-QZh6XhoCtt4QAvD_BwE
It is so cheap and pwerfull...
Thanks a lot
“The truth will set you free, but first it will p* you off.” - Flip21
kypfer Contributing Member • Posts: 985
Re: Sony e-mount lenses to Samsung Nx bodies... Kamlan 50mm F1.1 APS-C
freedom21 wrote:
Hi guys
kamlan-50mm-f1-1
Thanks a lot
Can't practically be done … e-mount has a flange distance of 18mm, NX flange is 25.5mm. Unless you introduce some extra glass to compensate for the differences you'll end up with a lens that only focusses at close range. Probably cheaper and easier to buy a second-hand Sony e-mount camera!
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
markyboy81 Veteran Member • Posts: 4,778
Flip...you not satisfied with the NX lenses? What are you missing?
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
freedom21
OP freedom21 Forum Member • Posts: 81
the pleasures of manual focus cheap vintage lenses...
Marky wrote: "Flip... sorry, Freedom...you not satisfied with the NX lenses? What are you missing?"
I'm just looking for an excuse to spend money LOLOLOL And also to distract myself, now that we are "locked at home", and forbidden to work, due to this communistvirus....
Now seriously, I always loved bokeh. The 85 is great, but you have to be so fare away from the subject
On the other end, I just discover the hidden pleasures of the manual focus lenses. I'm also into vintage lenses, but compact ones... I mean, the focus ring, and the aperture ring on vintages lenses are so easy to use... And also, looking for good bargains lenses, and this Kamlan is a bargain. I never tried a lens with such a wide aperture...
Re: the pleasures of manual focus cheap vintage lenses...
Have you tried extension tubes or even a close-up lens with your 85?
freedom21
hmmm, no never, and I have extension tubes... I thought they would be used only for macros shots... Well we are alwyas learning Can you explain how to use them?
I'm such a newbe If it wasn't for you guys... God Bless you all
"The 85 is great, but you have to be so fare away from the subject"
With extension tube(s) fitted you can get much closer to your subject at minimum focus … try it
freedom21
Thanks Can you explain me how it works, I mean, I tried with the 45mm, and I can focus only macro shots... I have the 10mm, and the 16mm... Now I have to be super close...
Try it with the 85 … that's what my comments referred to … with a shorter focal-length lens the effect of the tubes is very much greater, so you will only have macro capability.
freedom21
I've tryed with the 85mm, but still I have to be very near the subject to focus it... I wanted to do portraits, but closer to the subject, but not as close LOL
Right, gotcha!
In that case you do need a shorter focal length lens and a 50mm would probably be just about right on an APS-C camera. Doubt that you need to go as extreme as an f/1.1, you could end up with the eyes in focus and the nose and ears blurred! Something like an old screw-mount f/1.8  Pentacon or f/2 Helios-44M on a suitable adaptor would probably serve your purposes … and cost somewhat less
shutterbugnx
shutterbugnx Regular Member • Posts: 168
There was a manual adapter for NX Mini available. Currently out of stock. https://www.ebay.com/itm/174537163839
 shutterbugnx's gear list:shutterbugnx's gear list
Panasonic Lumix DMC-ZS60 Olympus PEN E-PM1 Sony Alpha NEX-7 Samsung NX2000 Fujifilm X-M1 +46 more
freedom21
Uau Thanks a lot my friend... now I definitely have to buy the NX mini
