Best old Pentax body to get in 2021?
Started Feb 23, 2021 | Discussions
robgendreau Forum Pro • Posts: 10,926
What do experienced Pentax shooters think might be the best older Pentax digital body to get now as a basic value? say something older than the K-3 or K-50, so fron the K-5ii and further back?
I've owned as old as a K-01, but not before that. I would think a K-30 would be maybe to of the list as the most modern, but I know from other brands that sometimes the even older CCD and <10MP cameras have their own charms. And of course one has to factor in the negatives, like maybe old card formats or batteries that are hard to find, although I don't know if that's a problem with Pentaxes.
And are the Samsung/Pentax variants any better eg than the Hoya/Pentax models?
IOW, if you were to discover a circa 2011 or older Pentax on the table at an estate sale, what model would you like to see sitting there?
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
Pentax K-01 Pentax K-3 Pentax K-30 Pentax K-50
The Squirrel Mafia
The Squirrel Mafia Senior Member • Posts: 1,017
Re: Best old Pentax body to get in 2021?
5
The K-5IIs comes to mind. It's built like a tank & has great image quality from its 16MP AA filter free sensor. The only downside is the lack of KAF4 support for some of the recent Pentax lenses. You can use them, but they'll only shoot wide open, since the body can't control the lens' built in aperture motor.
The K-50 is also nice, but there's that 50/50 chance of a solenoid failure & the AF kind of sucks for moving subjects, but it has great image quality & it can use KAF4 lenses with the latest firmware.
The K-30 doesn't have KAF4 support, but there is a hacked K-50 firmware available for it that will enable KAF4 support, but install at your own risk kind of thing. It's also prone to that 50/50 solenoid failure.
The K-3 is a bit cheaper now, but speaking for myself, I'd rather get the K-3II. It has slightly better AF performance & IBIS. It's still rather pricey on eBay, though. You can almost get a new KP for about the price of a used K-3II.
 The Squirrel Mafia's gear list:The Squirrel Mafia's gear list
Pentax K-3 II Pentax smc DA 21mm F3.2 AL Limited Pentax DA* 16-50mm F2.8 ED PLM AW Pentax 11-18mm F2.8 Pentax K-50 +10 more
Schleiermacher Senior Member • Posts: 2,637
7
The K-5 or K-5ii — among the best sensors to this day. Great dynamic range and low noise in a relatively small body.
Schleiermacher
www.mmathews.zenfolio.com
'At our best and most fortunate we make pictures because of what stands in front of the camera, to honor what is greater and more interesting than we are. We never accomplish this perfectly, though in return we are given something perfect -- a sense of inclusion. Our subject thus redefines us, and is part of the biography by which we want to be known.' --Robert Adams, Why People Photograph
 Schleiermacher's gear list:Schleiermacher's gear list
Pentax K-1 Fujifilm X-T20 Fujifilm X-T3 Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited +12 more
OP robgendreau Forum Pro • Posts: 10,926
I had both a a K-50 and a K-3ii back in the day. Both great. Especially the K-3ii; one of the best APS-Cs for landscape and such. Still.
Pentax 645Z
jamesm007 Veteran Member • Posts: 5,820
And what a body. A Pentax classic. In form and function.
The K-7 was the first of that kind body but the sensor is so much better in the latter models  . I can’t recommend it for the small cost difference.   The K20D is a perfectly fine camera but the K-5s are much more modern and capable in all ways. Considering what they go for used the K-5, K-5II or K-5IIs are great used cameras. I’m sure others have their favs
 jamesm007's gear list:jamesm007's gear list
Pentax K20D Pentax K-5 Pentax K-3 Sigma 17-70mm F2.8-4 DC Macro OS HSM Sigma 10-20mm F4-5.6 EX DC HSM +12 more
OpticsEngineer Veteran Member • Posts: 7,839
I vote for the K5IIS.  Great solid feel in the hand.  Good image quality.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Olympus XZ-2 iHS Fujifilm XF1 Canon PowerShot G7 X Olympus Tough TG-4 Sony SLT-A65 +27 more
zakaria
zakaria Veteran Member • Posts: 6,556
K5iis
5
It is the best Pentax dslr I have owned.
