Is OMDS on the verge of announcing the TG-7?
Started Mar 5, 2021 | Discussions
smithaa02 Regular Member • Posts: 252
Relatively recently it was leaked that OMDS registered a new camera in Russia (IM024). This fits the profile of a Tough camera (not a M43 camera) and would be similar TG-6 Russia registration that happened two years ago:
https://www.43rumors.com/olympus-registered-a-new-camera-in-russia/
Last week during the C+ show, OMDS explicitly said they would be continuing to develop new Tough models:
https://www.digitalcameraworld.com/news/olympus-pen-and-tough-will-continue-olympus-name-will-be-kept-until-fans-are-satisfied?fbclid=IwAR1QrDd_sntqZmUsU5Id_WLE0LIo7uyUUDdXpvcH1O4fCBIbgl4UBCSUYYY
And just recently, there is a rumor from 43rumors.com that OMDS will be announcing their first product on March 17th.
https://www.43rumors.com/ft3-will-omd-digital-announce-its-first-product-on-march-17th/
IMO this points to a TG-7 spring announcement and early summer release. Olympus in the past has preferred two year release cycles for the tough series and the TG-7 would be right on schedule (although maybe released a month sooner given the timeline of similar clues for the TG-6).
If true, what do you expect to see in a TG-7? What do you want to see?
I'm not sure we'll see much given that Olympus kind of gutted their R&D department. But...historically odd model tough cameras come out with the big feature changes while even number releases tend to be more passive.
I would love to see:
  • A more modern sensor
  • Change of resolution: 12 MP > 16 MP
  • 4k 60 FPS
  • TruePic IX (which might finally get us 4k 60 FPS)
  • More zoom (won't happen)
  • A final elimination of the purple orb
  • Better tools to reduce camera movement when pressing the shutter button (eg a quarter second delay option)
  • TG-6 video stabilization is bad...would love to FINALLY see sensor stabilization used for video (they use it for images already)
  • Add a GPS navigation map (very handy when kayaking)
I can practically guarantee we won't see a larger sensor size (which would mess with zoom and the internal optics that Olympus took years to calibrate).
Thoughts?
John McCormack
John McCormack Veteran Member • Posts: 7,098
Re: Is OMDS on the verge of announcing the TG-7?
Your guesses seem plausible. I'd like a 1 inch sensor even if the zoom is shorter but I doubt it will happen.
"A photograph is the pause button of life." Bjorn Moerman.
Yannis1976
Yannis1976 Veteran Member • Posts: 6,307
  • 4k 60 FPS
Thoughts?
Maybe I am wrong and don't understand the market, but I think the tough series is still one of the few areas a P&S could differentiate in a mobile phones era.As improvements I would look into:
- either a 1" 20mp sensor or at least a better 16MP 1/2.3 sensor. I am also using the Nikon P950 and its 16MP sensor is indeed better with noticeable higher DR and better noise at high ISO
- introduce a proper PASM mode (very easy to add and important!!!)
- introduce an accessory lens which would allow split photos (pleaseee)
- maybe change the lens to much wider so that FL UW would start at 24mm
Olympus TG series with all its accessories is still a very impressive package if people know how to use it. Despite its tiny sensor, the TG6 can take photos that many larger sensor ILC systems cannot do unless you use very specialized equipment:
I have never managed to reach this kind of macro with my m43 or Fuji setup yet. The combination of small sensor DOF and macro LED ring of Olympus can compete many larger sensor cameras.
And in terms of UW photography, the resolution might be small, but there other things that make this camera a great tool, such as very small size and wide lens extenders that bring the FL to 24mm:
Lets hope OMDS will have the same view and invest in the TG range. TG6 was very good, but almost the same as TG5!! They need to finally make some substantial improvements.
 Yannis1976's gear list:Yannis1976's gear list
Fujifilm XF 35mm F1.4 R Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Stefan Sobol Regular Member • Posts: 307
On the other hand regarding a possible TG-7, if it ain't broke, don't fix it.
OP smithaa02 Regular Member • Posts: 252
For anybody curious, the OMDS announcement next week was for a voice recorder.  Hopefully the TG-7 is still in the works and on the verge of being released.
Yannis1976
Sure, but some would be only small improvements such as full PASM mode or a sensors change from 12MP to the same size one from Nikon P950 (16MP).
A bigger sensor or new lens would be quite big though.
Rumors are heating up again over the TG-7. The IM024 (which was previously registered in Russia) has now been registered in China. This might not be the TG-7...but then again it might be.
Robin Wong (who had had exclusive preview of the TG-6 prior to its release) hinted that OMDS was releasing a product soon. On Twitter, OMDS hinted some type of announcement on Friday (although it might be a joint talk with Panasonic).
The "photography vlogger" claims the TG-7 will be released and posted specs. I don't know if I trust them...but what was posted was curious:
https://www.youtube.com/watch?v=N-RI66r5sHM
  • Same sensor size and mp (but new sensor)
  • 1.8 aperture (this is a noticeable improvement over the TG-6's 2.0)
  • 25-100mm eq focal length (like before)...but also 6x zoom (new)...these seems like a mistake unless OMDS is subdividing their zoom differently?
  • Looks like for video a possible 4k60p spec which would be a big improvement over the 4k30p spec
  • Retail $499
  • Release date April/May
TG-7 rumors are starting to heat up again.
https://www.digitec.ch/de/page/olympus-bei-unserer-entwicklung-wird-nicht-gespart-19584
https://translate.google.com/translate?hl=en&sl=de&u=https://www.digitec.ch/de/page/olympus-bei-unserer-entwicklung-wird-nicht-gespart-19584&prev=search&pto=aue
This is yet another confirmation from OMDS that there will be a TG-7.
