Fun with the new Venus Laowa EF-M 65mm 2x Macro
Started Mar 5, 2021 | Discussions
R2D2 Forum Pro • Posts: 26,528
43
After reading some really rave reviews about the Laowa 100mm 2x Macro (available in multiple FF mounts), I thought I'd give it's little EF-M brother a try. And little it is. It's smaller in diameter than most other EF-M lenses, and it's a little bit longer (and slightly heavier) than the EF-M 18-150. IOW a lot less of a handful than my standard macro lens, the EF 100L.
Shooting macros with this lens is a breeze. The small diameter makes it very grip-able, and the heft is perfect to give it a little stability.
This is a fully manual lens, so focus is best done by pre-adjusting the focus ring (basically to a desired composition), and then moving the camera to and fro until your subject is in focus. Aperture is also adjusted manually using a ring on the lens. There are no electrical contacts on the lens, so no EXIF either.
A 2:1 macro ratio is about the highest I'm comfortable with hand-holding, esp without image stabilization to assist. And Canon's Focus Peaking really works well for macros.
Since it's still winter outside around here, I took my new toy down into the shop and grabbed a few things to practice on. All of these were shot at 2:1 (an object 11mm wide fills the frame), and aperture was set to f/11 for improved DOF. F/11 is a little beyond DLA (into diffraction) but I've always found that macros can tolerate a large amount of fine detail sharpening.
I used diffused flash for these photos (for convenience), but a good set of photographic LED lights (or even a halogen work light) would work just as well. All but the first image (soda can) were shot at max 2:1, just to see how the lens would do. Files are 2160 high, full frame no cropping (no composing really either). EOS M6 Mark II, handheld. Just for fun.
Click on "original size."
Soda can
Roll of Tape
Bolt
Brush
Wire Cutters
Spring
Crescent Wrench
Fiskars Shop Shears
File
Pliers
Spring
Rod and Cable
Pull Chain
Spyderco Delica
Rubber Bands
Leatherman File
Flashlight Knurling
File
Rasp
Nail-set Knurling
Oak
Bronze Screw
Bottom line. This lens really rocks. I thought the colors were exceptional, the contrast excellent, and the sharpness very good.
I can't wait to get outside to shoot some bugs with this baby this spring. Highly recommended!
R2
ps. I really like this little lens hood, since it doesn't cut much into the lens' working distance...
52mm (minimal) hood at @mazon
For a bit more protection from stray light, I actually (currently) have it stacked with this other 52mm hood (meant for the RF 35mm f/1.8 lens)...
52mm (very minimal) hood at @mazon
Canon EOS M6
ken_in_nh Senior Member • Posts: 2,399
Re: Fun with the new Venus Laowa EF-M 65mm 2x Macro
Interesting choice of subjects. I should head to my garage for some pics while it's still iced/snowed in outside!
Too bad the lens won't work with focus bracketing.
FYI I like the brush and the oak the best, probably because of the color?
OP R2D2 Forum Pro • Posts: 26,528
Yeah, just grabbed whatever was at hand!
The 14 fps burst mode (M6ii) actually works very well for stacking (or cherry-picking the best focal plane).
It's amazing how at this magnification (frame size), man-made objects are so very monochromatic!
Now git out to the garage!
R2
303 geek
303 geek Junior Member • Posts: 42
Thank you for the review and beautiful images!
 303 geek's gear list:303 geek's gear list
Sony RX1 Sony a7R II Canon EOS M100 Canon EF 135mm F2L USM Canon EF-M 22mm f/2 STM +14 more
Carl LaFong Forum Member • Posts: 94
Great photos!
I’ve long appreciated images of seemingly everyday or mundane objects (in contrast to landscapes, sunsets, flowers, etc) because of how they illustrate how beauty is around us much more than the average person realizes.
I have had this Laowa lens for many months now but have not used it much (so far) because my few outings with it didn’t result in much that was interesting.  I think that was mostly because I was only using ambient light, which didn’t produce anything nearly as interesting as the shots you have shown.
I need to look into fixing that so I can enjoy this lens more.  Thanks for the motivation.
Quaero intelligere.
 Carl LaFong's gear list:Carl LaFong's gear list
Canon EOS M5 Canon EOS M6 II Canon EOS M200 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +10 more
Dors
Dors Regular Member • Posts: 320
22.2mm (sensor's width) : 11mm is 2:1! At last I got the meaning of macro ratios and 'life size' term.
