Rolling shutter comparison of A7r4, A7s3 and A1
pollup Contributing Member • Posts: 874
Credits to https://www.mobile01.com/topicdetail.php?f=254&t=6311416
Notice how there is zero visible distortion with the A1 sensor, and also the banding has disappeared.
 pollup's gear list:pollup's gear list
Sony a9 Sony FE 85mm F1.8 Sony FE 35mm F1.8 Sony E 70-350mm F4.5-6.3 G OSS Canon EOS 550D +7 more
Impulses Veteran Member • Posts: 7,776
Re: Rolling shutter comparison of A7r4, A7s3 and A1
Gotta love that 1/200 readout speed.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +29 more
OP pollup Contributing Member • Posts: 874
It's actually 1/250
pollup wrote:
It's actually 1/250
Was it tested at that? I mean it's academic but still... I assumed it'd be close to that when they said 1.5x but then everyone including DPR started quoting 1/200, there might be technical reasons the body doesn't use the full speed the sensor is capable of no? I'd be curious to see what the improvement in crop mode is like if it's not doing 1/250 for the whole frame, as crop mode used to double readout speed for older A7R bodies.
Impulses wrote:
pollup wrote:
It's actually 1/250
That's the official specs of the sensor ... and also Sony stated that it's 1.5x as fast as the A9 (being at 1/160), and if you do the math, 160 x 1.5 = 240, so everything adds up. However 200/160 is only 1.25. So if it's only 1/200 then Sony would be lying big time, because 1.25x is not even close to 1.5x.
Not everyone said 1/200, and DPR didn't "quote" 1/200, they just wrote "1/200 or faster", showing that they have no idea what it really is. They just know it's faster than 1/200 because the flash sync speed is 1/200 with the electronic shutter. However, you always need to be faster in order to get that sync speed, with some margin. That's why it's impossible for it to be only 1/200, because otherwise the flash sync speed would be lower, like 1/160.
It's doing 1/250 for the whole frame.
Speed is lowered in video mode, but not in stills mode. I think it's around 1/110 for 4k, and 1/60 for 8k.
