Sigma EF-M 30mm 1.4 - update without a dock?
Tapik
Tapik Junior Member • Posts: 37
Hello,
Just ordered this lens from a local store, but maybe it doesn't have the latest update on it. Can I in this case update the lens through the camera itself, or I should get the dock for that?
 Tapik's gear list:Tapik's gear list
Canon EOS M200 Canon EF-M 15-45mm F3.5-6.3 IS STM Sigma 30mm F1.4 (E/EF-M mounts)
Miguel-C
Miguel-C Senior Member • Posts: 1,979
Re: Sigma EF-M 30mm 1.4 - update without a dock?
Tapik wrote:
Hello,
Thats a good question, i have the lens but i dont know how to check for its update status. where would one go to see that?
With other lenses i would see it together with the body firmware, but it doesnt show for these new sigmas.
Cordial Regards
 Miguel-C's gear list:Miguel-C's gear list
Fujifilm X-T2 Canon EOS M5 Fujifilm XF 35mm F2 R WR Sigma 30mm F1.4 (E/EF-M mounts) Sigma 16mm F1.4 DC DN (E/EF-M mounts) +1 more
geru Senior Member • Posts: 1,195
Seems there is a firmware update for several mounts. Here's a link for the update at Sigma.
Hope this helps .....
 geru's gear list:geru's gear list
Canon EF 85mm F1.8 USM Canon EF-S 10-18mm F4.5–5.6 IS STM Canon EOS M50 Canon EOS M6 II Canon EF 40mm f/2.8 STM +5 more
beagle1 Forum Pro • Posts: 11,236
Tapik wrote:
Hello,
the older "non-art" 30mm 1.4 needs a dock - (but mine works fine on the M5 w/o updating)
Miguel-C
geru wrote:
Seems there is a firmware update for several mounts. Here'sa link for the update at Sigma.
Thank you, the issue is i dont know how to update these lenses haha. I have the old EF Sigma dock..
Cordial Regards
MyM6II
MyM6II Senior Member • Posts: 1,722
I think you need the Sigma UD-11 dock for EF-M.
https://www.bhphotovideo.com/c/product/1570253-REG/sigma_878971_ud_11_usb_dock_for.html
 MyM6II's gear list:MyM6II's gear list
Canon G7 X III Canon EOS M6 Canon EOS M100 Canon EOS M6 II Canon EOS M200
AshleyMC Senior Member • Posts: 1,148
https://www.sigmaphoto.com/article/firmware-update-for-sigma-ef-m-mount-lenses-8-20-2020/
https://www.sigma-global.com/en/software/sigma-optimization-pro/
Connect the lens to a computer via the SIGMA USB DOCK UD-11 (sold separately), then open SIGMA Optimization Pro software on your computer. If the lens firmware isn't the latest version, the following message will appear: 'The latest lens firmware is available'. Click 'Yes' to update.
thunder storm Senior Member • Posts: 6,567
Isn't it possible to use that one in combination with the EF-ef-m adapter?
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS M6 II Canon EOS R5 Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 35-80mm f/4.0-5.6 III Canon EF 24-70mm F2.8L II USM +16 more
Miguel-C
Ill check it out after work
Cordial Regards
Great!
Miguel-C
Great!
Not possible, the ef mount on the dock is larger. You need the UD 11 dock.
Cordial Regards
Thanks for reporting!
Lombardo_ph New Member • Posts: 3
you need the dock :/
