Fujifilm X-Trans II film like qualities?
Started Mar 1, 2021 | Discussions
Corot2 Senior Member • Posts: 1,697
HI
I have been reading quite a bit about the Fuji xt1, x100s, x100t, xe2 that X-Trans II may be the  best sensor for achieving "film like quality" in their output. Also, some have written this is Fujifilm's best sensor.
Wanted to see if those with this sensor and other sensors found this to be the case and if their is a noticeable difference in the output of the sensors and also if not the same type of qualities could be achieved by using another of Fuji cameras with vintage lenses?
Thanks very much
Lou
 Corot2's gear list:Corot2's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-E2S +11 more
Fujifilm X100S Fujifilm X100T Fujifilm X-E2 Fujifilm X-T1
Ulrik Christiansen
Ulrik Christiansen Senior Member • Posts: 2,837
Re: Fujifilm X-Trans II film like qualities?
lou Capeloto wrote:
HI
Thanks very much
Lou
I have an xt1. Imho, I can't see the "film" difference between it and my xt20 and xt3. But I guess it partly comes down to what film sim settings are used. If you look at fujixeekly recipes, I would think that you would be able to get all of the fuji x cameras to look like film in some way or another.
I do have some shots with the 35mm 1.4 and the xt1, where I used some portra and ectachrome recipes and I found them very nice indeed. And adapting some of the old vintage lenses can also give a different look.
Maybe others have investigated this in much more detail.
I think the most striking thing with the xt1 is, that it can be found really cheap and with the right eyes behind the camera, it will make images just as fine as any new camera. You have to live with slower autofocus among other things of course
 Ulrik Christiansen's gear list:Ulrik Christiansen's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8 Fujifilm XF 56mm F1.2 R +3 more
OP Corot2 Senior Member • Posts: 1,697
Thank you
I appreciate it, very helpful for me
(unknown member) Senior Member • Posts: 2,057
I much prefer the output of Xtrans 4 to Xtrans 2. I probably dislike 2 the most and never shoot JPG with it. But I do love adding Classic Negative to the RAF files in Capture One. The softer 16MP sensor has a nice filmic look with Classic Neg imo (I haven't compared with Xtrans 4). Less so with Lightroom's version which is cleaner or something. Unfortunately it is no extra steps to add Classic Neg in Lightroom so I may stop using Capture One, as I always then put the photos back into Lightroom after. Pal2tech has a video explaining how to get Classic Neg on older cameras in both programs.
For filmic lenses I recommended the old Super Takumar 55mm f1.8 or 50mm f1.4. The radioactive ones. The most filmic was in terrible condition so I wouldn't worry about the condition. Makes a bigger difference on Xtrans 4 cameras as the sensors are much crisper,  so that nice vintage softness is a noticeable change from super sharp contrasty lenses like the modern Fuji 50mm f2.
biza43 Forum Pro • Posts: 15,074
13
There are many types of film. So, "film like" is many things for many people. As good as Fuji marketing is, digital output passed through film simulations is very different from film.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
Redscale disco Junior Member • Posts: 27
I have an X-T30 and an X-T1. I can’t see any more ”film like” qualities in the X-T1. It really depends on your settings or your post-prosessing.
I do like in general what you can achieve with Fujifilm cameras if you are looking at some kind of film look. But I also think that this means different things for different people.
Anyway, this is a shot taken with the X-T30 and 35mm F1.4. It is a double exposure, where the second picture is out of focus shot of a white paper. It is post-processed just lightly, I added a little exposure, brought down the highlights and lifted a shadows a little bit. My point is, I could do this with the X-T30 and X-T1.
bowportes Veteran Member • Posts: 4,337
This could be easily done without your white 2nd exposure. Simply layer a white pixel layer with a gaussian blur. Sweeten the amount of blur and the percent of transparency on the white layer to taste for the desired effect
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro3 Fujifilm GFX 50S II +15 more
Krummj Contributing Member • Posts: 543
If you read The Online Photographer, Mike Johnston praises his X-T1 for having his favorite black and white tonal response (he also has an X-H1). He has long black and white experience and expertise so I trust his judgement. I assume this is with raw files because I believe he uses ACR and Photoshop.
dmaclau Veteran Member • Posts: 3,053
Heven't noticed
I have not noticed this, although I've seen it mentioned previously.
I normally shoot with an XP-2, xTrans III. I purchased an X-70 last year, xTrans II.  I've tried to compare the outputs of these cameras to one another, including using the same focal length.  I do notice differences between them of course but as far as filmic...no.  Not at all.
I do get that the word filmic is subjective so my findings are based upon my experience.  Many years of film photography then onto Foveon sensor cameras as they gave me the output I was most used to. I switched to Fuji with the XP-2.  I find the Fuji colors to be second in the "digital filmic" category but quite a bit ahead in camera usefulness.
absolute power corrupts...absolutely
 dmaclau's gear list:dmaclau's gear list
Fujifilm FinePix X100 Fujifilm X70 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +4 more
ms18
ms18 Veteran Member • Posts: 3,530
Definitely not. Autofocus is now a sensor thing, it has vastly improved in current sensors despite image quality remains some what same.
If you like my pictures follow me on Insta
https://www.instagram.com/mahidoes/
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +1 more
Doug MacMillan Veteran Member • Posts: 3,695
Thanks very much
Lou
Lou,
I have the X-E2s, plus the X-E3 and X-H1. There are times I shoot with all and I feel I could easily mix and match the images and you wouldn't be able to identify which camera took what photo, assuming they are all set up the same.
