Disable external flash on GR3?
Daniel Schutte New Member • Posts: 1
When out shooting, I am constantly switching between available light and flash depending on the situation. I use a cheap manual speedlight (Olympus t-20).
I've checked the GR3 manual as well as various forums, but can't find any way of disabling the flash when it is mounted on the hotshoe. This is annoying since, in addition to changing camera modes, I also have to turn the flash on/off when there is a change in lighting.
Ideally, I'd like to have M/TV/AV/P set up for natural light (i.e. flash disabled) and U1/U2/U3 for flash. This way I can simply change camera modes depending on the shot that I want.
I expected to find the solution in the "Flash Mode" menu, but the only available options are "Flash On" and "Flash On + Red-Eye".
Any advice would be appreciated.
Stavrosf Regular Member • Posts: 155
Re: Disable external flash on GR3?
I don't know the answer, but why don't you turn off the flash?
 Stavrosf's gear list:Stavrosf's gear list
Ricoh GR Ricoh GR III Nikon Z6 GoPro Hero9 Black Nikon AF-S Micro-Nikkor 60mm F2.8G ED +10 more
