Video scrubbing on the S21
Started Mar 4, 2021 | Discussions
Venger
Venger Junior Member • Posts: 39
Hi,
I've been experimenting with frame grabs from high res video and therefore I've been dragging the play head along the play line to find the frames I want to grab. Trouble is, every time I do this, you get the supposedly 'helpful' hint box pop up on the screen to tell you that you can drag upwards to increase the scrub speed...this hint box is on screen for the entire time you're dragging the play head and obscures whatever image is showing on screen, making it nigh on impossible to accurately stop the play head at the most in focus frame you want to capture!!
Anyone know if there's a way to turn the hint box off ?
I do have Vid Trim Pro on the phone and that has a frame grab facility and better still, you can advance the video forwards one frame at a time which makes it much easier, altho if you go past the frame you can't backup one frame at a time quite so easily.
Anyone use or know of a decent frame grab app that actually works and will allow you to nudge playback both forwards and backwards to locate that perfect frame ?
Many thanks for your time.
