Editors that can store edits in DNG metadata
Felix E Klee
Felix E Klee Regular Member • Posts: 374
ACR can store the non-destructive list of edits in DNG files, I assume in the EXIF data. That means neither a sidecar file nor a database is necessary to persist edits.
Are there any other editors that do so?
 Felix E Klee's gear list:Felix E Klee's gear list
Panasonic Lumix DMC-FZ5 Ricoh GR III
Joachim B Contributing Member • Posts: 729
Re: Editors that can store edits in DNG metadata
Yes I do. I use Lightroom and ACR/Photoshop. I shoot an Olympus raw, ORF, and convert that on import to DNG. Works like a charm to me. You can even incorporate the original ORF file into the DNG. Takes up much space, and i haven't seen the advantage yet.
But not all database information is stored in the file, only the development settings. So if you rely on folder structures, collections or star/color ratings, you still need the database for that.
Glen Barrington
Glen Barrington Forum Pro • Posts: 21,550
AFAIK - Only Lightroom.
For the most part, other parametric type editors use sidecar files.
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 II Olympus E-M5 III Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +11 more
Felix E Klee
OP Felix E Klee Regular Member • Posts: 374
Joachim B wrote:
Yes I do.
Actually, concerning my question, I guess you mean no, no other editors do that.
Good point. However, it doesn’t apply to me. I do my own organization of photos, and many photos are project based. So it wouldn’t make sense to keep them in one central database. I prefer one tool for a job, which is why I like ACR. I just don't like Adobe and their business practices. Also I have zero use for PS and LR, which are required for activating ACR. Nevertheless, it looks like I have no choice.
davidedric Veteran Member • Posts: 6,605
Felix E Klee wrote:
Joachim B wrote:
Yes I do.
You seem happy with what you are doing.  However, it would be easy to misinterpret what you say.
Lightroom does not prescribe any way of storing your images - your folder structure is entirely up to you.
Your images are not in Lightroom.  They are exactly where you put them, and Lightroom will not move them.
The Catalogue is a database referencing those files.  There is normally absolutely no need for multiple Catalogues - just sometimes photographers use separate Catalogues for different commercial clients.
 davidedric's gear list:davidedric's gear list
Sony RX100 VII Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic 12-35mm F2.8 +3 more
Felix E Klee
Some projects that I work on have data stored in Git repositories. So then the only option are sidecar files, having the edits stored in DNGs, or storing a database in each repository. Storing the edits in DNGs has the advantage that files can be moved and renamed without thinking twice. With sidecars or a database, renaming an image normally means that the reference breaks. The only exception that I'm aware of is Filmulator, recently featured on DPreview. It references images not by name but by a hash of their content. So you can rename them without breaking the database. However, it's still one centrally managed database.
Thanks for the clarification.  I appreciate your taking the trouble.
