Choosing an X100
Started Mar 5, 2021 | Discussions
shadowplay84 Forum Member • Posts: 73
Choosing an X100
I'm going minimal with Fuji and I would like to rationalize my kit and Buy an x100 for street.
Should I get the new x100V or even an x100F or x100T are still good in 2021? Which one would you suggest?
 shadowplay84's gear list:shadowplay84's gear list
Fujifilm X100V Fujifilm X-T3 Fujifilm X-E4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +8 more
Fujifilm FinePix X100 Fujifilm X100F Fujifilm X100T
Kev the Jack Forum Member • Posts: 56
Re: Choosing an X100
The newer version has slightly more megapixels and more up to date jpeg profiles. if this is important to you - go for this. it'll cost a premium though.  Otherwise the 100f will do the job.
The only other game changer will depend on how you shoot - do you shoot "from the hip"? if so the 100v's tilt screen will add to your usability.
 Kev the Jack's gear list:Kev the Jack's gear list
Fujifilm X100V Fujifilm X-T3 Fujifilm X-Pro3
Ringwraith69
Ringwraith69 Veteran Member • Posts: 3,407
I don't think any version of the X100 would really be a bad buy. I still have the original 'Mk I' version and use it regularly with great pleasure. If you can afford it and don't mind paying premium $ (or any other currency  ) I'd go for the latest incarnation of this classic camera concept. If you want to shop more cost conscious, just have a look around at reviews etc. and figure out which older versions would fill your needs. Could save you quite a bit and you could still end up with a camera you'll never want to let go again...
(We are only immortal for a limited time)
 Ringwraith69's gear list:Ringwraith69's gear list
Sigma DP1 Fujifilm FinePix X100 Fujifilm X-S1 Sony RX10 II Sony RX10 IV +42 more
DarnGoodPhotos Forum Pro • Posts: 11,881
The T, F, and V all had solid improvements over the models they succeeded. I suggest you read DPR’s reviews for each of them because those will let you know the relative improvements of the F and V .The T is still good assuming you don't have fast AF needs otherwise I would stick with the F or V, both of which had fast enough AF.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
sprouty115
sprouty115 Contributing Member • Posts: 618
I just replaced my Ricoh GRiii (stolen) with an X100V. It was more of an impulse buy than a thoughtful consideration of which model.
And while I do confess to missing that little black box, the X100 series are really quite nice and the newest lens seems to be on par with other modern designs.
So that, plus the improved focus, weather sealing, and flippy screen would make me opt for the latest version.
But you should also be honest about your budget. Because there is quite a bit of difference in price between the models and you shouldn't be stressed over a fun purchase.
 sprouty115's gear list:sprouty115's gear list
Ricoh GR III
d2mini Senior Member • Posts: 1,359
Unless you just can't afford the V, its the only one that makes sense if you don't currently have the F. So much has improved in the V. Better lens, water resistant, 4-stop ND filter, newer sensor, flippy screen, improved viewfinder, faster continuous shooting, 4k video, and a few other minor improvements.
Fuji X-T3 | Fuji X-100v | Ricoh GRIII
 d2mini's gear list:d2mini's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 56mm F1.2 R Fujifilm XF 16mm F1.4 R WR +2 more
biza43 Forum Pro • Posts: 15,074
The X100V is the more mature of the series.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
bastibe
bastibe Senior Member • Posts: 1,236
The older ones are still good, though. If you find the V too expensive, an S or T can be great value, used. Or even the original.
Personally, I draw the line at USB charging. That's a feature I want. So that's a T.
Maybe you have some other feature you can't live without, and can choose accordingly.
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
