Sony A7iii Metering Issue
dfeldt91 New Member • Posts: 24
If I half press the shutter button in anticipation of taking a shot the meter readout changes by nearly a full stop. Does anyone else have this issue? Or know why this is? Even if it's tripod mounted, so I doubt it has anything to do with the actual readout from the metered scene.
 dfeldt91's gear list:dfeldt91's gear list
Sony a7 III Sony FE 24-105mm F4 Sigma 105mm F1.4 (L-mount) Canon Pixma Pro-100 +3 more
Sony a7 Sony a7 II Sony a7 III
Benz3ne Regular Member • Posts: 212
Re: Sony A7iii Metering Issue
Have you got metering paired with focus point?
You might then be focusing on an area darker or lighter than the mean of the scene, and your metering changing accordingly.
LenRivers Senior Member • Posts: 2,995
Arbiratry guesses... I have the A7iii myself going on like 3 years I think
What metering pattern are you using. Spot meter could mess things up
Do you have any exposure compensation set?
Was the camera bought new or used
Any physical damage to the camera, dropped, exposure to sand or salt water/spray
When all else fails reset the camera ie look though the manual to go over each page and each menu setting related to exposure
dave
dave Senior Member • Posts: 1,507
When the apeture is stopped down smaller then max apeture, the apeture will open when the shutter is hapl depressed. This will result in a differt exposure indicated. Watch the diaphram as you press the shutter button half way.
Dave
Sony A7RIII A7III A6000 Pentax K5II
 dave's gear list:dave's gear list
Sony a6000 Sony a7R III Sigma 35mm F1.4 DG HSM Art Rokinon 14mm F2.8 IF ED MC Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +14 more
