considering b&w
Started Feb 28, 2021 | Discussions
ole kekkonen
ole kekkonen Contributing Member • Posts: 607
considering b&w
I got a sd15 without the dust filter from a friend.Been shooting with it all day and I like it but I can't get the color right
Sigma SD15
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: considering b&w
ole kekkonen wrote:
I got a [SD15] without the dust filter from a friend.
Well done!
It won't give you correct colors unless you mount a visible light filter on the lens. Kolari makes one which they call a "hot mirror".
ebay example: https://www.ebay.com/itm/Kolari-Vision-58mm-Kolari-Vision-Color-Correcting-Hot-Mirror-Filter-UV-IR-cut-/290869671163
Do not buy the B+W 486 - it is dichroic and gives a green cast at the sides if used on a wide-angle lens.
The Kolari has a slight blue cast overall - easily fixed in post or with a Custom WB.
Pedantry is hard work, but someone has to do it ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
Re: considering b&w
ole kekkonen,
Maybe someone with a "dead" SD15 might be able to give you a dust filter.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
docmaas
docmaas Veteran Member • Posts: 7,061
I think I have an 82mm Kolari around here somewhere.
I bought it for my Quattro when I broke the original and no replacements were to be found.  If you're interested let me know and I'll look for it.
Mike
"Laoma shitu" "An old horse knows the road" Chinese Proverb                                        "Dao ke dao, fei chang dao. Ming ke ming, fei chang ming" Laozi
"At every crossroads on the path that leads to the future, tradition has placed 10,000 men to guard the past."
Maurice Maeterlinck
ole kekkonen
OP ole kekkonen Contributing Member • Posts: 607
Re: considering b&w
Thanks, you are all very kind.but after seeing the files without the filter I am not sure if I will try color again, the best part is that I can do the jpeg again allover from the x3f file with the same result
xpatUSA
Re: considering b&w
Good one. I don't do B&W often because I prefer the false colors without any filters.
But for interest today, I extracted the blue layer with RawDigger and had at it in FastStone Viewer. Came out quite good:
SD15, no filter, 17-50mm @ 23mm. 100 ISO, f/10, 1/200 sec.
Blue because the solar panel had the narrowest lines and there was more "grain".
ole kekkonen
Re: considering b&w
very nice!It looks like a gelatine silver print
I guess I can get use to the false colors too
both at @iso 400 no filter
ahhh when in doubt run in circle scream and shout
xpatUSA
Re: considering b&w
ole kekkonen wrote:
I guess I can get use to the wrong color too
I wonder how it would come out when lit up? Depends what kind of lamps they are, of course. Shadows on the lion-heads should be striking in B&W ...
How about a lions triptych?
Yes, when there isn't much IR from the scene the colors can be quite pleasant and semi-accurate. Playing with various White Balance selections in SPP can work and trying a sunlit Custom WB can also be interesting ...
ole kekkonen
Re: considering b&w
Yes, when there isn't much IR from the scene the colors can be quite pleasant and semi-accurate. Playing with various White Balance selections in SPP can work and trying a I,I
Liking the lions triptych
ole kekkonen
Re:not considering b&w
color version peugeot
