DP1s Focusing problem
Started Feb 24, 2021 | Discussions
furtle
furtle Senior Member • Posts: 1,572
I have a DP1s in near mint condition that no longer focuses either in auto or manual mode.  It worked perfectly well, it was put in a cupboard and now doesn't focus at all.
Any suggestions?
Many thanks
Best, Steve
 furtle's gear list:furtle's gear list
Ricoh GR Digital III Sigma DP2 Merrill Sigma dp3 Quattro Sigma dp0 Quattro Sigma sd Quattro H +2 more
Sigma DP1s
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
Re: DP1s Focusing problem
Any suggestions?
Many thanks
furtle,
Lack of use must have caused some part to seize up or some electrical contact has corroded or carbonised.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Some applied vibration (less than 50G recommended) might do it, Steve.
For example held onto a: car engine, electric sander, electric jigsaw, kitchen appliance, etc., while trying to focus.
https://www.hansfordsensors.com/resources/vibration-calculator/
Enter frequency and amplitude - get acceleration (G)
Then there is the "calibrated tap" method. With the camera powered up and failing to focus, tap it repeatedly from different directions with the wooden hand of, say, a file or small hammer.
Finally, and in desperation, drop it from about a quarter of a meter onto a lino floor or a soft wooden board...
It will impact at just over 7 ft/sec and stop in maybe 1/16" ... figure the linear deceleration just for fun ...
Pedantry is hard work, but someone has to do it ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
furtle
OP furtle Senior Member • Posts: 1,572
Thanks, Ted.  It's very dead now.  It'll turn on and the lens extends and that's it.  The back screen is black apart from the manual focus distance scale.  I can't turn it off again but eventually, it shuts itself down.
I'll try your angle grinder advice and cut it up.
Best, Steve
furtle
Ceistinne wrote:
Any suggestions?
Many thanks
furtle,
S
Thank you.  I didn't use it too much, so, probably you're right.  Shame really.  Another DP1s bites the dust.
Best, Steve
xpatUSA
Sad to hear, Steve.
I enjoyed a DP1s for about a year but sold it when I downsized in a fit of pique ...
victorgv
victorgv Senior Member • Posts: 2,123
flex cable bit the dust common problem in dpX . if you shcke camera and hear rattling noise that would be sure indication of it.
 victorgv's gear list:victorgv's gear list
Sigma DP1 Sigma DP2 Merrill Sigma dp2 Quattro Sigma sd Quattro H
Roger Veteran Member • Posts: 3,293
Any suggestions?
Many thanks
Greetings
Was if left on when stored? If so it keep trying to AF till it died. It might be able to be repaired or sell for parts.
Good Luck Roger J
furtle
Roger wrote:
Any suggestions?
Many thanks
Greetings
Good Luck Roger J
No, battery was out of it.  It'll join my growing pile of digital junk.  Nokia Communicators etc....
Best, Steve
victorgv
Ulvervs Forum Member • Posts: 80
Had the same problem, but i have a local Sigma authorized repair service in city, and it happened on the last month of warranty, so i left it for repair and couple days later had it back like brand new, till now it works just fine without any problems after so many years.
As i remember correctly the AF cable was detached from the socket, and one square nut was also loose. The service guy told me that he just changed this cable to new one as a precaution for the longer future use, and secured the screw with glue, because it was recommended in service manual. They even cleaned my sensor from dust, and i payed nothing for it
You should try to find service manual, in which you will find a dissasembly procedure, if it's not on the internet, just ask your local Sigma repair service for the one, maybe they will send you SM in pdf file as this product is discountined for so many years, and they would not bother to repair it anyway, as a paid service, because of the problem of getting spare parts.
If it will not be possible then read all the posts on this forum about the same problem, there were many discussions in this topic here even with pictures and information at what steps of disassembly you must watch out, and start openning the camera and make detailed description with sketches where any part must be used in the process of assembly (every step with picture on your phone). Then you will find the problem and be able to repair it. The new AF cable on ebay costs about 5£ so you can repair it by yourself, just remember to have a set of small screwdrivers and be very careful.
You will not loose more, but you have a chance to repair it.
Best regards,
Ulvervs
furtle
Best regards,
Ulvervs
Thank you Ulvervs!  Great advice.  I'll park it in my 'to do bin" when I have completed my other more pressing tasks suggested by SWMBO.
To be honest, my more modern Sigma cameras are great and I include in those the fp.  In fact, its a really lovely and convenient  camera.  Yes, yes, I know it's got a Bayer sensor .....
Best, Steve
So use it often, and DP1 will wait It doesn't matter if they have bayer onr other sensor, just use it.
