Canon R or Sony a9 underwater
Started Feb 22, 2021 | Discussions
sg103d New Member • Posts: 1
Hey yall -- I have a Canon R and a Sony a9 and am trying to decide which to purchase an underwater housing for. Does anyone have any experience or suggestions?
Canon EOS R Sony a9
Barmaglot_07 Contributing Member • Posts: 633
Re: Canon R or Sony a9 underwater
I'd say the A9; if nothing else for the better autofocus, but you also need to consider other factors, such as - what lenses do you have? You will need a solution for wide-angle, macro, and possibly something mid-range. I'm not particularly familiar with RF lenses, but on the Sony side, macro would be served by SEL90M28G, and for wide-angle, you've got choices. One option is 16-35mm f/4 in a large dome (230-250mm range); another is a Canon 8-15mm fisheye via adapter (Metabones or MC-11), while another possibility is a 28-60mm zoom with a flat port and Nauticam WWL-1 wet lens - that last one is probably the most compact and easiest to travel with option. Don't forget a pair of good strobes as well - a full-frame camera needs powerful strobes such as Inon Z-330, Sea & Sea YS-D3, Retra Pro (my personal choice), Scubalamp D-MAX, etc.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
Architeuthis Regular Member • Posts: 491
I cannot make a real recommendation, since I do not have these cameras (I have Oly EM5II and EM1II in Nauticam housings for UW use). Since I am considering to change to mirrorless FF in the farer future (presumably next year), I follow the reviews and can describe what I think - maybe this helps:
#1.: Generally the decision should not be on a specific camera model, but more on a lens mount system, since the entire system costs will be many thousands of $ and the pure camera body is a small amount. For instance, once you have got your system around the Sony A9 (or Canon R), it will not be a big step to upgrade to a Sony A7RIV (or R5) after some time.
When it comes to the current mirrorless FF systems, I excluded already Nikon for me, since the technology (mostly AF) is behind competitors and also the use of Nikon DSLR lenses via adapter is difficult ("screwdriver"-AF Nikon lenses work only in manual focus via adapter on Z bodies).
#2.: Very important are the lenses that are available for a specific system (and in your case the lenses that you already have) - Important here is, that not every lens that is excellent over the water is also good for UW. The problem with Sony is that many lens types that are important for UW-use are lacking (see below). The advantage of Canon RF mount is, that many adapted EF lenses AF at least as fast/good, if not faster/better, on Canon R bodies than on the EF mount DSLRs (have a look into the Canon R forum here). Hence, one can regard EF lenses practically as "native" on RF bodies. See below a discussion of different lens types, important for UW use for Sony and Canon R:
#2.1.: Fisheye: This is a very important lens-type for UW. For both Sony and Canon you would use the Canon 8-15mm fisheye (or Sigma 15mm fisheye), that is an EF lens, with a domeport (e.g. Nauticam 140). No Sony fisheye lens exists. Adaptors reportedly do not make problems with AF, not on Canon R bodies, nor on Sony.
#2.2.: WA is either achieved with WA lenses and enormous domeports (result is o.k., but not really brilliant IQ) or via a "normal" range zoom lens with Nauticam WACP(=excellent IQ). For smaller budget and transportation also a wet lens (e.g. Nauticam WWL1) with normal range zoom lens and planport gives very good results (this latter configuration is possible with a zoom lens so far only with Sony in form of the new Sony 28mm-60mm; as far as I know no Canon zoom lens works with a wetlens for WA for FF)
#2.3.: "Normal" range works with both systems in regular sized (e.g. 180mm) domports.
#2.4.: Macro: here comes the problem with Sony. For AF speed not only the camery body is important, but also the AF drive(s) of the lens. While the Sony 90mm offers great optical IQ, AF is reportedly slow and hunting (see UW reviews of this lens in internet). The new Sigma 105mm macro with Sony mount is reported to be similar. This is contrasted by the Canon EF 100mm IS macro, that is very fast, even on R bodies. In addition, longer focal lengths (Sigma 150mm and Canon 180mm) exists for ultra macro at longer subject distances.
Bottomline is that both Canon R and Sony A9 are great to start a FF UW system. I personally do not have any Canon or Sony body yet, but the Canon EF 8-15mm and the 100mm IS macro lenses, so I sway towards Canon RF mount, but will carefully check the Sony macro "problem" before I make a final decision. Will be interesting to read what you and others think on that issue...
Wolfgang
 Architeuthis's gear list:Architeuthis's gear list
Olympus E-M1 II Olympus E-M5 II Sony a7R V Canon EF 100mm F2.8L Macro IS USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
No experience with Canon or Sony beyond their point-n-shoots.  I now shoot Nikon D850 underwater, after D810 and with a Sony RX100 for backup.
Looking at the specs, I would pick the Canon simply for the extra resolution, but I know nothing about the other camera capabilities.   If one has significantly better autofocus than the other, I would choose that one.
I will say that every time I've seen Sony's user interface (starting with RX100 II), I've been both frustrated and disappointed.   Canon's menus were far better for underwater use, at least with their point-n-shoots.
Beyond that, let's talk using full frame cameras underwater.   I can only speak from Nikon experience though.
For me, I have only three choices of lenses, unless I want to go off the reservation and try to gin up a port/extension system that works with some obscure lens.   FX cameras seem have zero choices for normal lenses.   You know, lenses in the 35mm-to-something range.  I have a choice between a few macro lenses, a couple of fisheyes, and maybe one wide zoom.   Since I don't like fisheyes, I effectively am limited to a 105mm macro and a 16-35 zoom, both with vibration reduction.
Furthermore, shooting a wide zoom requires a big dome port to get reasonable corners.  And you don't buy, carry and dive with a rig like this without the goal of getting reasonable corners.   This means B I G dome port.   If you have seen rigs like this before, let us know because you may have no idea just how ... controlling a big dome port is in terms of logistics of travel.  It's the underwater equivalent of having a 600f4 lens - woohoo! - but now you have to carry it to and from the dive resort.
Let me give you a heads up.
230mm dome port.   I had never seen one before unboxing mine.
The alternative to a big dome port?  Either fisheye, or perhaps one of the new, ultra-expensive and heavy wide wet lenses like the WACP2 (at $7500 and a dry weight of 7.06KG).
Not only that, my corners were ... poor anyway, until I added the special Sea and Sea Internal Corrective lens, made just for 16-35 lenses behind 230/240mm dome ports.
So - if one of your cameras has more lens offerings for underwater use, there's another good way to choose one or the other.
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Reefdiver Forum Member • Posts: 56
I shoot a7r3 underwater with sel 90 (great macro lens) and sel 16-35 f4 (rarely). I don’t know the Canon system but assume it would also be great. I think of the A9 as a great camera for sports with awesome AF, but not an obvious choice for underwater. Not that it wouldn’t be fine, just that underwater doesn’t make use of its best features. The extra MP in The a7r3 allow greater crop for macro.If you haven’t looked into it yet, you are facing a major expense. The housing will cost about the same as the camera body, dual strobes at 500-900 each, separate port for each lens etc.
