Micro 4/3 lenses on Samsung bodies - does it work?
Started Mar 5, 2021 | Discussions
freedom21
freedom21 Forum Member • Posts: 81
Hi,
Can I adapt micro 4/3 lenses on Samsung bodies, through an adapter such as this one?
https://www.ebay.co.uk/itm/Adapter-passt-zu-4-3-Standard-FT-Objektiv-an-Samsung-NX-Anschluss-Kamera/263207500358
Is there any drawbacks?
Is M4/3 the same as 4/3?
I was trying to adapt a TTartisan lens, micro 4/3 to an NX camera...
This one:
https://www.youtube.com/watch?v=Hnef-bKz9yU&ab_channel=chungdha
“The truth will set you free, but first it will p* you off.” - Flip21
kypfer Contributing Member • Posts: 985
Re: Micro 4/3 lenses on Samsung bodies - does it work?
freedom21 wrote:
Hi,
This one:
No!
4/3 and Micro 4/3 have different mounts and different registration distances. The "four-thirds" part of the name refers to the sensor in the cameras, not the mechanical mount.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
freedom21
OP freedom21 Forum Member • Posts: 81
No, they don't work? But they do exist, right. I bought this one. Should I cancel my order?
https://www.ebay.co.uk/itm/M42-NX-M42-Thread-Lens-to-NX-Mount-Camera-Lens-Adapter-Ring-for-Samsung/293678884871?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
i want to adapt micro 4/3 lenses on Samsung NX bodies...
Heritage Cameras
Heritage Cameras Senior Member • Posts: 2,301
That adapter is for using M42 screw lenses from older film SLR cameras such as Pentax and Praktica. It won't work with Micro Four Thirds lenses, and there is no suitable adapter as far as I'm aware.
Many other fittings are adaptable to Samsung NX, but not any mirrorless types (like the one you linked to), or Leica M. You can get adapters for some Leica Screw (often called LTM or M39) and most lenses for manual focus film SLRs, though.
Dave, HCL
 Heritage Cameras's gear list:Heritage Cameras's gear list
Canon EOS 5D Sony a7 Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100-300mm f/4.5-5.6 USM +2 more
freedom21
Oh man.... I already order it... I though m4/3 was the same as m42..... oh man, ebay listed, and didn't even realize it was a 2, instead of a 3
I thought it was this adapter here, but for the Nx1... https://www.youtube.com/watch?v=a1xbphZFCio&t=244s&ab_channel=FotodioxInc
Now I have to sell it to Kisaha... Do you think he will fall for it? He was a great friend of my cousin, Flip21... he put even flip21 in his prestigious ignoring list...
LOLOLO
skinwalker2009 Regular Member • Posts: 156
It would perhaps work IF you could find a suitable adapter but lenses for micro4/3 have a smaller image circle (sensor surface area 225m2) than those for APS-C (sensor surface area 329 mm2). The resulting image would look somewhat like severe vignetting.
See here : https://www.google.com/url?sa=t&source=web&rct=j&url=http://photoseek.com/2013/compare-digital-camera-sensor-sizes-full-frame-35mm-aps-c-micro-four-thirds-1-inch-type/&ved=2ahUKEwjZr4H9hqHvAhWByoUKHfAxBV0QFjACegQIAhAF&usg=AOvVaw1Q5kKDClCREgSwyruDaUfk
The absence of any suitable adapters is sort of a giveaway......
Gerrit Snoek
 skinwalker2009's gear list:skinwalker2009's gear list
Fujifilm FinePix S100fs Sony Cyber-shot DSC-R1 Nikon Coolpix P7800 Samsung NX500 Panasonic Lumix DMC-GX8 +5 more