Do you have a camera planned for this year?
We don't actually announce that in advance. But yes: A new camera will be available in the next few weeks and it won't be the last one this financial year. Unfortunately, I can't reveal more yet.
What about the waterproof and shockproof Tough compact cameras? Will they continue to be looked after?
Most competitors in this area have dropped out over the years. We are continuing the line and at some point will also present a successor to the current model, the TG-6. TG-6 . However, one thing is clear: the greatest innovative strength will flow into more professional cameras.
This new camera has to be the TG-7...I just haven't seen enough rumors to believe that a M43 camera is on the horizon instead.
IMO we should get a TG-7 announcement in early May...
John McCormack
Sorry if this has already been posted.
Here's a quote from OMDS :  “What about the waterproof and shockproof Tough compact cameras? Will they continue to be looked after?
Most competitors in this area have dropped out over the years. We are continuing the line and at some point will also present a successor to the current model, the TG-6. TG-6 . However, one thing is clear: the greatest innovative strength will flow into more professional cameras.”
"A good photograph is knowing where to stand." - Ansel Adams
Some more possible details about the TG-7...that same Youtube channel which made the previous announcement (https://www.youtube.com/watch?v=N-RI66r5sHM) in the comments made a curious remark about contradicting specs they received.
One spec listed the zoom at 25-100mm (1-4x zoom like the TG-6), while another listed it at 25-200 (twice the zoom...a big improvement).  The new 200mm zoom would explain the odd rumored zoom change to 6x from 4x...if the TG-7 were to retain 100mm, a change from 4x to 6x would be silly and just a marketing gimmick.
If the rumors about the new 200mm max zoom is true, this would have a number of pro's and con's:
Pros:
  • This may be a sign that OMDS completely rengineered the internal optics, which could mean the blue orb will be gone for good
  • Current image and video stabilization aren't good at 100mm...we could be looking at (hopefully) an improvement in either to be able to work with 200mm.
  • 200mm would compete well against smartphones.
  • 200mm would make some types of wildlife shooting finally practical...100mm (especially when kayaking) usually is just not sufficient for many decent wildlife shots.
Cons:
  • Lens quality could get worse with 200mm zoom.  100mm already on the TG-6 was soft...I'm not sure how they could pull off a sharp 200mm...
  • The form factor may need to change and a small snout may be required.  This could break all the previous TG Accessories.  I don't think OMDS will do this though...so we could be looking at 200mm with just internal optics which seems like a stretch.
PentaxNick Senior Member • Posts: 1,830
6x would make the long end 150mm, which would be more realistic without a major body redesign.
Pros:
Cons:
A few thoughts:
  • While I would like a better sensor, using a much larger one would compromise the macro ability.
  • A much larger sensor would also require a body redesign so requiring new add-ons.
  • I’d like to see a proper aperture mechanism rather than the 2 aperture system, but I don’t know how well it would work with the current sensor size.
  • Perhaps a 1/1.7” sensor would be a good compromise, although I don’t know if anyone makes a modern sensor in that size.
Nick
 PentaxNick's gear list:PentaxNick's gear list
Ricoh GR Fujifilm X100T Olympus Tough TG-4 Ricoh GR III Olympus PEN-F +12 more
The TG-6 just dropped 70 dollars in price on Amazon. It's also unavailable at some retailers like Best Buy. This could be a sign that a TG-7 release is soon to come.
https://camelcamelcamel.com/product/B07RC8HPHL?context=search
A price drop of the TG-5 did precede the release of the TG-6 so this has happened before.
Vigalphoto New Member • Posts: 8
I have a Full Frame reflex and sooner than later I will buy a Full Frame mirrorless. Of course I'm not going to do whitewater canoeing or going into the sea with that camera hanging around my neck. For that occasions I have a TG-5. I´m pretty happy with the camera but I would like better IQ and real manual mode. I shoot raw and when I see all that noise even at ISO 100 I feel disgusted.
If Nikon released an updated version of their Nikon 1 AW1 I will buy it. Or, let me dream, an m4/3 though camera. But I don't think either of the two things will happen.
IMO the only future for cameras with sensors smaller than FF (or perhaps APSC) but larger than smartphone sensors are to be though-adventure hybrid photo-video cameras.
Captive18 Contributing Member • Posts: 942
Was just about to buy a refurbished TG-6 for $288, until I saw this thread. I’d be interested to see what OMDS churns out. Hopefully, it’s before the 31st. That’s when my discount code expires.
 Captive18's gear list:Captive18's gear list
Olympus TG-6 Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +6 more
I don't think it will be available by the 31st.  I think we'll get announcement in early/mid-June with a July release.
It turns out the IM024 was the Pen EP7...not the TG-7. That's bad news. The good news is OMDS did reveal a IM028 is in the works...maybe this is the TG-7?
https://www.43rumors.com/om-digital-registered-a-new-camera-model/
If so, I doubt this is out before August.
Ricoh just released their WG-7 today which is a direct competitor to the Tough series...now would be a good time for OMDS to announce a new Tough camera to stay competitive.
https://petapixel.com/2021/06/17/ricoh-launches-the-wg-7-a-rugged-waterproof-20mp-camera/