pentaxian .
 zakaria's gear list:zakaria's gear list
Pentax K-1 II Fujifilm X-H1 Nikon D780 Fujifilm X-T3 HD Pentax DA 15mm F4 ED AL Limited +8 more
Kobie M-C
Kobie M-C Contributing Member • Posts: 701
Well, since you mention K-5II and back, I'd have to say K-5. It's ever so slightly better in high ISO. But either the K-5 or K-5 II would be the must haves. Phenomenal cameras.
I am not a Pentax insider. I just have a unique way of gaining insight.
 Kobie M-C's gear list:Kobie M-C's gear list
Pentax K-30 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax 55-300mm F4.5-6.3 ED PLM WR RE +6 more
Rahto Senior Member • Posts: 1,605
K3 or K3 II for compatibility with the newer lenses.
Bob
 Rahto's gear list:Rahto's gear list
Pentax *ist DS Pentax K-7 Canon EOS D60 Pentax K-1 Pentax K-3 +72 more
Kobie M-C
Bob
They want OLDER... K-5 II and older.
kypfer Contributing Member • Posts: 985
My K-5 continues to serve admirably, but it's image quality, at "normal" exposures and without cropping, is much the same as my other newer CMOS-sensor cameras.
For something "just a little bit different" I'd suggest one of the older 6 or 10 megapixel CCD-sensor bodies. I still use my *istDS and *istDL2but recognise that something like the K200D is probably superior, just haven't found one at a price I can justify
 kypfer's gear list:kypfer's gear list
Pentax K-3 Mark III Pentax *ist DL2 Pentax *ist DS Pentax K-5 Pentax K-70 +7 more
DougOB
DougOB Veteran Member • Posts: 3,176
Or the K10D.  Same sensor as the K200D but a sturdier, two control wheel body.  Bigger though.
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax KP Pentax K-70 +36 more
rmalbers Contributing Member • Posts: 529
Isn't it the same sensor that he has in his K-01?
Doug
My only reservation about the K10D is it's "different" battery and associated charger. All the other Pentax CCD-sensor DSLRs use 4x AA cells.
MrB1 Contributing Member • Posts: 605
K-5 IIs
AviPro
AviPro Senior Member • Posts: 1,254
K70
-- ## Thanks!
 AviPro's gear list:AviPro's gear list
Pentax K-5 II Nikon Z5 Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +1 more
iTrax
iTrax Senior Member • Posts: 1,125
K70
"from the K-5ii and further back" as requested
 iTrax's gear list:iTrax's gear list
Pentax MX-1 Fujifilm X100V Pentax Q Pentax K-30 Pentax K-01 +116 more
bob5050 Senior Member • Posts: 2,948
Pentax bodies have generally done nothing but get better, so not the answer you're looking for, but I'd ignore the body and look to see what lenses were on the table. Bodies aren't a matter of nostalgia for me.
bob5050
I just hope that everyone who's complained about the K-3iii delay actually buys one. One wonders, otherwise, about the sincerity of their complaints.
 bob5050's gear list:bob5050's gear list
Fujifilm XP130 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 50mm F1.8 +6 more
PentUp
PentUp Veteran Member • Posts: 4,188
K5ii - Hands down the best.
 PentUp's gear list:PentUp's gear list
Panasonic Lumix DMC-FZ300 Canon G7 X II Pentax K-5 II Pentax K-x Pentax K-3 Mark III +12 more
robbo d Veteran Member • Posts: 3,884
K5iis
Hands down best Pentax body of that era.
16mp sensor with killer dynamic range, no AA filter gave extra detail. Great in low light.
