Exposure on Nikon F3
Giovanni_1968
Giovanni_1968 Veteran Member • Posts: 3,287
The F3 has been sleeping for ages, got new batteries and two film rolls, an Ilford Delta 100ISO BW and an HP5 400ISO, now the Delta is loaded, took some shots with both my dad's old pre Ai (modified) lenses and with my 50 and 85 D f1.4 but wondering how does the camera evaluates exposure, too used to digital now and wondering how to work it out on analog.
The idea is to learn to develop on my own and then to eventually scan, got the F3 manual so I can read about exposure but any hint would greatly be appreciated.
Grazie
Giovanni - 70% GAS affected
http://www.flickr.com/photos/giovanniaprea/
Nikon D850 - Nikon D800 - Nikon D2Xs - Fuji S5Pro - Nikon F - Nikon F3
J.A. Michell Gyrodec - Audio Research SP-9 - Aeron AP-890 - JBL4311B - JBL L220
JN70CN - 14.14.30E 40.32.40N
 Giovanni_1968's gear list:Giovanni_1968's gear list
Fujifilm FinePix S5 Pro Nikon D2Xs Nikon D800 Nikon AF-S Micro-Nikkor 60mm F2.8G ED Nikon AF Nikkor 50mm f/1.4D +16 more
Overrank Senior Member • Posts: 2,087
Re: Exposure on Nikon F3
Grazie
If you haven’t seen it already this is the manual for the F3 - https://cdn-10.nikon-cdn.com/pdf/manuals/archive/F3.pdf
The meter on the F3 is biased 80:20 to the 12mm circle in the viewfinder, which means you can get slightly different readings than for a 60:40 meter in other Nikons.  Personally, in most cases I just set the shutter speed to A and use it as a aperture priority automatic.  With negative film the exposure is pretty much spot on in most cases.
Remember that meters differ depending on their calibration and age, that shutter speeds are rarely 100% accurate, and that even the aperture itself may not be 100%.   But it nearly always comes out in the wash.
Giovanni_1968
OP Giovanni_1968 Veteran Member • Posts: 3,287
I guess I will have to send the negative to develop soon and figure it out myself, the old trial and error technique... unfortunately here where I live nobody does it any longer and as such have to wait to be able to get onto the mainland bla bla bla
By the way I always shoot A so I leave the camera the duty to pick an adequate shutter speed.
I was reading, with regards to the film being used that it can be "pushed" to ISO80 rather than 100, I assume but am probably wrong, that it is suitable as to get more detail into the shadows whilst the emulsion can kind of resist excessive highlight, might that be the case?
Grazie
Grazie
There’s two uses of pushing and pulling, (shooting 100ISO film at 80 would be pulling).  There’s pushing and pulling where you shoot the film at a different speed and then correct for it in development, there’s also just shooting the film not at the box speed, developing as normal,  and letting the latitude of the film take care of it.  I suspect shooting 100 at 80 would be the second, just slightly overexposing the film.   Most consumer negative film takes overexposure very well so I sometimes deliberately over expose (say 200 ISO at 100) to get finer grain (XP2 is good for this).
ross attix Contributing Member • Posts: 563
Grazie
I am not sure I understand what question you are asking. Is it about how the meter works on the F3? If so, another person answered that.
But then you mentioned having to send the film in for development and using a “trial and error technique” so were you referring to running a snip test?
If your question is just about how to expose and develop film, and are talking about negative film, you should expose for the shadows, develop for the highlights.
This is why-If you took a cross section of a developed negative, the highlights are the thickest, shadows the thinnest. If you do not have enough exposure to hold detail in the shadows, you will never get it by over developing mostly because there isn’t enough density for the developer to react with.
Ross Attix
Giovanni_1968
Yep, mostly that.
Nope, there is no laboratory locally so I will have to expose the whole thing then go to the nearest town (Napoli which is 18NM across with ocean in between) and hand it to my printing service who, on their own, have a guy who goes through once a week to collect, develop, deliver... that's why, if I like it, I'd then like to develop myself which I know not being rocket science.
Ok, this is important to know, grazie mille!
When I first laid my hands onto the Fuji S5Pro digital camera I learnt that, tanks to its particular S-CCD sensor, one can concentrate on shadows with little chance to burn highlights, what a camera it was (still have one), pity I wasn't really good at using it back then.
Grazie
TJer
TJer Forum Member • Posts: 54
You may find it much easier to predict your results by adding or subtracting stops with your compensation than to “push” or “pull” your ISO/ASA. In either case it may wise to bracket your exposures depending on your confidence in your exposure.
If you insist on “pushing and pulling”, you may want to get yourself a handheld light meter or add an app to your phone to do the same (as I do).
The apps are very inexpensive and, from my experience, really reliable. My favorite apps are the “MyLightMeter” $1.99 or $3.99 for the “Pro” version (preferred); and “theLightMeterWheel” $1.99; both of which are available from the App Store (sorry, don’t know about non-Apple availability). There are many more but these are the most accurate from my experience and actual use.
Hope this helps!
When I want a good photo, I shoot digital. When I want a great photo, I shoot film!
 TJer's gear list:TJer's gear list
Nikon Coolpix 995 Fujifilm X100S Nikon D70 Olympus E-M1 Sony a7R +45 more
Giovanni_1968
Hope this helps!
Grazie for your suggestions
