ISO Bracketing in Z system
PankajDubey Senior Member • Posts: 1,450
Hi,
I was wondering if there is a possibility of just varying the ISO to Auto-bracket shots.
I can manage this in Sony A6400 with Manual mode+ Auto ISO- where just the ISO changes to bracket the exposure.
In Z5 in Manual mode the Auto ISO stays put and either S or A changes or nothing happens - even if the Auto ISO limit is not reached.
 PankajDubey's gear list:PankajDubey's gear list
Nikon Df Sony a6400 Nikon Z50 Voigtlander 58mm F1.4 Nokton SL II Sony E 50mm F1.8 OSS +15 more
topg Forum Member • Posts: 75
Re: ISO Bracketing in Z system
PankajDubey wrote:
Hi,
If you click on the little green icon next to 'Exposure Bracketing' on this page of the manual, you'll see more guidance on what is varied in each mode: https://onlinemanual.nikonimglib.com/z5/en/09_menu_guide_03_28.html , and about ISO in Manual mode:
  1. [snip]
  2. If [On] is selected for [ISO sensitivity settings] > [Auto ISO sensitivity control] in the photo shooting menu, the camera will first use auto ISO sensitivity control to bring exposure as close as possible to the optimum and then bracket this exposure by varying shutter speed.
  3. Use Custom Setting e6 [Auto bracketing (mode M)] to choose whether the camera varies shutter speed, aperture, or both shutter speed and aperture.
But ISO is not part of exposure so it doesn't really make sense to include it in 'exposure bracketing'.
OP PankajDubey Senior Member • Posts: 1,450
topg wrote:
PankajDubey wrote:
Hi,
If you click on the little green icon next to 'Exposure Bracketing' on this page of the manual, you'll see more guidance on what is varied in each mode: https://onlinemanual.nikonimglib.com/z5/en/09_menu_guide_03_28.html , and about ISO:
  1. If [On] is selected for [ISO sensitivity settings] > [Auto ISO sensitivity control] in the photo shooting menu, the camera will automatically vary ISO sensitivity for optimum exposure when the limits of the camera exposure system are exceeded.
thanks 😊
I did read the manual .
the last paragraph is a minefield that takes away the the third point of the triangle.
nikon does use the auto iso for varying exposure- just that it doesn’t allow only the ISO to change in bracketing mode.
No it uses ISO to adjust output image brightness, not exposure. This has been much discussed here in other threads, but see: https://petapixel.com/2020/03/05/iso-has-nothing-to-do-with-exposure-an-explanation-for-beginners/
It makes even less sense to bracket ISO when you have ISO invariance beyond a certain range like with the Zs.
Thanks again,
when I said - it is a minefield- I meant that I have read all that and seen some videos of the Angry photographer( Theoria Apophasis) too 😊 and whether larger sensors gather more light.
I just wanted to know if it can be done in Nikon or not.
karlreed Senior Member • Posts: 2,355
Thanks again,
Actually, ISO bracketing is a good idea. I can imagine situation, eg sports, where I want to fix my aperture (to control DOF) and my shutter speed, but, my targets are moving through areas with different lighting, eg., the shadow of a stadium on a sunny day. (not quite so good when they are moving, but,perhaps when they have moved)
It's possible that Active D lighting bracketing may have a better result than simple ISO bracketing. The existence of ADL bracketing may be why there is no ISO bracketing.
Can't see Autolighting bracketing easily in the R6 menu.
Karl
karl reed "let's change the tone-civility is in!"
 karlreed's gear list:karlreed's gear list
Sony RX100 IV Nikon D200 Nikon D750 Olympus E-M1 II Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +6 more
karlreed wrote:
Thanks again,
Karl
Thanks,
Recently, I went for a Tiger safari and the Tigers come out either in the morning or near the sunset to get to the water body.
