Minolta Maxxum 7000 Aperture Problem
Started Feb 23, 2021 | Discussions
JTse New Member • Posts: 1
I'm new to film photography and recently I picked up a Minolta Maxxum 7000. When I booted up my camera, instead of displaying my aperture, it shows two dashes (- -) as pictured below and I'm unable to set my aperture. Does anyone know what this means and how to fix it? Thanks.
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Minolta Maxxum 7000 Aperture Problem
Welcome to the forum .
The 7000AF was my first proper camera that I bought used in the early 90's .
I still have it as well , amongst many others .
The problem here is the camera can't "see" the lens .
There are five electrical contacts on the lens and camera body .
You'll most likely find that these need cleaning .
The first way is to use a cloth with some Isopropanol alcohol on and wipe them down .
If that doesn't work use a rubber ( eraser ) to clean them .
There's always a possibility the lenses ROM is dead , but that's unlikely .
Do you have another lens to try on the camera , and another camera to try the lens on ?
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
FrancoD Forum Pro • Posts: 19,261
Yes, given the condition of the camera, dirty contacts are the most likely cause as well ,if, the easiest problem to fix.
Paul Barnard
Paul Barnard Veteran Member • Posts: 3,798
Did you fix it?  The 7000 is a really nice camera to use.  I switched from a Canon AE-1 to the 7000 soon after it was launched.  Going to automatic focus after using a split screen for many years was simply awesome. I got some great images from it.  I still have mine, keep the batteries fresh and work the shutter every now and then to keep it alive.  On the 7000 it is important not to let it sit without batteries for too long.  There is an internal button cell that hold settings when the main batteries are removed and it is a known failure point in the camera.  They are not user replaceable, though it can be done by taking the camera apart.
 Paul Barnard's gear list:Paul Barnard's gear list
Sony a7R III Sony FE 55mm F1.8 Sony FE 70-200 F4 Zeiss Batis 25mm F2 Sony 1.4x Teleconverter (2016) +5 more
EvilOne
EvilOne Forum Pro • Posts: 14,627
Perfect reply and advice... I too have a 7000. I took many great photos with it.
Good luck to the OP to get it sorted out
Bill
 EvilOne's gear list:EvilOne's gear list
Minolta DiMAGE 7Hi Nikon Coolpix 990 Konica Minolta Maxxum 7D Sony Alpha DSLR-A700 Sony SLT-A77 +5 more
SQLGuy
SQLGuy Forum Pro • Posts: 12,664
Definitely something to check with other lenses.
Bad solder on the PWB board that connected the mount to the ROM is pretty common in the Maxxum lenses.
However, I also have one A9000 and one A7000 with bad aperture base plates. This is the part that it seems the camera was built around that actuates the aperture control ring. Hopefully it's just bad solder or dirty contacts...
A7R2 with SEL2470Z and a number of adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR.
 SQLGuy's gear list:SQLGuy's gear list
Canon PowerShot G9 Canon PowerShot S100 (2000) Sony Mavica FD-91 Sony Cyber-shot DSC-S70 Sony Cyber-shot DSC-V3 +45 more
a-p-92 New Member • Posts: 1
Hi, I know this is an older post and I'm not sure if anyone can help, but I am a (very) amateur photographer and have just bought a working(?) AF 7000 from the bay. I'm having an issue with the shutter speeds and aperture automatic setting.
On 'PROGRAM' mode, the aperture and shutter speeds seem 'stuck' on f/22 and 1/2000 respectively with the numbers just blinking.
On aperture priority mode, the shutter speed is stuck and blinking on 1/2000, no matter the aperture and ambient light, and vice versa with the shutter speed priority, aperture stuck on f/22 at any shutter speed.
My lens has an aperture range of 1 : 4 (22), so I was under the impression that the camera should automatically be choosing the most appropriate values for these variables.
I've tried all ISO values too and it behaves the same on all of them.
I've replaced the main batteries and have ordered a new internal battery but from reading, I can't imagine it would be causing this issue.
As I said, I am a complete newbie so apologies if I am doing something stupid but I can't find any similar issues online.
Cheers
neilt3
Have you loaded film in it yet , with the DX coding on it ?
Are the contacts clean where the film goes in ?
The ISO has to be set before you can take pictures and the LCD does flash up like this .
DX coded film does it automatically, you should be able to input it manually for non DX coded film , so why your having a problem isn't clear .
Either way , without loading film and taking a test shot , you'll not find out if it is working or not.
Set it to a small aperture ( high number) and check the aperture stops down when you take the shot .
Camera needs to be set to "Aperture Priority" mode .
( Face the camera at yourself and look in the lens )
The aperture magnets sometimes Gail on the 7000AF and 9000AF .
SQLGuy
I just put some new batteries in mine and fired it up. No film in it.
It defaults to ISO 100. What does yours say?
It meters as expected in Program mode.
If I remove the lens, it still meters, but shows -- for the aperture.
Certainly sounds like something is wrong with yours. I'd suggest reading the manual to see if what you're seeing is an indication of some known problem.
Edit: after thinking about it a bit more, it sounds like something's wrong with the meter in your camera. It should be flashing 2000 and 22 if there's too much light for the selected film, but, since you're seeing this even with low ISO selected, it sounds like the meter is damaged and is always indicating too much light. You can probably still use it in full manual mode, but you'll have to do your own metering. There are apps for that.
A7R4a with SAL2470Z (G1), 55Z, and a bunch of other adapted lenses (Canon FD, Minolta AF, Canon EF, Leica, Nikon...); A7R converted to IR. Many other old DSLRs.
SQLGuy
You are seeing that on your Maxxum 7000? Mine just defaults to ISO 100 with no film in it. However, if I set mine to ISO 6400 and aim it at a bright scene, I can get it to flash 2000 and 22.
No need to load film to be able to fire the Maxxum 7000.
The aperture base plate failed in one of my Maxxum 9000s. This did not result in any issue with the metering or display. It just resulted in the lens not stopping down when firing the shutter or using DOF preview (the 7000 doesn't have DOF preview).
neilt3
I've just got around to putting some batteries in my Minolta 5000AF , 7000AF and 9000AF .
Your right , the 5000AF and 7000AF default to ISO 100 when non DX coded film is loaded .
It's the 9000AF that requires the ISO being manually set if non DX coded film is loaded .
ISO 100 flashes up on the LCD , and continues until you set it . With DX coded film loaded it is set automatically .
You can fire the shutter , but the only way you know if a camera is working 100% is with a test roll .
My 9000AF's still working well , aperture and all .
So I've just loaded some film in it to give it some exercise !