However, I go back and forth on whether I can see a little something in the images, especially the JPEGs I get from the X-E2.
I also shoot with vintage lenses on all three and the differences are not sensor dependent.
I started with the X-E3, then got an X-E2 as a backup. I ended up giving my grandson the X-E2 when his Canon Rebel (which I had also gifted him) got destroyed in a fire.  I missed the X-E2 and found a cherry copy of the X-E2s.  Reviewers minimized the differences, but I feel the X-E2s is a much better camera.
It's getting harder to find X-Trans II bodies, but if you do,  grab it.  Also, if you don't have any vintage lenses, buy a few and experiment.
This photo was taken with the X-E2s with a Canon FD 50mm f1.4.  I converted to B&W from the RAW file using PS and Topaz Studio.  I also added a texture layer to add character.
X-E2s, Canon FD 50mm f1.4, B&W conversion via Topaz Studio
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
Doug MacMillan wrote:
Thanks very much
Lou
Lou,
When I see posts like this I can't help but remember all of the complaining about the 2nd generation JPEG images...  how the 1st generation (the X-Pro1 and XE-1) were far superior...   how the 2nd generation had crushed the shadows, etc.
I think it's mostly a matter of what we become accustomed to rather than which is most "filmic." I didn't find the images from my X-T1 (2nd gen) to be superior or inferior to my X-E1 (first gen) or X-Pro2 (3rd generation).
I'll agree with you that the X-E2 (and X-E1) were delightful cameras to shoot with.
Nice shot. Thank you. I just got back from shooting near my condo with my old xm1 and the Minolta 40 mm f2 m mount v2. Will post a few shots hopefully later today
jjz2 Veteran Member • Posts: 4,396
I haven't noticed much difference in images, if any. Can crop slightly more, that's about it.
If I really want the film look, I can load some film into quite a few film cameras I have laying around.
I'd say if you like the look, get an actual film camera... you can get them for next to nothing.
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 85mm F1.8 +1 more
I love that little X-m1.  It's a treasure, and the easiest use of flash for quick candid stuff and fill.
jslade797 Regular Member • Posts: 326
I heard similar things about the first generation X-Trans and played around with an X-Pro 1 for a while. I actually a post comparing its output to the X100T (X-Trans II) sensor that you might find interesting: https://www.jonathanslade.net/post/in-with-the-old
I agree with Street_Photography that the X-Trans II is my least favourite of the Fuji sensors, though many of my favourite shots were taken with X-Trans II cameras. I find there's a slight tendency to yellow and a waxiness to the High ISO output (especially skin tones) that is improved with the later sensors.
Instagram - @jontyslade
 jslade797's gear list:jslade797's gear list
Fujifilm X100V Fujifilm X-E3 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R
Few photos from experiments today
I was encouraged to pull out my xt 20 and my old Fuji xm-1 and put on the 40mm f2 m Minolta ver 2 lens and wanted to share a few photos outside my condo
When I compare them, the lens to me seems to give an older vintage look
Fuji xt 20 f2/40mm Rokkor
Fuji xm-1 40mm f2 Rokkor
Here are the photos labeled with the camera
Minimal post processing
rlandrigan Regular Member • Posts: 131
I'll second that 16mp sensor being something good, not just Fuji's take on it but the entire Sony line it's based on. The D7000, Nikon Coolpix A, X70, X-T1, etc - it has a great balance of enough resolution but not so much that it outraces the lens. For IR conversion, I'm really happy with it, and while I think my X-T2 and X-H1 outstripped the X-T1 in most aspects, it dealt with converted lenses often better - but IBIS won out for me:)
Threaded Veteran Member • Posts: 4,180
8
I think if you’re going to go down the “filmic” old sensor rabbit hole then it’s generally accepted that the original X-Trans, principally in form of the X-Pro1, is the one to go for. In Fuji world that’s really the source legend of the whole film-like mythology.
X-Trans II was actually heavily criticised at the time for losing the fabled “organic” look and seeming too digital. In comparison to the X-Trans I JPEG’s, the results are a lot more polished in some ways, bolder, and less subtle. Someone on this forum once said it was as if X-Trans I produced matte prints, and X-Trans II glossy.
Of course that’s all subjective, but X-Trans II’s worst crime was what it (or at least the image processor in those second gen cameras) did to skin tones at higher ISO. At 1600 ISO or above, the XE2, XT1 etc all apply a very heavy handed noise reduction to skin tones which renders faces waxy and artificial looking - a deliberate “enhancement” which couldn’t ever be turned off even with the in camera NR setting turned down. X-Trans III and later cameras removed this, or at least reigned it in significantly.
For that reason, as a jpeg shooter, X-Trans II is by far my least favourite sensor and I was very glad to move on from it.
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
Sjak
Sjak Veteran Member • Posts: 7,318
lou Capeloto wrote:
HI
Thanks very much
Lou
"Film-like" look can be achieved in two ways:
1. Shoot film (which is actually a lot of fun to do from time to time!)
2. Shoot digital and do post-processing to achieve the look you want.
The sensor is of little consequence in this process. But maybe you will find it easier to work on files from one camera compared to another.
Myself, I've made "film like" images with all kinds of camera's. On the toher hand, I've also made "digital looking" images with film-scans
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