The Min aperture gets decided by costly/cheap the lens is and you need the shutter speed for the active cubs.The Auto ISO gives one reading - often high . I had the A6400 and it is not good beyond 800.So, rather than change the ISO every time or switch back and forth between AUTO ISO and fixed ISO or fiddling the exposure comp button each time, I thought the ISO bracketing at continuous high(5 shots) gave me at least two manageably exposed shots.
But that was Sony .
I would try the ADL bracket in Nikon.
PLShutterbug Contributing Member • Posts: 937
PankajDubey wrote:
Hi,
Reading through this thread I wonder if you really mean “bracketing” or if what you want is auto-adjustment.
Bracketing means to take multiple images of the same scene while varying a single setting to ensure you get one image with the “best” exposure. In post, you choose which is the best and discard the rest. Or maybe you stack to increase the dynamic range of the finished image. You can also do focus bracketing by keeping all exposure parameters the same but changing focus through a series of images.
Reading here, it sounds like you really don’t want bracketing as I define above but automatic adjustment: the camera automatically adjusts aperture, or shutter speed, or ISO of a single shot to provide one image that is best exposed.
Nikon can do either, with ISO, aperture or shutter speed as the variable.
Are you looking for auto-bracketing, or auto-adjustment?
 PLShutterbug's gear list:PLShutterbug's gear list
Sony RX10 IV Nikon D7100 Nikon Z7 Nikon AF-S DX Nikkor 18-105mm F3.5-5.6G ED VR Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF +4 more
PLShutterbug wrote:
PankajDubey wrote:
Hi,
This is what I want and get with the Sony set up in A6400.
Not sure how you got that impression.
Auto bracketing, then I pick and choose or merge.
Thank you for your help, I was looking for pound for pound thing in Nikon.
The ADL bracket would light up the shadows in otherwise bright scene but won't work in cloudy or not good light setup.
ISO Bracketing is #6 in the list:
https://digital-photography-school.com/6-types-bracketing-camera-can-use/
Re: ISO Bracketing in Z system- Managed it 😎
Thanks everyone who chipped in.
I worked out that if you put the Z5 in manual mode, AUto ISO and e6 Mode M to flash only - then only thing that changes is ISO.
There is one catch- if Auto ISO is too low for +1.0 then it will lower shutter speed.
If Auto ISO range is is high enough then it will vary only the ISO and keep the shutter and aperture constant.
And for z6ii? ISO Bracketing in Z system- Managed it 😎
I couldn't get this to work for my Z6ii. In fact, it has now decided not to bracket at all.
Re: And for z6ii? ISO Bracketing in Z system- Managed it 😎
I am travelling out of my home city so don’t have the Z5 with me ( I do have the canon 1200D with Magic lantern)
The Z6ii is not supposed to have a mind of its own- 😊what you say happened to me as well when all three shots were of the same exposure settings.
the e6 settings to flash only and Auto ISO settings max value allowed are the two important settings
e6
e1
e2
M MODE
I can't get this to work..Re: And for z6ii? ISO Bracketing in Z system- Managed it 😎
Well, I have tried your suggestion, and, on my Z6ii 1.10 firmware it doesn't work.
And, reading the manual, neither t should!
Re: Correction -works in Aperture priority with rest of the settings as described.
Just checked and re-checked my settings -It is Aperture priority on mode dial - rest of the settings as above.Only when it crosses the ISO set threshold that is decreases the shutter speed.But it works in limited circumstances- you have to define the minimum shutter speed with flash in the Phot shooting menus - ISO sensitivity-> minimum shutter speed with flash.
The manual is pretty clear about what should happen in your clip.
It's possible that your work around is only effective for the R5.
I spent a lot of time on this..
Three photos in sequence with Exif showing bracketing.
and only ISO varies.
over +0.3 ISO 640
Exposure Bias 0 ISO 500
Exposure Bias -0.3 ISO 450
The logic is: The Aperture mode fixes the Aperture.
That leaves shutter speed- which is fixed by enforcing -the flash only bracketing and fixing the minimum shutter speed in AUTO ISO bracketing.
only when the highest level set for Auto ISO is reached does the system do anything with shutter speed.
