custom wb test sd15 no filter x3f file open in RT and some sharpening with gimp
Started Mar 4, 2021 | Discussions
ole kekkonen
ole kekkonen Contributing Member • Posts: 607
sd 15 cwb capture from the scene
Still learning but I think the dirt and the hose color came out pretty accurate.
same setup but x3f file open with spp6 and auto everything
Sigma SD15
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: Custom WB test SD15 no filter X3F file open in RT and some sharpening with the GIMP
They look good to me, Ole.
I use Custom WB too.
What did you shoot for the Custom WB? Gray card or part of the scene?
Mine is for a gray card filling the frame and shot under direct sunlight.
Are you able to access the WBGain and the Custom WB matrices in the meta-data or can you post an X3F somewhere accessible?
Do you prefer the GIMP's sharpening to RT's?
In RT I use Contrast By Detail Levels followed by about 60% low-radius (typically 0.57) LR Deconvolution.
Pedantry is hard work, but someone's gotta do it ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
ole kekkonen
OP ole kekkonen Contributing Member • Posts: 607
I know nothing, really!…:)I did try the custom wb because you suggested it in another thread.I did it like the first photo in this thread, not sure if the camera read the white or shadow in the bucket as I took the reading.
yes prefer sharpening in the gimp,when I use cbdl in RT the image show up different in gimp,much sharper.
not sure if this work
https://photos.app.goo.gl/uDkrAaAW6qEMnqsW7
I didn't know google photo could open x3f files
xpatUSA
No, the displayed image has been re-done and protected by Google.
Probably extracts the full-size JPEG from the X3F, but I seem to recall that Picasa would open SD9 files - perhaps using DCraw.
But DCraw does not convert SD15 files (filtered or not) correctly - just creates a bluish low-saturation raw composite image.
ole kekkonen
I don't have a website so you can download∞
how do I access the WBGain and the Custom WB matrices in the meta-data?
xpatUSA
Oh boy ...
First download and install an app known here as "Kalpanika" ...
https://github.com/Kalpanika/x3f/releases/tag/0.57
If that goes well, somewhere there will appear a command-line file "x3f_extract.exe".
Move a copy of your X3F file to wherever the command-line file is.
In the command-line window "cmd.exe" type:
x3f_extract -meta SDIM0903.X3F
A file SDIM0903.X3F.meta is stored.
Windows can open it:
HTH
ole kekkonen
Oh boy ...
HTH
I will take a look on that
are you on linked in? maybe I can send the x3f file there as a pm
xpatUSA
Sorry, not on LinkedIn ...
You could attach it to an email to:
ole kekkonen
You got mail;)
xpatUSA
You got mail;)
U2