Thank you!
 Dors's gear list:Dors's gear list
Canon EOS M6 Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM
Many thanks.  It was fun just finding something to do inside on a cold winter day!
R2
Carl LaFong wrote:
Great photos!
Thanks.  Easy to do actually!
I know what you mean.  Seeing stuff that close really is an eye-opener!
Absolutely.  Macro is just like everything else, it benefits greatly from good (and interesting) light.
Yeah, there are so many ways to enhance, alter, add, reduce, and modify light (esp easy for macros!).  I used a cheapo set of wireless radios to get my flash off-camera, in order to impart a bit of drama to otherwise mundane objects.
Have fun!  And thanks again for commenting,
R2
Thank you!
Yay! I actually like using the "Frame Size" measurement when describing macro capabilities (ie a 22.2mm frame size, or an 11mm frames size). This leaves any ambiguity out of it, even as regards to sensor size/format.
I would like to do another macro exercise using just a 1:1 magnification ratio with this lens (22.2mm frame size ). And maybe another at 1:2 (1/2 life size, or 44.4mm frame size). It gets harder to keep things interesting tho as frame size gets larger (when shooting small ordinary objects) as the images are less abstract, and composition becomes more important.
I've heard it said that Macro shooters are the only really happy shooters (since they always have a plentiful supply of subjects to shoot). And I'd tend to agree with them!
Thanks for your comments, and I hope you get to shoot all you want!
R2
Dors
R2D2 wrote:
Thank you!
Excellent idea! With this, macro ability of a lens is very clearly stated and imagined. But it is not used as a standard oddly.
R2
bgreg
bgreg Contributing Member • Posts: 641
5
This thread cost me $424. today. Thanks a lot! great pics tho.
Dors wrote:
R2D2 wrote:
Thank you!
Well if you’re talking about just a lens (in isolation), then you HAVE TO use its magnification ratio, because it might be used on any number of (sensor) formats.
But most of the time folks are discussing a (lens/body) combo’s macro capabilities, including adding close-up lenses, ext tubes, etc, and it’s way clearer and more descriptive to simply state the measured Frame Size.  IMHO
R2
Hey, if your S.O. gives you any trouble, tell them we’re helping to support the COVID economy!
Thanks!  With your aptitude for abstractions (looked at your “Challenge” entries), you should get along fantastically with this lens.  Seek out the good light!  Enjoy.
R2
Dors
R2D2 wrote:
Dors wrote:
R2D2 wrote:
Thank you!
R2
Yes, sure! my bad. Thank you.
Dors wrote:
R2D2 wrote:
Dors wrote:
R2D2 wrote:
Thank you!
R2
No, not your bad at all.  I was just clarifying something that I might have left ambiguous.
Personally I think taking a photo of a ruler is the most unambiguous method of all!
R2
thunder storm Forum Pro • Posts: 10,139
Pull Chain
Rubber Bands
Not saying the other pics are bad, but those look especially outstanding to me.
Perfect Covid lens I guess.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Thanks 'Storm. I just wanted to get in some variety!
I didn't work on my compositions, or even try to get the focal planes perfect. I'm really looking forward to getting serious with some bugs this summer though!
Thanks for commenting. I know you don't really dig macros much.
R2
bgreg
B&H just e-mailed me they shipped my Laowa 65 today. Looking forward to playing with it. Got the 11-22 and 32mm a week or so ago so I've been playing with the 32 and the raynox 250 which works just fine. I also picked up a Fotasy adapter for my M50/2 to mount a boxload of old Konica  Hexanon lenses and surprisingly it works quite well. The adapter with the Hexanon 55mm and Konica macro adapter(extension tube) actually produces decent results. the Fotasy Konica/M adapter was $13 so I thought "why not". It fits quite well on both sides. Just wish the weather would cooperate.
And looking forward to seeing your photos!
Sounds like you have a lot to keep you busy.    Enjoy!
R2
5
Well I had some fun out in the garden last weekend with the Laowa and the M6ii. Had a couple of helpful visitors too.
These were shot at 1:2 (.5x), and then cropped some. F/11 @1/200 second, ISO 200 generally. The Nissin i40 provided some nicely diffused flash. I’m really loving this lens!
Thanks for looking!
R2
